Question about Carrier 42qh12 b-h/38qh12b-h 12000 btu split air conditioner for 220 v
42qpc18h 9 flashing ERROR - Carrier 42qh12 b-h/38qh12b-h 12000 btu split air conditioner for 220 v
What does error message number 9 mean on my kymco mini s mobility scooter?
hi, it's a controller trip error message this can mean a bad connection or at worse a controller fault ...
Regards
Rob
May 05, 2014 | Health & Beauty
Getting an error code of flashing 9 times then pause then flashing
Pride Mobility Products Corp Product Owners Manuals Specification Sheets Click on "Celebrity X"
9-flash usually indicates a blown controller. The larger pride scooters are known for blowing controllers and having melt-downs when they are pushed or towed too fast. EVEN WITH THE KEY OFF the controller still monitors the safety systems. If the system detects a "roll-away" situation, the controllers turn on and go into dynamic braking mode in attempt to slow or stop the scooter. If the scooter is being towed or pushed and this happens, the scooter tries to stop the motion, overheats and burns up. Catastrophic failure and 9-flashes will result.
Best regards
Mar 16, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
Krups ea 8010
Error code 9 is temperature detected as too high or too low. Check NTC on boiler
NTC fault (component, bonding, connector, wires...)
Coffee leakage on NTC (resistor value)
Jan 15, 2014 | Krups Coffee Makers & Espresso Machines
Flashing wrench 9 times
Lester - so many issues. Take it to a dealer.
9-Flashes means comm fault - check joystick wiring harness.
Nov 01, 2013 | Electric Mobility Invacare Pronto M41...
Won't turn on, light flashed 9 times
the 9 blinks is indicating a panel SOS which means the Panel itself is whats causing the 9 blink error code.
Mar 24, 2012 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Sony KP51ws520
9 times blink shows Audio Error in your TV.
Let me know if you want to fix it by yourself.
Feb 21, 2009 | Sony KP-51WS500 51" Rear Projection...
Can't get Adobe Flash Player 9 ActiveX.exe to download.
Flash player 9 is actually not the latest version. If you want to install the latest version which is version 10, follow the steps below:
a. Download the most recent Flash Player uninstaller to your desktop from the TechNote below. Please read the instructions in the TechNote before running the uninstaller.
How to uninstall the Adobe Flash Player plug-in and ActiveX control
http://www.adobe.com/go/tn_14157
b. Quit ALL running applications, including all Internet Explorer windows, other browser windows, AOL Instant Messenger, Yahoo Messenger, MSN Messenger or other messengers. Check the Windows system tray carefully to make certain no applications which might possibly use Flash Player is still in memory.
c. Open the following folder: C:\WINDOWS\system32\Macromed\Flash
d. Run Flash Player uninstaller.
e. Check if there are files left in the folder: C:\WINDOWS\system32\Macromed\Flash. If there are any files left inside the folder, delete the files.
f. Download and install the latest Flash player at:
Flash Player 10,0,12,36 Active X (for Internet explorer)
http://tinyurl.com/67twte
Flash Player 10,0,12,36 Plug-In (for Firefox,Netscape,Safari,Chrome,etc)
http://tinyurl.com/8nz9s
Feb 03, 2009 | 2000 Ford Windstar
My Sony BRAVIA KDL52XBR2 Television Standby flashed 9 times
9 flashes indicates a panel error, either the panel itself or the TCON board is bad. the solution is the same for both, replace the panel (the TCON board is supplied with the panel). I daresay the cost of the part would exceed the value of the TV
Sep 25, 2008 | Sony BRAVIA KDL52XBR2 Television
I can't download Flashplayer
Sounds like you may have some registry errors, download a registry repair utility, such as Registry Mechanic or PC Pitstop Optimize.
Oct 07, 2007 | Macromedia Flash MX
Carrier 42qh12 b-h/38qh12b-h 12000 btu split air conditioner for 220 v Logo
56 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
