Question about Garden
Atco manual Hi, bought a secondhand atco admiral 16s. Cleaned up really well. Dusty but all good. Throttle cable linkage rusty but freed off and working. Could use a manual, apart from pulling the pull cord how does it start/ stop. Is there a switch. Thanks Alan
  • 417 Answers
SOURCE: pull cord switch
If it is a 1 way switch circuit (2core +earth cable) it should be LIVE/HOT in COM and Aux live (to the light) in L1 . I
f you have a 2 way circuit (3 core + earth cable) the aux strappers go in L1 & L2. and LIVE/HOT to COM
Remember to disconnect the power before working on electric wiring.
Please remember to rate this solution.
Posted on Oct 23, 2008
steve_lima
  • 181 Answers
SOURCE: Pull cord on weedeater wont recoil
sounds like the spring is broken itself.there should be a hook at one end and a loop at the other end.the hook usualy breaks off but the spring looks good.replace the spring with part number..4140 190 0600 ....that is the stihl part number.let me know if this helped you...if not give me a quick mail and i'll try to help some more......
Posted on Mar 13, 2009
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
lilmikew99
  • 122 Answers
SOURCE: TB144 pull cord does not catch, pulls free--no start
yes exactly what i would do sounds like the springs are either worn or gummed up or just broken on the dog ears
Posted on May 11, 2009
  • 246 Answers
SOURCE: tecumseh engine #143.985510 - carb linkage hook-up
Hello:
The Carbuertor Throttle is Held in the Full Open Position Until the Engine is Started and Running, then the Governor and Spring Work together to Keep the Engine RPMs to the Desired Setting.
The Following is an Explaination on How the Governor System on Small Engines Function.
>>The Governor System behaves like an Unending Tug of War between One of Two Governor Springs, which Pull the Throttle Toward the Open Position, and a Spinning Crankshaft, which Tries to Close the Throttle. When the Load on the Engine Increases - a Typical Example is when you Move your Running Lawn Mower from the Driveway to the Grass - Crankshaft Revolutions Drop. But the Governor Spring is Still Tugging, Causing the Throttle Plate to Open. In Response, a Larger Volume of Air-Fuel Mixture Enters the Carburetor, Increasing Engine Speed to Compensate for the Increased Load. The Crankshaft Speeds Up, and the Tug of War Resumes, until a New Equilibrium is Achieved. With Each Change in Load, the Tension Between the Governor Spring and the Load Brings about a New Equilibrium, known as the Engine's Governed Speed. Neither Side Wins until the Engine is Shut Off. At that Point, without the Crankshaft Spinning, the Governor Spring Pulls the Throttle to the Wide-Open Position. Two Types of Governors are Common on Small Engines - Mechanical and Pneumatic.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
I need a diagram of a 1991 flhtc carburetor throttle side including the linkage
Hi, Gary for this scenario you will need a service/owners manual if you can not find the first and best tool you ever bought for your Harley, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below, and for specific information or questions feel free to contact me at xlch@mail.com. Good luck and have a nice day.
http://www.harley-davidson.com/en_US/Media/downloads/Service/isheets/-J02631.pdf
HowTo Adjust Harley Davidson Throttle Cables
1991 flhtc carburetor throttle side linkage diagram Google Search
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Instant Tech Relief A must have !!! only $6 a month "CHEAP"
May 30, 2016 | Motorcycles
Briggs Stratton 5hp I/C starts ok, runs, but will not rev
My money is on a partial blockage of the main jet or the passageway to it. You're having to force it to run through the idle jet by fully choking the incoming air. There's not enough gas coming in with the choke open to allow it to run.
I'm thiniking total carb disassembly, carb cleaner and an air compressor combined with a ton of patience will take care of the issue.
Mar 31, 2015 | Briggs & Stratton Briggs Stratton...
2004 Honda VT 1100 C2 Shadow Sabre throttle linkage loose
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Throttle Cable Adjusters
Motorcycle throttle cable adjustment MP4
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 07, 2014 | 2004 Honda VT 1100 C2 Shadow Sabre
Admiral side by side fridge freezer gc2227cgfw - not cooling and clicking on/off noise from bottom of unit - have pulled out to investigate was very dusty and vacc'd out loads of dust - but warm in bo
Leave the unit unplugged for at least 4 hours then plug it back up, if it still clicks and doesn't cool, the compressor is likely burned out. It sounds as though it just overheated and is tripping out on overload, it should restart and run fine if it didn't get too hot. Good Luck...
