Question about Sony Playstation 3 (PS3) Console
I HAVE A PROBLEM WITH MY PS3 UPDATE, PLEASE HELP ME, I HAVE A DNS PROBLEM,PROBLEM WHERE DETECTED WHEN MY PS3 WAS DOWNLOADING UPDATES.  AND NOW MY PS3 CANNOT INSTALL UPDATES BECAUSE THIS IS NOT FULL VERSION, PLEASE SOMEBODY HELP ME AND TELL ME HOW TO INSTALL NEW PROGRAM IN MY PS3
    President:
  • 2,653 Answers
Can you still access the normal PS3 menu?
Posted on Jun 18, 2009
Nokia 3110 not gets connected to pc via usb,or in bluetooth.It shows some execution files missing.plzz help me.
The software on your mobile is corrupted, may be due to virus. Remove the memory card & scan for viruses by using card reader connected to PC. Then update the software straight to your phone, with no need for a PC. The software updates keeps your phone at its best. To update software without using PC - Select Menu - Settings - Phone - Phone Updates. - Select the update which you want to install.
- For downloading follow the instruction on the screen You can take the help of user guide for software update.After updating & restarting the phone should work.Tip: Always remember to scan your memory card for any viruses. Such problems occur due to downloading applications, data from unreliable sources especially GAMES.
Aug 12, 2011 | Nokia 3110 Cellular Phone
Internet connection failed during new download 2.42
Make sure that your PS3 is connected properly to your wireless network if you have a wireless router, because sometimes if your PS3 is not configure correctly to work with your network it will have this problem..
Hope that helps.......
Jul 30, 2008 | Sony Playstation 3 (PS3) Console
I have been tring to connect to wireless internet all day with my ps3 and it ethier says my WPA key may be incorrect or errorhas occurred (8013013D)
that is not a problem and i will be glad to assist you. If this doesnt work please follow up with a comment and i can give you instructions on what to do next.
This error code is caused by a connection time out when attempting to connect to the Domain Name Server (DNS). If you are seeing this code you should check the following: • Do you have a working internet connection (can you connect successfully using a PC)? • Reconfigure your network settings (delete existing settings and create new ones) • Does your Internet Service Provider (ISP) prohibit access to secure pages as a default setting? (this may lead to failures when accessing system software updates) • Within network settings, is the Primary DNS being detected? If the ‘Primary DNS’ is displayed as 0.0.0.0 or is blank, the DNS is not being detected automatically. If this is the case you should contact your ISP and ask for the ISP’s DNS address. This DNS address should then be manually input into your network settings. Following all of these steps your PS3 should now be able to get online.
to find your dns in windows > Start
> Run
> command
> ipconfig /all
Then the DNS Server(s) being at the bottom
If it still doesnt work let me know your router model number. Also ensure your WPA key is correct and that its not wpa2 as depending on the model most playstation 3's cant use wpa2. that way if you provide me with your router i can ensure that everything will work with each other and determine the best security settings to get your computer online
If you need further assistance or help with anything please let me know and i will be glad to guide you through any assistance you may need.
Aug 28, 2010 | Sony Playstation 3 (PS3) Console
PS3 error code downloading patches. Prior fix-ya advise inop. Need help fixing router problem. Conflict with Ps3.
0710102 - Error DNS, DNS server not available.
8001050B - Don't start demos on the hard disk when you have a Blu-Ray added. Unknown cause.
80010510 - Don't start games on your hard disk. Unknown cause.
8002b241 - DVI has no audio.
80028EA5 - Unknown.
80029023 - Exchange of key information timed out.
80029024 - The Attempt to obtain an IP address timed out.
80029564 - Game downloaded does not install. Unknown cause.
8002F997 - You cannot upgrade the XMB firmware.
8003051E - Game does not write.
80031150 - The settings are not be save. Possible System blue screen "Setting information is corrupted. Press the X button to repair and restore default".
80130203 - PS3 connects to the Internet, but not to the PSN. This could mean that the ports needed to connect to Store are not configured.
80710092 - "An error occurred. You were disconnected from the Playstation Network" - (the Internet connection lost?).
80710102 - PS3 can not start the connection with the information configured with the IP router. Try renice the router.
80710541 - The connection to the server timed out.
