Question about EuroTech EDC158 Electric Dryer
Drain light comes on and stops machine, no water to empty
The dryer stops drying. Obviously, there is a problem, but I don't know what to do. Have cleaned the condenser, lint filter etc.
3 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: I have a eurotech condenser tumble dryer (EDC158).
Hello & Welcome to FixYa
If you have already tried to clean the drain pump-filter assembly located inside the bottom panel and the problem is not solved then you will have to replace the drain pump. Please get back to me if you have any other questions.
Kevin
Posted on Apr 30, 2011
Daniel S
  • 4323 Answers
SOURCE: EuroTech 158 Dryer. Green Light
Hi
If everything is cleaned then all you have to do is turn on the machine, turn the knob to STOP, and wait a couple of seconds. You'll hear a tone and the light will stop blinking. If the issue returns and the drain filter inside the lower front assembly are cleaned then the issue is with the pump relay on the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 15, 2011
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
Hello, i am using Haier washer dryer HWD-D1200TXVE that is 1 year old, after a full cycle (pre-wash) the machine gave an error 12 and did not perform drying because water was not drained. I opened the...
Look up the mfg website and see if they have a troubleshooting page or a support group. It may still be a warranty item check that as well
Oct 20, 2013 | Washing Machines
Check drain light comes on and machine will not spin or empty
You probably have a blocked sump. Empty the machine by hand and remove as much water as possible because you will need to remove the sump hose which is under the machine, place a shallow bowl or dish under it before taking it off or you could flood the floor. I've no idea what machine or model you have but you will probably need to tilt the machine away from the sump (if it is at the rear of the machine then tilt it forward ) undo the clamp holding it on and carefully pull it free from the tub, clean it out and replace it
Mar 25, 2017 | Miele Washing Machines
After drying a load of rather damp clothes, the 'emty out container' light keeps coming on (there is a loud peeping noise and the dryer stops) even though the container is empty. The container is not...
This may help you. Please give the person who answered this thread credit if this helps.
http://www.fixya.com/support/t277592-bosch_classixx_condenser_drier
Apr 07, 2011 | Dryers
LG TD C70045E problem
Fluff has blocked the drain hole into the water drawer.Try locating the hole and using a small bore plastic tube **** the debris out of the container.
Feb 21, 2009 | Zanussi TC7102W Electric Dryer
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
EuroTech EDC158 Electric Dryer Logo
35 people viewed this question
Top EuroTech Dryers Experts
Tim Whalen
Colin Stickland
Colin Stickland
Are you an EuroTech Dryer Expert? Answer questions, earn points and help others
