Question about Westinghouse LTV-19W3 19 in. LCD Television
Westinghouse 19" Model ltv1937 will not turn on. Power source o.k. , cable good to secont tv.
  • 92 Answers
Check out the fuse on the power board. If you're not sure then replace the power board and it should resolve the problem
Posted on Jun 18, 2009
Westinghouse hdtv, model # dw39f1y1 Tv receiving no power when plugged in to a power source
Turn On & Has No Power & No Standby Light Troubleshooting & Repair - YouTube
please search for and view the above youtube video for power trouble shooting techniques. YouTube
Jan 01, 2018 | Westinghouse Televison & Video
My 19" Venturer TV will not turn on
  • 1 Check the antenna. Adjust it to see if the picture improves. Confirm that the antenna cable is firmly connected. Check to see that input cables are connected.
  • 2 Scroll through the channels to determine if the problem is specific to a station. Check any video sources (i.e. cable box). Make sure all cables are connected tightly.
  • 3 Check for interference. Power off all nearby devices one by one to see if any of them are creating the lines.
  • 4 Power off the TV for 30 minutes before turning it back on.
  • Mercedes Superchargers
    Jun 13, 2012 | Venturer 19 Class 720p LED LCD TV w/ DVD
    I have a Westinghouse W3223 TV which has decided not to turn on any more. It powers up just fine as always. But instead of showing the video input source before showing the picture, now it shows nothing...
    This going to be tough one to figure out, but at least the back light inverter board and power supply are working, unhook it at least 1/2 hour?
    You may have bad main logic board problem. Try reading my guide here and see how much the main baord may cost you.
    Please see my basic troubleshooting guide here:
    http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
    http://s807.photobucket.com/home/budm/allalbums
    http://en.wikipedia.org/wiki/Capacitor_plague
    Parts: www.shopjimmy.com
    Jun 25, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
    I have a 19" phillips lcd tv and when i turn the tv on the phillips screen comes up but when it is going the show the channel it shut off by itself how can i fix this problem?
    Hello. I may be able to assist you. If you are using a direct cable connection from the wall outlet;
    • Check the incoming cable or antenna signal connection to ensure that it is properly secured to the TV's antenna input.
    • If the connection is good, perform the automatic installation again to search for all available channels.
    If you are using a coaxial connection from the Cable or Satellite box to the TV;
    • Set the TV to the channel specified by the service provider.
    • Change the channels at the Cable or Satellite box to view the program.
    If you are using a video connection (CVBS, S-Video, YPbPr, HDMI) from the source (DVD, Cable or Satellite box) to the TV;
    • You do not need to perform automatic installation to search for the channels.
    • Press the 'SOURCE' 071218044349_22024.gif button on the remote control repeatedly to select the correct input source.
    If you are using an HDMI connection from the source (DVD, Cable or Satellite box) to the TV;
    1. Reset the TV and source by unplugging it from the power outlet for 30 seconds.
    2. Turn on the TV and press the play button on your source device. If the source is HDMI CEC compliant, the TV will automatically switch to the HDMI input.
    3. If your source is not HDMI CEC compliant, turn on the TV and switch to the HDMI input.
    4. Turn on your source.
    If you are sure you have selected the correct input or channel but still have no picture or sound;
    • Try resetting the TV by unplugging it from the power outlet for 30 seconds.
    • Press the 'SOURCE' 071218044349_22024.gif button to select the correct input source.
    • Check the connection cables.
    • Try the connected source with another TV.
    • Connect a different source on the same connection of your TV.
    Dec 14, 2009 | Televison & Video
    Tv just quit working
    This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
    Sep 11, 2009 | Emerson TS1997 19" TV
    Screen works for awhile but then goes blank.
    if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
    ekwhoward@yahoo.com.
    Thanks
    Ekow
    Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
    Westinghouse ltv-19w6 source won't change
    Have you tried to click the source button on the tv? It is the second button from the bottom on the right hand side of the screen.
    I doubt your tv/monitor is turning off, it just isn't getting any input. D-Sub is the "pc monitor part".
    Try clicking that button, give it sec, the hit it again. It will go through all of it inputs. If TV is what you are trying to find, it is directly after the Video input (green letters, top right hand side of the screen.) Keep hitting the button until TV shows up.
    Good Luck!
    Oct 23, 2007 | Westinghouse LTV-19W3 19 in. LCD...
    Tv source
    pull the back off the tv and plug in the cable for the input board. Its either not seated or came lose
    Oct 02, 2007 | Westinghouse LTV-19W3 19 in. LCD...
    Westinghouse LTV-19W3 19 in. LCD Television Logo
    510 people viewed this question
    Top Westinghouse Televison & Video Experts
    Jaime Hernandez
    Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
