Question about Homelite Consumer Products Tiller Attachment
No high throttle
I have an homelite htc 12, starts and runs. But when you give it throttle you get just a little.but you can reach down and grab the linkage and make it run faster.
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spraywith carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals canbecome blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
  • Jim Parker
    Jim Parker Jun 24, 2009
    Did this solution solve the problem?
    Jim
Whats the hi and low setting
Posted on Mar 22, 2010
A friend of mine gave me a zr series ,625cdv homelite weed eater and I can't figure out how to adjust the carb. Bought a new primer bulb it crank and run for a little bit but I have to idle it high
Screw in the HIGH and LOW needle valves. Then turn each one out 1 full turn, That should be a good starting point.
After engine is running Run engine at Full throttle. Loosen HIGH screw until the engines RPM slows a bit. When that happens Turn screw back in until it revs high and then just starts to slow again. You do not want the engine to run at it's highest RPM or it's not getting enough Lubrication It need to run Rich, that's why you screw the screw in a bit after the engine has reached it's highest RPM. Let it idle down . Then Accelerate hard, if it hesitates, loosen or tighten the LOW until it accelerates quickly with no hesitation.
May 30, 2017 | Homelite Garden
Engine runs full throttle and won't throttle down
Try grabbing the governor arm coming out of the side of the engine where the throttle linkage comes from, can you manually slow the engine down with that? Is it stuck?
Jun 09, 2013 | Cub Cadet Garden
I have a homelite htc 12, Its starts fine but when I speed it up it stalls and wants to dye. how can i fix this ?
Check tank filter first, should be easy to blow threw. Cut wire from clothes hanger, 8 to 10 inches bend hook at one end, reach in tank pull fuel line out of tank remove filter. replace if needed.
Sep 01, 2011 | Homelite Garden
My Homelite grass trimmer idles fine but when I open the throttle it stalls. How do I fix this?
Its sounds like it is running rich. Adjust your high speed adjustment screw. If the unit is older think about buying a carb rebuild kit, they run about $12.00 at your local fix it shop and if you are not in a hurry online for about $8.00 give or take S/H.
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite Timberman chainsaw won't run anymore
ohhhh maybe ya burnt a hole in top of piston... are you SURE compression is OK?
Feb 13, 2010 | Garden
Carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Dec 24, 2009 | Garden
Homelite saw runs wide open(homelite ut10520)
There is a recall on the UT models, all you have to do is call the costumer service center for homelite. they will give you a number for the closest warrenty center that will adjust you throttle cable free of charge. I went through two UT 10520's before i started researching the problem.
Feb 02, 2009 | Garden
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Homelite Consumer Products Tiller Attachment Logo
396 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
