Question about Hotpoint WMA58 Front Load Washer
Want to remove top of my hotpoint wf860 waschine
Need to take top off my washer because there is something stuck inside
gittos73
  • 244 Answers
SOURCE: hotpoint wf860
not sure about the f04 code but if its still full of water try putting the washer onto a drain cycle if the water does not drain then your pump is either blocked or faulty to check if its faulty pull the washer outnow take the drain hose and place into a bucket low to the floor if it comes straight out then the pump is faulty what it is is they have a magnectic part which goes down if the water doesnt come out its blocked you will have to take the washer outside tip it backwards but dont put it on its back now undue the sump hose which is situated in the centre of the drum pull it the water will drain out now undue the 2screws under the pump pull out undue the pipes you should see the blockedge if not could be in the drain hose itself m8 let me know how you go on if the pump needs replacing shouldnt cost no more than £20
Posted on Nov 17, 2007
  • 27 Answers
SOURCE: HOTPOINT ULTIMA WF860
H2O means the applionce isnt getting enugh water but it sounds to me like youre waste hose is to far down your stand pipe it should be in no more than 4 inches and also make sure you are connected to the cold feed not the hot
Posted on Feb 22, 2008
  • 4 Answers
SOURCE: Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Posted on Apr 17, 2009
  • 16 Answers
SOURCE: where is the filter on a hotpoint wf860 washer
The filter is underneath the drum, inside the rubber that exits the drum down to the pump
Posted on Aug 25, 2009
Testimonial: "thanks for a prompt answer "
barkencoa
  • 3463 Answers
SOURCE: hotpoint wf860 door wont open
Lay drain hose down, and drain it into a bowl or bucket, if door still does not open, then you have another prob.
Please rate my solution.
Thanks.
Posted on Sep 13, 2009
How do I get to the drum of my washing machine
WITH GREAT DIFFICULTY, IT TAKES AN HOUR TO STRIP A MACHINE. WOULD BE ADVISABLE TO GET A CHEAP REPAIR MAN IN
Dec 27, 2013 | Hotpoint Ultima WF860 Front Load Washer
Wot does code F-05 mean on a hotpoint ultima washer mean?
It means water level switch jammed on full.
You need to check and clean pump filter.
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose
Reassemble and water test..
Feb 15, 2011 | Hotpoint Ultima WF860 Front Load Washer
Can I replace the rubber drum seal on my Hotpoint WF860 myself, if so where can I get one?
ebay best place very easy to change if you remove the spring on the seal on the front of the machine you can get to the clip to take of the inside you can take off the lid to get to it from the top thankyou
Jan 21, 2011 | Hotpoint Ultima WF860 Front Load Washer
Where is the filter on a hoitpoint ultima wf860
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter is under the rear of the machine inside the sump hose. Remove the lower rear inspection panel and tilt the machine forward, keep it tilted by placing a tin of peas or something under it at the rear. Now put a shallow bowl or dish under the sump to catch any water that may still be it the drum and remove the retaining clip. Pull the hose free from the tub and the filter is inside. (Work safe and remove the power plug from the wall before commencing any repair) For more tips on repairs use this link selfix-uk
Mar 11, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint WF860, one of the blue/green bars on the inside of the drum has broken and come off. Do you this part? Thanks. Ruth
Hi.
You need to order the part from Hotpoint direct, or through one of the local dealers who sell spare parts for washers.
The hotpoint address is>>>>
WWW.HOTPOINTSERVICE.CO.UK
Click on SPARES
.Please rate my solution.
Thankyou
Jan 27, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 pump obstruction. How do I get to pump?
Locate and remove the large black hose fastened to the bottom of the drum.
Remove and clean the plastic filter inside the hose.
Remove the hose onto the pump, and check for blockage or obstruction here and in the pump.
Thisn should the problem.
Good luck.
Dec 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Changing door seal on hotpoint ultima washing machine
hello if you take the top off the washer and look down inside you should see a metal ring with long screw and nut unscrew this so it's loose you should be able to pull the seal off .then on the front of the washer where the next part of the seal is theres another rmetal thin bit of wire . unscrew the platic clip and the wire should come off. then just pull the seal out of the washer and when you put the new seal on fit it the same way you took it off good luck ps get back to me if you get stuck
shaun
Sep 06, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wf860
f12 is an electrical connection problem between the 2 circuit boards of the machine. it may be a loose connection or more likely a new power board required.
Feb 22, 2009 | Hotpoint Ultima WF860 Front Load Washer
Wf860 door seal
un-plug the washer take the lid off now open the door undue the clasp that goes around the rim of the door seal on the outside of the washer (look carefully) once done the door seal should push into the washer now if u look into the washer from the top at the front though u will see a another clasp going around the door seal on the inside of the washer this is a screw un-screw it once done then the door seal should pull out repeat backwards to replace it m8
Apr 27, 2008 | Hotpoint Ultima WF860 Front Load Washer
WF860 Door stuck in closed position.
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Dec 17, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMA58 Front Load Washer Logo
13 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
