Question about Bosch Ascenta Series WAP24200UC 24" Front-Load Washer with 2.2 cu. ft. Capacity, 15 Wash Programs, S
Bosch customer support
Washer wont start keeps blinking the key and END
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
Can't get a Bosch MAXX 5 WAA24161GB to start. Changed fuse and socket, but machine still won't work?
hello, have you checked the glass fuse inside the washer make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Mar 06, 2011 | Bosch Washing Machines
Bosch classic 1200 key sign showing and just bleeps wont start wash
To start a cycle when the child lock has been activated you have to keep the start button pressed for a least 5 secs. Check your user manual for deactivation of child lock.
If you don't have the manual, use the link to download a copy, you will need the Enr number from the sticker on the inner door.
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Oct 19, 2010 | Bosch Washing Machines
Machine has a flashing key sign and won't start wash cycle - t
You have probably inadvertently activated the child lock. You can start a cycle still, but you will need to hold the start button for approx 5 secs. Check you user guide for deactivation instruction.
use link to get manual if needed
Jul 13, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1400 express key symbol
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Apr 06, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx6 1200 express
my classixx6 1200 express is flashing f21? what is wrong with it?
May 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Ascenta Series WAP24200UC 24" Front-Load Washer with 2.2 cu. ft. Capacity, 15 Wash Programs, S Logo
24 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
