Question about Garmin GPSMAP 298 GPS Receiver
Says transducer is disconnected - Garmin GPSMAP 298 GPS Receiver
Installing transducer
I assume you're talking about a transom mount transducer. Best if the leading edge of the transducer is even/level with the hull and tilts slightly down in the back or trailing edge of the transducer. Also try to eliminate a gap between the leading edge of the transducer and the hull.
Mar 25, 2014 | Hummingbird Boating
Transducer Error
You either have a fault in the head unit, connection to the transducer, broken wire in the transducer cable, or a faulty transducer.
Jul 20, 2013 | GPS
Garmin 4208 Marine Transducer Problem
You either have a faulty head unit, bad connection between the transducer and head unit, or a faulty transducer or transduced cable.
Jul 19, 2013 | Garmin GPS
I have been getting a F1 error for months now and have restart my cycle 3 to 5 times a wash. I heard this is a common problem with this model is it a recall? what do I do
Thank you for your question.
The F1 fault code on this washer indicates that the water level pressure transducer signal is out of range. The pressure transducer air hose tubing being pinched or crimped can cause this. A failed pressure transducer on the machine control board can also cause it.
The first image below shows the method for accessing the pressure transducer tube that runs from the bottom of the washer tub to the machine control. I recommend checking this air hose for pinches, twists or crimps.NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
If you find no problems with the pressure transducer tube, then the machine control board will need to be replaced.
Jan 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore elite, oasis, model # 110.2703, at exactly 19 min left, at the starting of the rinse cycle it flashes the F1 code, i push stop then start untill it stays on, usually takes about 4-5 trys
If you find no problems with the pressure transducer tube, then the machine control board will need to be replaced. The procedure for accessing and replacing the machine control board is shown in the second image below.
Jan 09, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis washer, top load that flashes F1 at the rinse cycle, what part do i need to fix this???
If you find no problems with the pressure transducer tube, then the machine control board will need to be replaced. The procedure for accessing and replacing the machine control board is shown in the second image below. The part number for the machine control board is W10189966.
Image 1
Image 2
Jan 09, 2011 | Kenmore Washing Machines
One of the drum pads is disconnected. when i touch the wires it still makes a sound, but i can't seem to refit the pad into its place and it still functon
You might try taking the pad apart to see if the piezo transducer has come loose or if there is a bad connection at the transducer or the jack.
Aug 12, 2009 | Music
How do you replace egr valve in a 2005 dodge caravan
REMOVAL - 2.4L The EGR valve and Electrical EGR Transducer are serviced as an assembly.
  1. Disconnect vacuum tube from electric EGR transducer. Inspect vacuum tube for damage.
  2. Remove electrical connector from solenoid.
  3. Remove EGR tube bolts from EGR valve.
  4. Remove EGR valve from cylinder head adaptor.
  5. Clean gasket surface and discard old gasket. Check for any signs of leakage or cracked surfaces. Repair or replace as necessary
INSTALLATION - 2.4L The EGR valve and Electrical EGR Transducer are serviced as an assembly.
  1. Assemble EGR valve with new gasket onto the cylinder head adaptor.
  2. Loose assemble the bolts from EGR valve to EGR tube.
  3. Loose assemble the bolts from EGR valve to cylinder head.
  4. Tighten bolts from EGR valve to cylinder head to 22.8 N·m (200 ±25 in. lbs.) torque.
  5. Tighten bolts from EGR valve to EGR tube to 11.9 N·m (105 ±20 in. lbs.) torque.
  6. Reconnect vacuum hose and electrical connector to electrical EGR transducer.
Aug 03, 2008 | 2007 Dodge Caravan SXT Minivan New Cars
Depth Sounder does not display depth
I will see if I can get mine off the hull for testing. Still have found no procedure. Thinking about just replacing the sounder with another unit.
Jul 05, 2008 | Garmin 185 Sounder GPS Receiver
Transducer
I have the exact same problem. Were you able to solve your problem???
May 12, 2008 | Garmin GPSMAP 3210 GPS Receiver
Open Questions:
See all Garmin GPSMAP 298 GPS Receiver Questions
Garmin GPSMAP  298 GPS Receiver Logo
15 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
