Question about Home
Bird clock wrong sounds - Home
There's only one battery visible and it doesn't sing. Where are the batteries for the sound?
It is located on the back side.
2 total batteries for this type of clock, one for the time piece the other for the audio portion.
I have a cool clock like yours, but mine is Corvette Engine sounds. Very Cool.
There is a small door with a screw.
Mar 15, 2015 | Audubon Society Audubon Singing Bird Clock
I just got a radford exchange purr-fect moments kitten cuckoo clock and the clock movement doesn't work. I need to get a new clock movement with the wire that connects it to the bird sounds unit of th
There are several companies that sell that movement , just google clock movements and they have a chart with spec to match yours. I have replaced several in my time, its pretty easy
Jan 05, 2015 | Watches
I just got a Bradford Exchange Purr-fect Moments Kitten Cuckoo Clock and the battery powered clock movement doesn't work. I need to get a new clock movement with the wire that connects it to the bird
Bradford is a high end retailer. You can contact them because if the item is not over a year old then it is warrantied. The other thing is you can email them to see about the clock works inside the unit. See this page and look for "contact us" at the bottom.
How to fix a German Regula cuckoo clock?
As Larry said, you can pull the chain to spin the wheel in both directions. If you are having trouble with one chain being longer, you can even them out this way. I wouldn't suggest removing the weights.
Elisa Jed ' http://www.rockaroundtheclocks.com/category/34939958
Aug 10, 2014 | River City Clocks 6" Cuckoo Clock German...
No sound
I found mine was just making a clicking sound and no birds singing. changed batteries,all that synchronizing birds to time and nothing worked. Remove screws holding back on that are located around the ring area. carefully remove the glass,the hands, then the holding nut for the motor housing, remove face from clock assembly.There will be a wire going to the eye sensor for daylight/nighttime. Take a paperclip and jump the two solder points where the blue/black and yellow wire connect to the little circuit board (must have batteries in) and this resets the song feature. Not sure why this works, Simply reverse disassembly procedure making sure clock hands are unobstructed with each other and not bent, dont forget the seconds hand it's little and easy to forget to put back on.
Dec 08, 2013 | Audubon Society Audubon Singing Bird Clock
Birds won't chirp on the hour on audobon society bird clock
If the clock is more than a few years old, it may be that the switch movement inside has gone out, or maybe the sound mechanism has gone out. You'd have to find a clock repair shop that would consider working on it. Search clock repair in your general area with whatever search engine you prefer.
Aug 09, 2013 | Home
Instructions for Proteam Ho 1940 bird sound wall clock
Take out all 3 batteries. Move the hands to 5:50. Put batteries back. Start turning the white dial to correct time. As you're turning, if the clock is silent after 9 o'clock, you are on PM. For am, continue turning white dial to 6 o'clock when the bird sounds will start again and then to the correct AM time.
Jan 06, 2012 | Audio Players & Recorders
Singing bird clock
take batteries out set clock to 12.50 pm then insert batteries and set to normal time. this will then put correct bird sounds with relevant bird.
Dec 31, 2007 | Audio Players & Recorders
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
