Question about Canon Rebel XT / EOS 350D Digital Camera
How do I recent my Canon Digital Camera?
My camera got dropped. =( and it shos up as an error, with a black screen and it tells me to reset my camera, well, i cant figure out how to do that, as it wont let me use the camera, i hooked it up to my computer but the same problem occurs, the lens wont retract and thats the problem, is there a solution???
To reset factory defaults. Turn the dial to P (program). Turn on the camera. Hit the menu key. You will now see the extended menus. (if you don't turn to P you only get basic menu). Go to the last tab which is the second tools menu. Look down the menu and you'll see a "clear settings." Select this and you have two choices "clear all camera settings" and "clear all custom functions." Select "clear all camera settings." The "clear all custom functions" only applies if you've created custom functions which few people do. I hope this helps.
Posted on Jun 21, 2009
    Sergeant:
  • 321 Answers
Ur cam got damage it need service
Posted on Jun 18, 2009
Canon G5 Powershot LCD screen is black and will not show images in any setting.
Are you sure the battery is ok? Did you press the button display (bottom right nest to the display) several times? Next, how long did you not use this camera? If it was for long, something inside could be corroded. Did you recently drop the camera? Something more serious could be wrong. I'm not sure you can make any picture, because you don't need the screen to make a picture. You then could look is a proper picture is on the memory card. If the rest of the camera is working ok the viewing must work also. Check is the off button is moving correct. (And not blocked) Resetting could be an option, but you need the display to answer the question. This is in the user manual.
Oct 23, 2013 | Canon PowerShot G5 Digital Camera
Dropped Canon - Display Broken
Repair expensive, if possible. Replacement best option.
May 25, 2017 | Canon PowerShot SD600 Digital Camera
Blank screen on Canon Powershot S2is camera
hi.if you are telling both viewfinder and lcd are blank or black the problem is in the shutter that you found inside of the lens are not open.sometimes the cuase of the is humidity or moist goin inside of the shutter thats why it will not work properly or stuck up.if you can open your camera and adjust the shuuter from lens unit its better .but if not its better you bring to service center and request for adjustment.
by the way try also to reset your camera to default setting maybe it will help you.
thank you
Jul 08, 2010 | Canon PowerShot S2 IS Digital Camera
Oops! dropped camera. camera will not activate, black screen, "Lens error, restart camera.
black screen, no image formation,shutter is defective.if not allienment of the lens unit to the mother board.so take it to camera tec.
Mar 07, 2010 | Canon PowerShot SD1100 IS Digital Camera
My Canon Power Shot A80 Digital camera goes ON but only shows the screen name Canon then the lens goes back into off - some sounds come on and then E18 shows in the lower left of a black screen. Help.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 09, 2009 | Canon PowerShot A80 Digital Camera
Canon Power Shot SD 400 Digital Elph - image not on screen
On most canon elph cameras you can either go through the menu and reset back to factory default and this might solve the black or white screen. If that does not work you should be able to hold the menu button down for several seconds until a reset prompt pops up. You will then click on yes for reset and this should completely reset the camera and the screen should be back to normal.
Jun 10, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera was dropped-- "Lens error-restart camera" message
If it is still under warranty , please repair it.
If it is out of warranty. Try to get a quote, it the quote is more than 50% of original value , forget it.
For digital camera's they die like flies. New ones are better and cheaper anyway.
Mar 22, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
My Canon Power Shot S2 1S will not take pictures because the lens will not go back in or out. The screen is black unless I review recent pictures
Do you get an E18 error? If so, then the lens motor is bad, or you have contamination in the gears (sand, dirt, etc), or mechanical failure from dropping the camera. This will require repair by Canon or other camera repair services.
Jan 17, 2009 | Canon PowerShot S2 IS Digital Camera
E18
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
It's important that you fix the E18 error first, as the blur of colors may be symproms of a failing CCD. If so, Canon would fix this for you for free IF the camera has no other problems (ie no E18 lens error). Please see the following info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
May 27, 2008 | Canon PowerShot A70 Digital Camera
Lens Error
Remove battery for a minute or two then reinsert and try
If the problem persists recharge the battery fully
Then try if it still persists then there is a possible fault and you should return it to the vendor if under warranty ot contact Canon if out of warranty
Be warned if out of warranty your likely looking buying a new camera
Jan 24, 2008 | Canon PowerShot SD600 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
294 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
