Question about Smooth Fitness Smooth CE 8.0LC Elliptical Trainer
Smooth Fitness Elliptical CE 8.0 LC - Smooth Fitness Smooth CE 8.0LC Elliptical Trainer
Life fitness 95XI elliptical clanks
You may still have the original tie rod design on your machine. If so, more than likely this is your problem. The link below is the updated fix for the original design.
Control Link Kit LifeFitness GK62 00002 0071 SPORTSMITH net
Dec 16, 2013 | Life Fitness 95XI Elliptical Trainer...
What are popular brands of elliptical machines?
Popularbrands include: Precor, Sole, ProForm, Eclipse, and Smooth.
Aug 05, 2012 | Exercise & Fitness
Are Smooth Fitness elliptical trainers good?
I have never used one; however I will send you a site with a lot of information about them, including customer reviews.
http://www.smoothfitness.com/ellipticals-machines/smooth-ce-80.htm?select_tab=reviews#reviews
Aug 02, 2012 | Exercise & Fitness
Is it better to get a rear-drive or front-drive elliptical trainer?
To best answer this question for you I have found an excerpt about this topic written by a fitness professional. Read it over and then consider your options.
"The rear-drive elliptical trainers have a more intuitive design," explained the fitness equipment expert. "When you exercise, inherent in this design is the proper biomechanical motion. It's a more natural motion. Most commercial units are the rear-drive type, because it has a floating system with free-rolling bearings. This means there are less mechanics, and less mechanics means less wear and tear. Also, mechanics in the back allow the user to sit forward, maintain the proper posture and, thus, get a better workout."
Our expert went on to describe front-drive ellipticals: "With front-drive elliptical trainers, they have to add extra linkage to make the pedals more comfortable. They also have to use a track, which can break down due to dirt build-up. There are more mechanical components, which need constant maintenance. More mechanics lead to more wear and tear and more noise. These machines tend to lose their smooth feel. The mechanics pushes the user back, making it necessary to lean forward, so the workout is not as effective as you get on a rear-drive model."
I really want to buy an elliptical machine for our home, but I can only afford to spend a couple hundred dollars. Can I find a machine for that amount?
Finding a machine for cheap shouldn't be too difficult - check out some discount department stores. I would strongly suggest that you wait and save up some more money. An elliptical machine is a great investment and holding out until you can afford a higher quality machine (such as one from Smooth Fitness or Sole) is well worth the wait.
Monitor diplays E1 and won't stop beeping
Fitness Quest Eclipse 1175e Elliptical Trainers were recalled on December 11, 2007 for a fall hazard. During exercise, the foot pedal crank can break. After receiving 190 reports of the crank breaking, the company is offering a replacement product or credit toward other Fitness Quest products. If the pedal falls off, be sure to save it; you will need the right foot platform to claim the replacement or credit.
Owners should stop using the elliptical trainer immediately. Owners can receive a replacement with another Fitness Quest product or credit.
Eclipse Recall Instructions and Form (PDF)
Questions? Contact Fitness Quest at: (800) 321-9236 between 8:30 a.m. and 8 p.m. ET, Monday through Friday. Or, e-mail productrecall@fitnessquest.com.
The Fitness Quest Eclipse 1175e Elliptical Trainer was sold at major sporting goods chains, such as Sports Authority, Modell's, Dunhams, and JC Penney stores in the United States from September 2006 to October 2007. Sale prices were $290 and $450.
E1 errors are usually lubrication/resistance issues. Has the unit been oiled/greased recently?
Jan 10, 2009 | Fitness Quest Eclipse 1100 Hr/A Elliptical
Smooth Fitness Smooth CE 8.0LC Elliptical Trainer Logo
52 people viewed this question
Top Smooth Fitness Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Smooth Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
