Question about VOX Amplification Vox VT40+ Valvetronix Guitar Combo Amplifier (40 Watts, 1x10 in.)
Vox vt40 factory reset - VOX Amplification Vox VT40+ Valvetronix Guitar Combo Amplifier (40 Watts, 1x10 in.)
    New Friend:
Consider reading the Manual for this amp, it explains how to reset to factory with the VFS5 footpedal. Or with the power off ..hold down CH1 & CH4 then turn power on.. when the Bank & Channel leds start blinking.. then release the Channel buttons. Next press the Tap switch ... the bank & channel leds will change from blinking to lit. with in a few seconds it will enter preset mode.
Posted on Mar 07, 2015
I have a vox vt40 and the light for the power comes on bit there is no sound. I talked to someone with the same amp and they said there is a clip that switches on the tube that tends to go out with this...
If your amp isn't producing signal, your best bet is to take it into a local Vox autorized repair shop. There are leathel voltages involved and if you're not an experienced tech, you can get hurt, not to mention screwing to amp up worse. Here's a link to the Vox contact page http://www.voxamps.com/contactus
And one to find the list of Vox repair shops.
Korg USA Musical Instruments
Feb 11, 2015 | VOX Music
Is it possible to lower the VOX VT50 transfo outgoing voltage?
bulbs have tolerance, that means it can work with + or - 6.3v just use the 7.6v which a diffrence of 1.is ok for it to work.
Jun 27, 2014 | VOX Amplification Vox Valvetronix VT50...
Vox vt40+
that is because it is two different output channels. eventually you will blow the speaker or your amp. It wasn't designed to handle the impedance of an external speaker through the stereo
headphone jack. Are you sure that your speaker is hooked up or plugged in?
Mar 30, 2014 | VOX Amplification Vox VT40+ Valvetronix...
I have a vox valvetronic 50, which keeps blowing fuses as soon as it is switched on and leaves a burning smell. any ideas?
One or more parts in the power supply section is defective. I would recommend taking/sending the unit to a repair depot.
Oct 20, 2013 | VOX Amplification Vox VT30 Valvetronix...
Vox Tonelab LE. One of black buttons on my unit has got damaged and pushed under the metal casing so it is permanently pushed down. (Used to set preset values). Has anyone got a procedure for taking this...
Hi it could be that the switch has failed if it is something you are not confident with ask an independent electronics repair shop for some help. Sorry I cannot help more but I cannot see how the switch can be seized in the on (Depressed) position.
Dec 21, 2017 | VOX Amplification Vox Valvetronix Tonelab...
Vox vt120+ cutting out and then coming back on. even when the jack lead is not in the jack input. the fuses all seem ok.
i live in mexico and musics stores here sucks I'm an engineer and y started experimenting i think its an IC the TAS5615 im about to order it but does anyone know for sure what it could be??
Sep 28, 2011 | VOX Amplification Vox VT20+ Valvetronix...
I have a VOX AC15C1 amp and bought a VFS2A foot switch. The foot switch right LED did not come on and I sent it back for a replacement. The replacement foot switch came and the right channel seems not to...
That supposedly is the correct footswitch for the amp... there may be a defect in the amp. Contact the factory support about this problem. Make sure you are FULLY plugging in the plug as SOMETIMES they feel like they are clear in but they are not.
Sep 19, 2011 | VOX VFS2A
I have a VOX NT15. When switched to Triode ( 7,5 W ) mode, my amp generates quite loud buzzing sound. The loudness of this sound is on the same level, no matter if the volume is switched to minimum or...
You LIKELY have a bad filter capacitor. The additional load of the Triode load is probably dragging the supply causing flattopping and the power supply ripple frequency to come through. Have the unit serviced.
Jul 26, 2011 | VOX Amplification Vox Night Train Amp Head
VOX Amplification Vox VT40+ Valvetronix Guitar Combo Amplifier (40 Watts, 1x10 in.) Logo
919 people viewed this question
Top VOX Music Experts
rhodesworks
David
David
Are you a VOX Music Expert? Answer questions, earn points and help others
