Question about Samsung LTN1535 15 in. HD-Ready LCD Television
Single vertical blue line - Samsung LTN1535 15 in. HD-Ready LCD Television
I have a single blue line in the middle of the screen
Is the problem with your flat panel ?
or flat crt tv ?
In the cause crt tv, there is the problem with vertical deflection driver IC or vertical deflection coils (some times called YOKE).
In cause of flat panel tv, there is the problem with the panel, the panel may be broken.
May 04, 2016 | Televison & Video
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
My Samsung TV developed a a single blue vertical line on the left side. what could possibly cause that.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name and type (TV, VCR, DVD player etc:) of your device, in the search box [at the top right] of the home page. It will make surf easy.
Jun 13, 2015 | Samsung UA-40H5500 40" Full HD Smart...
2 thin vertical blue lines, near center and right side. Do i need to replace LRC buffer boards. Z50p3 50 in plasma.
By thin line I assume its one pixel in width. A single pixel wide line is an indicator of a defective panel.
Oct 30, 2013 | Zenith Z50P3 50 in. Plasma TV
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
Power light starts blinking
replace the vertical ic.having single line is a sign that your vertical ic is need to replace.if the power indicator is blinking is also a sign of defective vertical ic
Feb 06, 2008 | Toshiba 27AF41 27" TV
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
Philips Flat Screen Green Lines
The LCD Panel is defective. You will need to replace the LCD Panel. It will probably be cheaper to replace the monitor since the LCD Panel may exceed the monitor cost.
Single lines of single color (red,green, blue) are LCD panel failures.
1 or 2 lines of single color are LCD Panel failures.
Multple color lines could be anything so in this case you start by checking the power circuit.
Nov 28, 2007 | Philips 20 in. TV/VCR/DVD Combo Flat...
Samsung LTN1535 15 in. HD-Ready LCD Television Logo
24 people viewed this question
Henry  Thomas
Henry Thomas
