Question about OTC Office Equipment & Supplies
Need owners manual otc 6490
I own a otc 6490 hub tamer set but do not have any paper work.
I need a operations manual for an OTC 3183 battery tester
Your OTC 3183 and Matco MD8300 is the same as the KAL8300 Digital Battery Tester Plus. Download the user manual in PDF format. http://tinyurl.com/jmj2jby
Sep 03, 2011 | OTC 3183 Digital Battery Tester
I Have a Magna Mountain tamer 15 speed bike and i need the manual for it.
i need an owners manual for a Magna Mountain tamer bike a 15 speed womens
May 28, 2011 | Cycling
Looking for the hub tool to take off front hub of 1989 suzuki sidekick
Without promoting anyone OTC makes a socket, Should be able to find one on their website or at least get a part number.
Jan 05, 2011 | 1989 Suzuki Sidekick
HOW DO I PRINT AN ENVELOPE ON A BROTHER MFC 6490 CW
the plastic indicater should slide back and forth to adjustr from paper to envelope
if you dont have the manual to figure this out , go to this link
http://www.brother-usa.com/mfc/modeldetail.aspx?productid=mfc6490cw
leave positive feedback for me please
Oct 16, 2010 | Brother MFC 6490CW InkJet Printer
HOW TO SET UP MFC-6490 TO SCAN 11 X 17 DOCUMENT
You will need to open the control center program which is installed when you install the printer on your computer.
Start, all programs, Brother, control center. Click on configuration then scan then file. There are two tabs at the top, change the paper size at bottom of each to ledger and press ok.
Jun 17, 2010 | Brother MFC 6490CW InkJet Printer
Ferroli otc settings
this sounds like the boiler is in comfort mode press the eco/comfort button once and eco will be dispalyed on LCD. also check terminal 3 and 4 have no wires on the terminal strip as this is were the OTC is connected to boiler.
May 02, 2010 | Heating & Cooling
How to remove routers for a for bronco 85 302 full sized
Removing rotors.
1. Jack up, put on jack stands and remove tire (obviously)
2. Remove caliper
3. Remove bolts holding locking hub body to hub
4. Remove snap ring from end of axle, Remove hub retainer ring from ID of wheel hub. Use a small screwdriver or pick to start it out of the groove. Remove the hub body
5. Remove the outer bearing lock nut, lock washer and the inner adjusting nut
You need the special socket for this OTC #7158 or similar
6. Remove the outer bearing and then the hub
7. To separate the rotor from the hub, use a soft faced hammer to drive the studs out
8. Turn the hub over and set the new rotor in place. Put the studs back in.
9. I will usually use an air hammer to drive the studs back in. Alternating in a circular pattern. If you don't have access, you can use a large diameter punch or another hammer on the back of the studs.
10. Now would be a good time to repack the bearings and replace the wheel seals. Pull the spindles and check the bearings and seals in the back of them. If they are not rusted, slab some grease on them and put back together.
11. Install the hub and rotor assy, and the outer bearing and bearing adjustment nut.
Apr 25, 2010 | 1985 Ford Bronco
Brother mfc-6490 printing crooked.. any ideas?
Could be paper feed rollers.
But first make sure the back cover is properly closed, and that the paper tray guides (width and length) are properly placed on tray for the paper to be snug.
Apr 15, 2010 | Brother MFC 6490CW InkJet Printer
151 people viewed this question
Top OTC Office Equipment & Supplies Experts
jasbo
jasbo
Are you an OTC Office Equipment and Supply Expert? Answer questions, earn points and help others
