Question about Hisense Televison & Video
Stuck in headphone mode - Hisense Televison & Video
When I call someone on my Iphone 5, they cannot hear me. What do I do
Check to see if your phone is stuck in headphones mode. Clean out the headphone port if it is, and plug in some headphones a few times. iPhone 6 Can Hear Caller Fix
Feb 09, 2016 | Apple iPhone 5
Turning off
I got a DAV system that had exactly the same problem, ie. it was stuck in "headphone mode", this mode should be active when headphones are attached then it should revert to amplifier mode when the headphones are removed.
I opened the cover and removed the amplifier output board (the one where the speaker wires connect to) and soldered the following dry joints.
1) large brown capacitor on the amp output board.
2) dry joints on the rear headphone socket (the one that has the connecting lead from the front headphone socket)
3) Then one of the surround channels didn't work so I soldered further dry joints on all the coils (white vertical rectangular blocks)
I tested all surround chanels before putting the lid back on (careful, watch the mains) and found all was now working ok.
Mar 11, 2008 | Sony DAV-S500 System
My technics integrated receiver su-g75 is stuck in
The headphone jack is stuck, something got in there. Probably have to take it apart, but it might be a piece of a plug. Use flashlight...
Aug 28, 2014 | Audio Players & Recorders
There should be a cable going to the headphone pcb. If you unplug that cable, it should clear the false h/p detection that is happening. Of course, you won't be able to use the headphones then. To completely fix it, you would have to replace the headphone jack.
Jun 19, 2013 | Yamaha Audio Players & Recorders
AV-R730 stuck in headphone mode?
Try a quick blast of compressed air into the headphone jack area. Worked great for me.
Apr 14, 2013 | Samsung Av-r730 A/v Surround Receiver...
Stuck in HP 2CH
one of the transistors seem to have been installed in the wrong direction.if it is working it will blow off again As for the remote , it works via a separate circuit.
Feb 05, 2008 | Sony STR-DE597 Receiver
Televison & Video Logo
21 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
