I have a 51pp9200d rear projection made by philips. I went to turn it on today and audio came on like normal but only for a second or two then stopped. The picture never appeared and the power button blinks slow six times, then one fast and repeats. Can you help? Ive unplugged the unit for a few minutes and plugged it back in and it still doesnt work.
  • nate85dogg04 Jun 18, 2009
    Is the fuse inside the power supply or attached outside? Could you tell me exactly where to look so I can relay the imformation to my TV Tech? Should the fuse look like a resistor? Is there a possiblility that the power supply is bad? Where can I find parts for tvs nowadays? Thanks again
    Positivly nothing had ever been spilled inside the tv. Do you still think that changing the fuse would STILL fix this problem even wikthout the "spillage"?
  • 555 Answers
Try to check your remote control maybe you press someting or try to reset it using your remote control. Else turn off your unit and unplug all its wire then after 5 mins try to plug its wire then try to turn it on and obeserve its result. If the problem continues then better call a technician and let it check or try to call the supplier to ask support in this problem directly to them to have more detail information to solve this problem.
Posted on Jun 19, 2009
  • Jonas Awayan
    Jonas Awayan Jun 19, 2009
    You can change the fuse but you have to consider first that if you change the fuse make it sure that you have the right fuse and proper installation of it. Cause sometimes there are fuse that are not compatible to the unit/device. I recommend that if you want to change the fuse first try the solution that i have earlyier then if it not works then contact a technician or a shop near in your place cause they have a better tools in fixing that device or unit.
    Thanks
  • 355 Answers
Many things can be wrong here. simplest thing could be a fuse on the audio board blown. but let me stress that taking the back cover off the tv and poking around can be VERY DANGEROUS AND DEADLY. most t.v.s ive seen with this problem have had something spilled inside the tv
Posted on Jun 18, 2009
  • Rohit  Asthana
    Rohit Asthana Jun 18, 2009
    Check the site www.TvRepairKits.com.
    They have put together a couple of kits to fix the chirping set/dead
    set condition. If you don't see your model listed send them and email
    and they will build a parts kit for you.
  • 81 Answers
Dear nate
This is a common problem with some of these models. Unfortunately this code means there is a short in the power supply. It is quite possible that the internal fuse had blown and needs replacement.
Fortunately it doesn't mean your TV is dead! A TV technician should be able to do this. The fuse is typically located behind the lamp but this will depend on your specific model.
Best of luck!
With regards
Liveks
My Philips 51PP9200D/37 tv won't turn on. The lighted power button stays lite but nothing else happens. Could this be the Flyback transformer?
It could but it could be about 50 other things as well. You have a voltmeter, and know how to use it? going to need a service manual as well.
Dec 19, 2012 | Philips 51PP9200D Television
No picture
try turning the green screen control down slightly. The screen controls are located in the back of the set on a block about the size of a pack of cigarettes. with 6 knobs 3 lower and 3 upper. 3 are for the focus and 3 are for the screen
Mar 29, 2008 | Philips 51PP9200D Television
Can I have the part # for convergence ICs for Phillips TV Model 51pp9200D/37?
IC convergence number: STK392-120 or STK 392-150 Will work correctly. Any question, please let me know.
Aug 04, 2011 | Philips 51PP9200D Television
Philips projection HDTV 51PP9200D/37. Convergence problem
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 13, 2009 | Philips 51PP9200D Television
Philips 60p8342 chassy ptv 916
check all your solder connection and test the resistors on the conversion IC's , also check oscilating circuts
Oct 27, 2008 | Philips 60P8341 60" Rear Projection...
Sparking, popping
power house is fried these at times tend to go out but this time it might have had a little help animal or bug crossing or chewing on wires
i know alone on cost for the bulbs is around 300 to 400 dollars gotta estemate right around these odds for the power house price is around 200 parts and labor high voltage conductors
May 10, 2008 | Philips 51PP9200D Television
Popping, sparking, snapping
TV screen problems
convergnce IC are bad replace both of them that should straighten out your problem. But also check th resistors right next to th ICs as 1 or 2 of them may be oen as well
Mar 13, 2008 | Philips 51PP9200D Television
Philips 51PP9200D/37 not comming on
Check the site www.TvRepairKits.com. They have put together a couple of kits to fix the chirping set/dead set condition. If you don't see your model listed send them and email and they will build a parts kit for you.
Dec 11, 2007 | Philips 51PP9200D Television
Philips 55" rear proj. tv...55pp9352
those ic's are to be replaced with original parts..also suggest audio ic..john
Sep 11, 2007 | Philips 55PP9352 55" Projection Television
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