80710B23 - PSN is offline, or the PSN is too busy to respond.
80710D23 - Off the PS3 for a while (30 min) with the AC switch (not standby mode).
80029024 - "Could not get an IP address."
80028EA5 - Unknown - User cannot connect to PSN. Sony said user to take to get the PS3.
8002F997 - Trying to update the PS3 firmware, downloading the update file for USB and attempt to install failed.
80710016 - Playstation Network is offline.
8013013E - WEP keyError, replace WEP key for all the numbers and try again, or to replace WPA.
8013030F - Check page of the router, off SSID Broadcasting.
8002F994 - Many people are making downloading updates. Please try again later.
80028F10 - Go to Settings and choose presentation HDMI (or whatever your connection) and choose Auto, not Custom.
8002A705 - Unable to connect to. Server. Check the router settings doors.
80030920 - An error occurred during the copy operation. The file may be corrupt or there is a lot of memory. Try copy of its original location.
80010514 - total failure of the Bluray drive.
May 06, 2010 | Computers & Internet
Update failed when starting up brand new xbox!?
You can download updates to a cd rom,then try to update it that way,
Google, downloading updates to console.aspx.
Remember thumbs up if this helps.
Jan 29, 2010 | Microsoft Xbox 360 Console
No connection
I also think one or two of you may be trying to get your PS3 online without a router. I'm not sure why they don't tell you, when you first purchase a PS3, all the things you'll need to run your console with optimum settings. But you DO NEED A ROUTER! I know this may sound silly to some of you, but I've been asked this SO many times, that I have to clarify... A modem is NOT a router. These are seperate devices.
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
PS3 Game Updates not working
do you have the new firmware update 2.41?
Aug 29, 2008 | Sony Playstation 3 (PS3) Console
Random DNS Error
You may need to manually configure your PS3 connection on the console. Let's see.. I can suggest to first go to your Settings Menu -> Network Settings -> Choose:"Settings and Connection Status List" this will display a pretty detailed information about your connection to your local gateway (router).. Check specifically for Primary and Secondary DNS. In my experience, using the PS3's auto setup for the connection seems to enter the default gateway's ip (labeled "Default Router" on PS3 Status Screen) in place of the real DNS entries..
Question
: Sooo how do you check your primary/secondary DNS for your network? Answer: On your PC, open a web browser and enter your default gateway ip into the browser.. log into your router (assistance can be found in your router manual or by calling your router manufacture). You should see a status page of sorts that displays your ISP's primary/secondary DNS entries.. Simply transfer those two IPs to your PS3 manually to correct the DNS issue.
Hopefully that should resolve your issue!
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
try this
So what I found out was to put in the IP address you find in ipconfig/all but add one to the last octive. Example if yours is 172.16.1.25... then in your ps3 type in 172.16.1.26
Then I was using the primary and secondary DNS numbers that my computer was giving me in ipconfig/all. Do not use those. For your primary DNS number use the number for your default which should be a right below your subnet mask number. For the secondary DNS number just leave it blank. 0.0.0.0
Then you have to upgrade to version 1.50 (which just came out yesterday actually). Get a memory stick with at least 100mb space on it. Make a new folder that is names PS3. Inside that folder make another new one that is called UPDATE. Both must be in capitol letters. Then go to PlayStation.com - PLAYSTATION®3 - Network - updates and click on "download now"... Then click save and save it to your memory stick in the UPDATE file, which should be in your PS3 file.
Then after all is done... plug that into your ps3 in one of the USB ports for the controllers. In the main screen go to SETTINGS and then go to SYSTEM UPDATE. Go to UPDATE VIA STORAGE MEDIA. PS3 will search for your media stick and it should say on the screen The latest update data was found... Version 1.50. Click OK and follow the rest of the instructions. After it is completely done... go back to the internet connection setup and go through all the menus to make sure all your numbers are the same as I stated above. Then at the end run the connection test. It should work!
Jun 24, 2008 | Sony Playstation 3 (PS3) Console
Ps3
Download the system update from another place. Once the file on the PS3 is corrupted or incomplete it will only try that file.
You can install the system update using your PC by downloading the update to a USB stick or Memory Stick.
Get the system update here.
http://www.us.playstation.com/PS3/Network/Updates/pc_update.html
Dec 12, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
88 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
