Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Remove top lid hotpoint wd640
I need to remove top lid cannot find screws at the front of machine
  • 105 Answers
SOURCE: How to remove lid
usually after removing screws at back give the top a good push back or forward
there is a couple of pegs that lock into a keyway holding the front top in place
Posted on Jan 28, 2008
  • 90 Answers
SOURCE: How to remove top panel and front facia on a Hotpoint Aquarius WDF451 washing machine
Un plug it. There should be small screws either at the bottom of the panel on the front or there is separate panel that comes off the top back. If the back is one solid piece top to bottom, then the control panel lifts out and hinges up when the two small cross tip screws are removed from the bottom outside corners of the control panel..
Posted on Feb 10, 2008
barkencoa
  • 3463 Answers
SOURCE: I need to replace a door seal, Hotpoint Ultima WF860
Push the top cover to the rear and lift at the same time, then ease the control panel to the right, you will not get control panel off with the top cover in place.
This will then give you access to the front panel scews, located at the top and bottom of the panel. remove the door seal ,and door lock, then lift the front panel away.
Posted on Dec 04, 2008
  • 160 Answers
SOURCE: How to remove the top from a hotpoint WT940? 2
you need to give a sharp blow to the front of the lid towards the rear.. there are keyholed lugs holding it down in place... use you hand not a hammer...lol.. Thanks
Posted on Dec 18, 2009
Testimonial: "Thanks for that, I did manage to remove it. Although I pulled it from the back and removed some skin from my knuckle too...!!"
apart4u
  • 213 Answers
SOURCE: how to replace bearings
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our sitehttp://www.apart4u.co.uk
This first video shows you how to diagnose the problem
utube.png You-Tube video "kG5HWQ0x2s0" placeholder (do not delete) utube.png
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Posted on May 26, 2010
I cant get the back off hotpoint aquarius wma56 to change bearings
the back does not come off but the front does.
remove top lid ( two hex head screws on side of lid, under plastic covers)
take out dispenser drawer. reveils 3 screws
remove screws and slid front panel to the right (reveils 2 scrwes left and right)*
remove bottom kick strip ( reveils 2 more screws)*
undo door seal retainer, and remove 2 screws holding on door lock.
now remove 4 screws holding on front panel.*
panel now lifts up and off.
Jun 25, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
How do you refit a pump on a wd640?
Unplug the machine from the wall outlet,
Remove lower rear panel of washer. Locate the pump, remove the hoses onto the pump and disconnect the pump from the machine. Refit in the reverse order removal, making sure that all bolts, clamps and screws are tight. Check for leaks before refitting the cover.
Mar 13, 2011 | Hotpoint Aquarius WD640 Front Load...
Catch on door broken
VERY EASY FIX. REMOVE TOP OF MACHINE DISCONNECT SWITCH. REMOVE TWO SCREWS ON FRONT OF MACHINE. REPLACE SWITCH IS REVERSE. EASY. Parts are widely available, check sears or lowes or any other appliance dealer.
Dec 16, 2010 | Hotpoint Aquarius WD640 Front Load...
I have hotpoint aquarius wd640 washer/dryer and wondered how easy it is to replace the door seal
For most front-loaders:
Remove the top, screws behind the top lid. Slide an inch away from you & lift up. Remove old seal. Lubricate the slot which fits over the tub with washing-up fluid. Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange. When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. This is quite difficult and you may need another pair of hands. Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using. Use rinse to test as the water level is higher.
(There is no glue anywhere, only clamps,etc)
Pl rate me nice for the free help!
Mar 18, 2010 | Hotpoint Aquarius WD640 Front Load...
How do i get inside the Hotpoint Aquarius WD640 Front Load
The top cover can be removed by undoing screws at rear of cover, and sharply pushing forward on cover to remove.
The lower rear panel of washer is also removeable.
Jan 15, 2010 | Hotpoint Aquarius WD640 Front Load...
Wd540p hotpoint washer dryer is not drying clothes. Any ideas?
first of all, REMOVE PLUG from the wall socket.. remove the top lid off the machine and you will see the dryer element housing element in front of you. you will see thermostats on the housing, do a continuity test on these, replacing them will solve your problem. NEVER bypass these under ANY cicumstances
Oct 19, 2009 | Hotpoint Aquarius WD640 Front Load...
Hoptpoint Aquarius front load washer dryer wd640p
there are 2 screws round the back, take these out, lift the front of the lid slightly and bang the top to the rear to relaese it from the tabs.
the buttons are all plastic clipped in and can be removed and cleaned with care not to snap anything.
Dec 30, 2008 | Hotpoint Aquarius WD640 Front Load...
How to remove lid
Jan 18, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquarius 1000 deluxe W22 washing machine
the newer type motors have carbons tht are fixed in place you would need to remove the motor and on either side will be the carbons they need to be un-screwed to be replaced
Jan 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius wf 620
A fault code of F-01 normally refers to a short circuit in the control board. The best way to find out is to gain access to the service sheet located inside the machine.
Look at the back of the machine. Along the top there should be 2-4 screws the hold the top in place. Remove these screws and pull the top backward to release it from the front. Remove the top. The service sheet should be taped to one of the support arms.
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
46 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
