Question about Panasonic Technics SL-1210MK2 Professional Turntable
Turn power on platter spins really fast
Both 33 & 45 buttons light up and the platter spins really fast soon as the power button is turned on
4 Suggested Answers
SOURCE: TV Won'T Turn On
A fuse is not your problem. this TV has a safty feture that when it senses a problem it cuts the power to prevent any fouther damage, when you un plug it the TV resets and it will turn on agian. I have the same TV Check the CRT light guns there are 3 of them. If one goes bad it will cause your problem.
Posted on Dec 18, 2007
  • 1121 Answers
SOURCE: Power button flashes red. TV comes on momentarily
this is a inverter board defective. please change-it
Posted on Oct 31, 2009
  • 8457 Answers
SOURCE: I was watching tv and it suddenly cut off; soon
Power supply board is dead.Replaced the power supply board will get ur power back.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Posted on Feb 15, 2010
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Hi having a problem !!
If it has a belt drive, the belt has to be replaced.
Mar 22, 2015 | Technics SL-1210 Turntable
How do I fix the speed of my Technics SL-6 Turntable?
Something has gone awry in the world beneath the platter so you will have to remove the platter to expose the mechanism, then observe what happens (or doesn't happen) when the buttons are pressed.
Jul 29, 2014 | Technics Audio Players & Recorders
Technics 1200 fault where both the 33 & 45 buttons remain lit, the platter spins at super speed,start stop button doesn't work and the red light is not on
Did you try to de-assemble and clean the contact of this button with contact cleaner, take care to not shoot on rubber parts if you have near the contact, it would blown up !
Apr 28, 2014 | Technics Audio Players & Recorders
When i turn my 1210s on both 33/45 switces come on and platter spins too fast
Couple of options , but first cleanen the pithfader and variable resistor pitch vr3 i thought, it's an open one , he needs allways to be replaced, even technics says so and first clean the board, inside and on youtube and this side there enough movies and text how to do it, and check the pitchfader cables very good.
Apr 12, 2014 | Technics SL-1200MK2 Turntable
Arm not working. Stop/start light flashes red instead of staying solid
Don't try and force anything that won't move. Try this. With the power unplugged, place the tonearm over the record, if it will move freely, while rotating the platter by hand. Move the tonearm slowly over the surface of the platter until the end. Continue turning the platter by hand and see if the tonearm picks up and returns to the rest. See if that fixes your issue. For more information or further questions, please visit my website at audioserviceclinic.com. Thank you.
Dec 09, 2013 | Technics Audio Players & Recorders
Counter clock spinning
pitch slider can cause an unstable motor (clean with can of air and switch cleaner) if it spins counter clockwise it will be the brake. there is a little screw in a hole under the platter to ajust the brake speed.
Jul 14, 2009 | Technics SL-1200 Turntable
Stanton ST150 turntable won't spin
Hello DeKay,
I just had a spindle lock issue this past Sunday at my gig. I had the turntables out in my car and brought them in. I let then warm up for 2hrs before plugging them in.
Everything was good. Then mid set my right side turntable started spinning really fast and then DEAD STOP.
I was pushing the platter and it really hard to turn. I took off the platter and tried to turn it with my hand. It was dead locked, WTF?!!
So I limped through with one turntables since I use Traktor Scratch Pro and made it through the whole night successfully.
I searched the net and it was suggested to lubricate the 1200 spindle with 15W40 motor oil. Since the motor design is indentical, I picked up some 10W40 motor oil since I couldn't find 15W40.
I oiled both turntables to be on the safe since. I tapped the spindle on the locked turntable to help loosen it.
I drove back home which is pretty much an hour drive and let the tables sit for another 2 hrs.
I decided to grab a thick towel and vice grips to work on the locked spindle.
Clamping down on the towel with the vice grips on the brass fitting for the platter I was able to free the spindle quite easily.
I was then able to turn it by hands so I did in both forward and reverse directions to work the oil down into the spindle bearings.
I put the platter back on and spun it manually to check for resistance, it was spinning nicely!
Plugged in the turntable, set the pitch at 0 and watched the stobe dots. There was no waver in the strobe dots. YAAAAAAAY!
My turntable is back to new and since I only use them on the road they stay stored most of the time.
So I would suggest just oiling the spindles every so often to keep them tip top.
Hope this helps you!
Peace,
DJ Quartz
Nov 06, 2008 | Stanton ST-150 Turntable
Platter quit spinning
Sounds like the motor drive controller might be malfunctioning. An authorized Denon service center would have to take a look at it to make sure.
Apr 08, 2008 | Denon DN-S3500
Panasonic Technics SL-1210MK2 Professional Turntable Logo
43 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
