Question about Konica Minolta Office Equipment & Supplies
C450 copie probleme - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,696 Answers
What is the problem???????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 10, 2016
Bizhub C450 strange printing problem. Green data LED is flashing but nothing happens.
Did you try to change the IP address of MFP. Please change IP address of MFP and connect the PC you are sure not giving any problem. If its works fine then connect rest of the remaining PC's
Nov 15, 2014 | Konica Minolta bizhub C450P Laser Printer
C450 copie probleme
what is the issue????
Apr 12, 2014 | Konica Minolta Office Equipment & Supplies
C450 blank copies
Does it print out a meter report OK? Does it make a copy? NOT A Print? I check the Xfer roller The sponge looking roller is the xfer belt OK (Shiny ) inside across from the sponge roller when cover is close. any P_ codes little oil can looking thing on the operation panel bottom
Feb 21, 2014 | Minolta bizhub 200 All-In-One Printer
How do i copy my contacts from phone to sim -Samsung sgh c450
goto contact menu then down the arrow copy contacts option
copy r move
Dec 05, 2013 | Motorola Mobility RAZR V3x Cellular Phone
Bizhub c450
On your printer settings on your computer when you select to print there should be a box that says only use black ink. Try that first and if it still prints in green you may have them in the wrong ports.
Aug 18, 2013 | Office Equipment & Supplies
Account Codes
Yes. Easy to do, just go into the admin mode under utilities. Turn on Copy Track and then setup your accounts. You can restrict color, number of copies etc. This is also in your operators manual.
The default admin password is 12345678
Good Luck
Apr 16, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Copy speed slow ( on bizhub c450 ) and show three angle shape
good luck
Description:
The machine copies very slow and well below the rated output for black and white and color.
Solution:
CAUSE: The machine memory is corrupt.
SOLUTION: Perform a data clear:
1. Browse to the NIC/Log on as Administrator/Select the Scan tab/Import Export and back up the one-touch addresses to the desktop.
2. Enter Tech Rep mode.
3. Select System 1.
4. Select Data Clear and press start. Wait for the machine to cycle OFF/ON and for the POWER OFF MACHINE WITH THE MAIN POWER SWITCH message.
5. Import the one-touch list back to the NIC.
6. Re-install the HDD and power the machine OFF/ON.
7. Reset the Marketing area to U.S. and the target to U.S.
8. Re-install the TCP/IP address and power the machine OFF/ON.
Sep 14, 2009 | Office Equipment & Supplies
KONICA MINOLTA C450 VXL Printer - When stapling multiple copies it staples all the copies together rather than each one separately as required. I use vista operating system.
There is an issue with the Konica Print Driver and the MS Print Driver. If Collate is turned on in both the drivers, you will get this problem.
The solution is to turn off Collate on one of the Drivers. Usually you will have an initial Print Dialog window that pops up when you can select your printer, how many copies and if to collate or not. De-select Collate. Then you should also see Preferences Tab. If you select that tab, select Collate and Staple, your print jobs should now Collate and Staple correctly.
Jul 23, 2008 | Office Equipment & Supplies
DVD player does not play
Display of my DAV C450 does not work
Jan 13, 2008 | Sony DAV-C450 System
16 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
