Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
TV froze during update. How do complete update?
We tried to update netflix on our 70 in Aquos LC-70EQ10U TV. It froze at 67%. We cannot turn the tv off or use the remote.
swami nathan
  • 208 Answers
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Posted on Sep 28, 2008
SOURCE: Programming the Acquos Remote
I got a a sharp LC-32D43U and for my motorola cable box i use hte code 31 from jerrold, i take it from the manual and i got it tryin every single code unti i get one that works.
Hope it works for you
Posted on Oct 21, 2008
SOURCE: Sharp Aquos LC-30HV4U
replace the supply board
or repair it *** there's problem with supply
Posted on Nov 11, 2008
Input code 0093 into your Comcast remote. Here's a link for the how to: http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_dvr_remote_manual.pdf
Posted on Mar 01, 2009
  • 73 Answers
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Posted on Sep 27, 2009
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Why did it freeze during software update?
Here is some help on a Sharp Aquos. You pull the plug and update manually.
Sharp Aquos Firmware Update Issue and Resolution I recently had problems with my Sharp Aquos LC-60LE632U and firmware update 311U1204061. When I attempted to run the Netflix app, I was told that I couldn't proceed unless I updated the firmware. After 2 attempts to update the firmware via the network, I turned to Google and found that this was a common problem. In order to resolve the issue, you'll need to update the firmware manually, via a USB thumb drive. See the following instructions:
  1. Go to the Sharp USA product download site
  2. After you choose your TV model, download the firmware file
  3. View the rest of the instructions found here
Info found here
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/1436990-sharp-aquos-frozen-when-updating-software.html
Oct 03, 2015 | Televison & Video
My tv turns itself off and on every few minutes. I was able to update the software, which seemed to correct the problem. I turned off the tv and came back later and the problem is back
Sounds like the timer is set . Unplug it and then hold the power button in for 30 seconds . Plug it back in & power it on . Try the menu or input button . Or try tuning the TV on last after your other devices like cable , dvd ect .
Good luck !
Jun 21, 2015 | Sharp LC 70UD27U 70 Inch Aquos Ultra
Tv will not turn on
replace fuse in back or power board
Jun 11, 2015 | Sharp LC-70LE847U 70 inch 240hz Wifi AQUOS...
The tv froze up while watching netflix and won't turn off or do anything
Sounds like the CPU froze. Unplug set from power completely, then plug back in, should work. If not then the problem will have to be solved by a repair technician.
Mar 12, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
Have just bought a 70"
Hi, If you just have your Bose system connected with a fiber optic " TOSLINK " coming from the televisions digital output this will surely fix the problem. I am assuming of course you have some sort of HDMI connection. The T.V. may now interpret this as some sort of sharing violation while "STREAMING " from Netflix. If that is how you have the t.v. connected you may want to disconnect the hdmi while listening to a Netflix movie through the bose. That should take care of the conflict. Thanks for coming to FixYa,I hope this helped,good luck Prodzilla
Apr 15, 2011 | Audio Players & Recorders
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
26 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
