Question about Samsung MU3250W Microwave Oven
I have a Samsung MU3250W microwave that will not work. It lights up 8888 on the display screen when you plug it in. I have pushed the pause/cancel button but nothing happens. You can not get the 8888 of the screen. The light will come on when you open the door. Any suggestions?
  • ashleysloan Jun 18, 2009
    The fuse is fine. So would that mean the the control board needs to be replaced. Could there be a problem with the key pad that would cause this to happen?
    President:
  • 1,197 Answers
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
if its all fine... then ur control board might have shorted....... u might have to look for replacements for any burnt capacitors or may be even the entire board......
i strongly feel its the humidity.....
if u feel i ve been of help to u..... kindly rate my service......
good luck......
Posted on Jun 18, 2009
    Genius:
  • 1,689 Answers
Hi ashley,
the issue on the your unit is the control board, you may have a blown fuse or a blown up capacitor that sets the display to 88888.
When you open the unit from the back, you will see a bubbled capacitor in the control board itself or a blown up fuse near the power supply. You can have this repaired or part replaced by an authorized dealer.
hope this helps.
regards,
voodoo
How many watts in samsung mu3250w microwave
It's 950 watts.... back of unit says .95kw.... do the conversion ;)
May 13, 2014 | Samsung MU3250W Microwave Oven
Sumsung MU3250W shut down
The problem is your magnetron tube is leaking RF. The mag tube comes on 2-3 seconds after you hit start, and the RF interfears with the board and shuts it down. Drop the front of the control panel down and watch, it wont happen.. Get a new mag tube put in and you'll be good to go.
Oct 19, 2008 | Samsung MU3250W Microwave Oven
Tappan microwave has se or 5e on diplay wont push buttons
this a problem a dust in the control board keypads, You must open the keypad, and clean any connector with contact cleaner specially the ribbon cable or plastic and use pencil eraser for to fix the corrosion, dust, and try again.
Jul 08, 2013 | Microwave Ovens
Samsung microwave displays 8888 beeps then 6666
how can i fix this problem i have an air conditioner whit the same problem and don t work please help me here are very hot
Jun 20, 2012 | Microwave Ovens
?E - 5" message
From Samsung's FAQs:
"Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
"Other microwaves do not give specific error messages and just display "8888" on the LED. If you get this error message, your microwave needs service.
"If the message is either ERROR or E-6, it indicates a mechanical fault.
"For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locator to find your nearest Authorized Service Center."
Or instead let us know if we can help further.
Aug 22, 2010 | Samsung MU3050 Microwave Oven
Microwave wont heat up food
Could be the magnatron at fault.......Cheaper to renew..
Jun 06, 2010 | Samsung MU3250W Microwave Oven
Samsung microwave -the electrical panel runs, the
it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Nov 14, 2009 | Samsung MU3250W Microwave Oven
Samsung MU3250W Shut down
Good luck.
Quit working
SE probably means a sensor error.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Otherwise, it may have a problem with the control panelm such as moisture or contamination or a bad connection.
Let us know if the hard reset doen't fix it, and please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 12, 2007 | Samsung SMH7178STD Microwave Oven
Intermittent keypad operation
A new keypad is not difficult to install, and can be worthwhile.
It's part # DE34-10139B and you can get one for $18.71 plus shipping from http://www.samsungparts.com
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
We're able to install them for folks who don't want to do it themselves.
Nov 26, 2007 | Samsung MU3250W Microwave Oven
Samsung MU3250W Microwave Oven Logo
170 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
