Question about Maytag MAF8805AES Front Load Washer
How to close the door on a may tag MAF8805AES washing machine
My hotpoint aqualtis model number aq9f 492 u is showing f6 what does this mean
F06 Door lock fault
Issue: Washing machine door cannot be opened or closed / when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Dec 29, 2015 | Hotpoint Washing Machines
May tag centennial washing machine model mvwc400xw1 has a button to start,pause,machine...will no longer work..can this be replaced. Runs fine if I can get it started..slamming lid sometimes help.
the machine will do nothing until the door or lid is detected as closed
so your fault is the door detect or ' interlock'
is the issue
not the button buddy
Apr 28, 2015 | Washing Machines
May tag Neptune 5500. The door locked light never comes on and door is not locked in any cycle. How do I test the switch/lock assembley? And is there a way to trick the machine into thinking that the door...
Grounding in a 120vac environment usually will cause a big spark and pop the circuit breaker. There is a possibility the latch is like a car door latch. If it somehow gets moved to the shut or latched position when the car door is open, it will never close and latch . The latch must be returned to it's normal door open position so that when closed it will latch securely.
Your machine's latch may be blocked by something acting like the car door latch described above. It may be the switch has broken and is the "culprit".
Mar 26, 2015 | Neptune Washing Machines
Washing machine
Lower the exit pipe fixed behind your washer to let out the water. If there is much water in machine it will not open. Then open the top of the machine, screws behind the top. Reach out to where the lock is, you may find a plastic tag which you shd pull down, it's the door release tag.
Apr 13, 2013 | Hotpoint Washing Machines
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
Washing machine door wont open on hotpoint aqualtis after wash.The door locked sign os still on no matter what i do.
remove the front kick strip, on the LHS you will notice a yellow tag. with the power on on the machine pull down twice gently on this tab. this should unlock the door.
if you now notice the drum is full of water its more than likely your filter is blocked and this is what caused the door not to open.
Jun 25, 2011 | Hotpoint Washing Machines
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
I have a samsung wf316law\xaa washer.I started a load of clothes and went out later and it had stopped early in first few cycles.I got the door open by pulling real hard took clothes to finish them.Now the...
hello,
solution bellow.
There is disclosed a method of controlling an automatic door opening/closing apparatus
for a washing machine that includes the steps of determining whether or not there is an error in
an automatic door opening or closing operation carried out in response to a command to open or
close the washing machine's door; determining if the erroneous operation has been
repeated more than a predetermined number of times according to consecutive incoming commands to open or close the door; and when erroneous operation has repeated more than the predetermined number of times, ignoring a subsequent command to open or close the door.
1. A method of controlling an automatic door opening/closing apparatus for a washing machine door, the method comprising the steps of: determining whether or not there is an error in an automatic door opening or closing operation which operation is carried out in response to a command to open or close the washing machine door;
determining if the erroneous operation is repeated more than a predetermined number of times according to consecutive incoming commands to open or close the washing machine door; and
in the event that the erroneous operation is repeated more than the predetermined number of times, ignoring a subsequent command to open or close the washing machine door.
2. A method as set forth in claim 1, further comprising the step of: returning the door to the washing machine to an original position in the event that the error occurs.
3. A method as set forth in claim 1, wherein the step of determining if there is an error in an automatic door opening or closing operation is performed on the basis of whether or not an inversion occurs in an open/closed state of the door within a prescribed period of time after an automatic door opening or closing operation is initiated.
4. A method as set forth in claim 1, further comprising the step of: clearing the number of errors in the case where the door of the washing machine has been opened or closed manually at the time of occurrence of the errors.
5. A method as set forth in claim 1, wherein said predetermined number is 3.
6. A method for controlling the operation of an automatic door mechanism in a washing machine, said method comprising the steps of: sensing a command to automatically open or close a washing machine door;
sensing whether a failure occurs in opening or closing the door in response to the command to automatically open or close the door;
incrementing a counter indicating the failure;
determining whether the counter is equal to a predetermined number; and
failing to engage the automatic door mechanism in response to a subsequent a command to automatically open or close the door if the counter exceeds the predetermined number.
7. The method claimed in claim 6, further comprising the step of: returning the door to an original position if a failure is detected.
8. The method claimed in claim 6, wherein failure is indicated by a lack of a transition between a door open state and a door closed state within a predetermined time period following entry of the command to automatically open or close the door.
9. The method claimed in claim 6, further comprising the step of: clearing the counter if the door is opened or closed manually following a failure indication.
Thanks for using fixya.
Nov 02, 2010 | Samsung Washing Machines
How do I open the door of the washing machine? It is a Bosch Maxx Classic
there should be a smal door on the front pop that door open you will see a colored plastic tag, that is your manuel unlock
Oct 03, 2009 | Washing Machines
Door error on maytag front loader washing machine
that is the emergcy door release once the door is closed it will eset it self what is the Model Make and code you are getting
Aug 02, 2008 | Washing Machines
Maytag MAF8805AES Front Load Washer Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
