Question about Dacor MCS230 Millennia Electric Double Oven
Fan doesnt turn off for 30-40 minutes after turning oven off MCS230s
2 Suggested Answers
blackmar
  • 235 Answers
SOURCE: Do I have to pull
On some ovens you have to pull the oven out of the cavity and remove the top panel of the oven to get access to the electronic timer control. On other ovens you only have to remove the panel which is behind the timer without removing the whole thing. Just slide it out a bit and have a look at the panel behind the timer.
Posted on Feb 16, 2011
My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
May 16, 2016 | Smeg Ovens
DCS Double oven cooling fan will not turn off
Is this a convection oven? Need more info.
Mar 03, 2014 | DCS (WOTD-227) Double Oven
Simpson Nova oven model 63-538 fan and light not working
I have the same oven and the fan doesnt work intermittantly. I turn it on and off a few times and if that doesnt work I give the fan a push with the handle of a wooden spoon. Works so far so I havent bothered with a 'real' fix as yet.
May 21, 2012 | Electrolux Ovens
New World G90m grill turns off - overheating?
Its a good chance its the thermal control board to the fan (PCB),if faulty it doesnt allow fan to reach correct speed thus overheating.
Hope this helps
Feb 05, 2012 | New World G90m Gas Double Oven
Do I have to pull the whole double oven assembly out of the wall to gain access to the upper oven power relay board? MCS230S
Feb 16, 2011 | Dacor MCS230SS Millennia Electric Double...
My oven light turns on but the oven doesnt heat up
If it is a fan assisted oven, and the fan is working o/k, then it is likely to be a faulty oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Dec 17, 2010 | Electrolux EOU6330 Electric Double Oven
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Jmw8527AAb Jenn Air Electric Wall Oven
Has anyone done any repairs to the oven lately? It sounds like it's working in reverse. The fan is supposed to come on about 10 minutes after the oven is turned on. The reason I ask this question is if someone did work on it they could have wired the fan relay wrong. If not you have a problem with the oven fan relay. They occasionally short and it wll cause them to run the opposite way they are supposed to.
Dec 21, 2007 | Jenn-Air JMW8527C Electric Double Oven
Dacor MCS230 Millennia Electric Double Oven Logo
11 people viewed this question
Top Dacor Ovens Experts
Vitaliy Gins
Vitaliy Gins
ashburton
Oloyede Monsuru
Are you a Dacor Oven Expert? Answer questions, earn points and help others
