Question about Husqvarna Chain Saw 20" Bar
How to adjust carberator 41 huqvarna chainsaw
  • Husqvarna Master
  • 1,807 Answers
Http://www.mediafire.com/download/vl6tkv4b69eyvvh
the tuning screws are located on the left hand side of the saw, by the top cover
Posted on Feb 27, 2016
2 Suggested Answers
  • 41 Answers
SOURCE: I have a husqvarna 340 chainsaw and it will not
Turn the screw labled T in a little. This will raise the idle setting. Heres a link to the manual. Look on page 29 of the .pdf
http://www.northerntool.com/downloads/manuals/195946.pdf
Posted on Aug 02, 2009
Carberator adjusting
Many new units have a very limited adjustment possibility. This is due to EPA regulations. If the saw is hard to start, it may need to be richened up a little. Your dealer should have proper tool to adjust.
Apr 14, 2014 | Husqvarna 36 41 50 51 55 136 141 154 254...
I need instructions on for adjusting carberator settings on Mighty Mite chainsaw.
Before you make any adjustments start with fresh fuel in the saw. Dump out all the old gas and try starting with fresh fuel. The alcohol in the gas we have thease days draws water to to it. Water in the fuel will not burn.
Sep 08, 2013 | Garden
Gas continuously floods carberator
Fuel pump diaphragm faulty, main needle jet worn or float height needs adjustment.
Nov 13, 2012 | Craftsman Chainsaw 3.7 Vintage
Some Husqvarna carbs require a special screwdriver to adjust them, some just use a mall flat head tuning screwriver.
Screw both H and L screws in. Then turn them out anticlockwise the following amounts to return them to standard.
H 3/4of a turn L1 full turn (Chainsaws)
Some equipment like blowers and strimmers are:-
H 2 1/4 turns out L 2 1/4 turns out
Nov 03, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Yesterday i was using the 455 rancher its a huqvarna. it was working fine then, i went to use it again a little while later and when i went to cut with it it started bogging down and had little power.so i...
When it won't run correctly, try removing the fuel tank cap temporarily. If it immediately picks up, suspect tank venting problems. Good luck!
Nov 12, 2010 | Garden
How to adjust a mcculloch 610 chainsaw carberator
there are two screws on the card of youy chainsaw one is the slow running jet the other is the full throttle jet start up saw run it till its hot adjust slow running jet first till saw ticks over ok then adjust fast running jet till you have full throttle,, start with both screw turned in to one and a half turns then adjust from there
Mar 28, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
Need carberator settings for a sears craftsman chainsaw model#358.354831
You don't want to tighten them down just turn them in until the are just snug and then turn them out.
Start with the low at 2 full turns out and the high at about 1 full turn out. Start the saw and let it idle adjust the low idle to where it runs smooth. Adjust the high until the saw runs as much rpm as you can get at w.o.t. (Wide Open Throttle).
Jul 11, 2008 | Electrical Supplies
Husqvarna Chain Saw 20" Bar Logo
53 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
