Question about Hisense Televison & Video
Is there a firmware update available on this model LEDN50K20DGP that switches off the terrible film-interplotation/120mhz or judder correction. - There is no option to switch this off in the settings?
  • 1019 Answers
SOURCE: No firmware update available
why do you want or need a firmware update ?
if the drive is functioning correctly, it,s best to leave it alone.
Flashing a drive with firmware, can lead to an unusable drive. if you get a corrupt file-bad flash or power cut. you,ll have a pretty paperweight.
Mike @ Compurepair.
Posted on Feb 22, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: "Load main image failed
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
yammy_alf
  • 666 Answers
SOURCE: Problem scanning film with EPSON V300
check if upper cover remove for film scanning, bulb must be visible upon scanning in negative or positive film.
Posted on Mar 23, 2010
carsandcomps
  • 722 Answers
SOURCE: 2004 Accord sometimes judders as if only started on 2 cyl
Honda makes diesels - awesome.
Well, I know diesels aren't very complicated engines, however when anything goes wrong it's usually the fuel filter. I suggest changing the fuel filter, and see what happens.
Can't think of much else that would cause a diesel to that. And you say it only does it ever now and then, and you have to shut it off and then restart it.
Let me know if you need any further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Posted on May 21, 2010
  • 59 Answers
SOURCE: Bluetooth not available after software update
try reinstalling the software from the nokia pc suite. if it still doesnt help just take it to a nearby nokia care. updating software from nokia doesnt void your warranty remember.......
Posted on Jul 30, 2012
Hisense LED TV are not coming on and my power supply are 100% but my t-con board have no power and no pic and back light pleas help me model is LEDN50K20DGP/C1Z1
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 11, 2014 | Hisense Televison & Video
Transfer film not installed Fargo HDP600 cr100
Double check to make sure the film is installed correctly. The printer senses a chip, located on the roll, to determine - Type, Amounts and Physical presence.
If this problem persists, go to HIDglobal.com. Under the Support tab, click Drivers & Downloads. Populate the drop down menus with make and model. From here you can view all the recent software versions.
Scroll to the bottom of the page, under Misc. Download the Fargo Workbench utility. This program enables you to automatically update firmware. It is also a very useful tool in diagnosing issues.
Sep 24, 2014 | Fargo HDP600 Thermal Printer
How update wd800aajs-00b4a0 firmware ?
I do not believe it is possible to update the firmware on this model of drive. You can check on this WD website what software drivers and utilities are available for your model.
WD Support Downloads SATA SAS WD Blue SE SE16 SATA II Availability of firmware updates for WD Products
Aug 12, 2014 | Western Digital WD800AAJS-00B4A0
Vivitar 508nhd firmware upgrade?
Sorry, there is no firmware upgrade available, nor is there a way to upgrade the camera even if one were available.
Dec 29, 2013 | Vivitar ViviCam 8400 Digital Camera
I cant find the firmware updates for my 50" emerson flat screen tv model # LC501EM3
Emerson does not list any firmware updates are available for the LC501EM3.
Mar 11, 2013 | Televison & Video
Camera & blue tooth not functional
Thanks for visiting FixYa!
Since you did not include the brand, model number, cellular carrier or location of your phone I'll have to give you a general idea of how to correct your problem.
Go to the support page for your phone and see if there is a firmware update for it.
To do this, Google: "(Insert the Brand name and model number of your phone) support" (Without the quotation marks or brackets).
If a firmware update is available, download it to your PC. (Do not install it on your PC - it is for your phone.) There should be instructions on how to update the firmware on the (Support) download page. Follow the instructions.
Feb 18, 2011 | Cell Phones
If my scrren is blank how do i update the firmware
On the EOS Rebel XS 35mm you cannot update the firmware. It's possible on later Digital Rebel models, but not on the 35mm film versions.
Oct 01, 2010 | Canon EOS Rebel XS 35mm SLR Camera
I HAVE A NIKON 35MM FILM SCANNER LS-40-ED SERIAL NUMBER ;228462 AND I REQUIRE THE APPROPRIATE SOFTWARE TO LOAD ONTO MY APPLE MAC G4 DESKTOP COMPUTER (OPERATING SYSTEM X TIGER.)VERSION 10.4.6...
Hi
Download the Nikon scan application here: Nikon Scan
There is also a firmware update for this model. After installing the Nicon Scan software that includes the scanner driver (ensure that scanner is recognized), do the firmware update.
Follow instructions on site and do not interrupt firmware update procedure, or that may damage the scanner.
Coolscan IV / LS40 1.2.0 firmware update
Aug 20, 2010 | Computers & Internet
Nuvi 660 update firmware offers a g CHIP choice
Chipset "G" is an update of the GPS firmware for the SiRFstarIII receiver in the flip up antenna. I would update the firmware because it has updates to help improve satellite acquisition.
- Jim
Aug 18, 2008 | Garmin Nuvi 660 GPS Receiver
Mike @ Compurepair.
Feb 21, 2008 | Sony COMBO |CRX850E SLIM % (CRX850E)...
Televison & Video Logo
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