Mar 21, 2014 | Admiral Refrigerators
Yamaha 82 model XJ650: Throttle cable will not move. Disconnect cable from carb linkage and cable works freely, no resistance. However, if reconnect to linkage, throttle will not move. Bike has been...
hi sounds like the main spindle shaft that operates the carbs has seized spray penetrating oil wd40 or similar all over the outside of the carbs giving them a good soaking leave for a good few hours
and gently try and wriggle the throttle cable till it starts to move then spray it some more if this doesnt work remove the carbs and clean them out putting penetrating oil inside the throttle bores
you will probably need to take off the lower fuel bowls and clean them out too if its been standing a long time the fuel avaporates away and your left with a lot of corrosion inside that must be cleaned
out as it will block fuel flow through the carbs
Feb 22, 2011 | 1982 Yamaha XJ 650
How do I adjust(set)the engine speed govenor on an Atco 114cc engine.
Some ATCO carburettors have more than one hole for attaching the throttle cable to the governor pivot, which will allow some variation of the speed setting by moving to a different hole.
Just before the throttle cable reaches the governor pivot it passes through a metal lug (separated from the pivot by a spring) here there is threaded screw on the throttle cable - loosen or tighten this to adjust running speed.
There is also a throttle stop adjusting screw which on the side of the carburettor which you can adjust to set the idle speed.
Feb 22, 2011 | Garden
I am having a problem with the Acceleration, The petal may be loose? It feel like the petal doesn't go down as far as it used to, the cars takeoff is significantly slower now. I have inspected the gas...
Real good chance the throttle valve cable and linkage from throttle to top of linkage is seized, or seizing and needs lubrication. You'll have to remove battery to see it good under battery tray, and look for the piece of linkage on top where shifter linkage attaches.It needs to move freely. It also regulates your shift points as well, when passing etc. If you push gas pedal hard, it will begin to stick in lower gear longer (revving) before it shifts up, and will downshift hard as well when slowing to stop. Gas pedal will feel stiff, until you get it freed up. Try penetrating lube like WD-40 first to get it freed up, then spray white lithium grease or similar on it after. Do not try to remove nut holding it on, and remove linkage, just leave it on there and keep working it until it will move a full sweep back and forth freely. If you remove that piece of linkage, shaft will drop down and need to remove pan etc to fix it. If you need a picture, let me know, I have one from past experience with same.
Dec 15, 2010 | 1997 Dodge Neon
Need to adjust the throttle on a 2000 Kawasaki KX250
Hi, Allmillers for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
VERY IMPORTANT TWO STROKE THROTTLE CABLE ADJUST TIPS
How To Adjust Throttle Cables Like Pro
Kawasaki KX250 Service Manual
OEM Parts for Kawasaki
Kawasaki kx125 1997 Owner Manual
Nov 16, 2017 | 2003 kawasaki KX 250
2002 dodge dakota sxt 4x4 with 75000 miles i have
Have a look at throttle valve cable, which will run to transmission, close to shifter cable. It runs from throttle linkage area on throttle body, to the transmission. The cable and/or linkage may be partially seizing at transmission end, and hanging up too long resulting in symptoms you are experiencing. With engine off, have someone press throttle to floor slowly, and watch what that linkage does, then have them release pedal, and watch as well. When pedal is pushed it should pull that linkage around, and when pedal is released, that linkage should return fully in the opposite direction. If that linkage doesn't return all the way freely, then transmission will hold up in lower gear longer. Give that linkage area, a good spray with penetrating spray, such as WD-40 or similar, and make sure it is returning all the way freely. Once it's freed up real good, spray it with white lithium grease or similar to keep it from doing same in near future. You can probably work that linkage by hand as well, to make sure it gets loosened up real good, and is returning fully. Give that a try and let me know how it goes.
Jan 16, 2010 | Dodge Daytona Cars & Trucks
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
