Diagram of motherboard wanted
I want to upgrade my cyrix and connect to an ethernet rj-45 connection. where is the slot on the motherboard?please
    Brigadier General:
  • 6,966 Answers
Based on your post/description, you would want to do 2 things: 1) upgrade a Cyrix and 2) install LAN capability.
#2 is easier, all you need is a PCI LAN card with the right drivers for your operating system and you should be set to go;
#1 is trickier...
If you are referring to a Cyrix MediaGXm motherboard, at most that you can go up to is a 300 MHz CPU and hopefully a max of 256Mb of memory depending on the motherboard version.
If you are referring to a Cyrix MII-433 processor which ran at 300 MHz (100x3), hopefully you can try replacing the processor with an AMD K6-2 500 or higher, that is of course assuming that the motherboard is compatible (FSB, VCore voltage, multiplier). You should take into consideration that other than the MII-433. most Cyrix CPUs run at 83 MHz bus in a (Super) Socket 7 motherboard and technically is extremely overclocked (PCI bus running at 41.5 MHz). You should meticulously check the various jumper settings to accommodate your upgrade CPU. For stability, perhaps you should choose an Intel 266 with MMX, for speed AMD K6-2 500. This is of course if you can still locate such processors and appropriate memories.
Good luck and kind regards.
Posted on Nov 02, 2007
I want to connect a CAT5e Ethernet cable (with or without a RJ45 connector) from a DSL router to an older computer that only has a RJ11 input. This will be used for DSL internet service only -- no...
The only "outputs" from a DSL-router are:
* RJ-11 telephone-jack, only if the router also supports voice-over-IP,
* RJ-45 Ethernet port (always present)
You need to purchase an internal network-card, to create an RJ-45 port on the computer, and then use the CAT-5e cable to make the connection.
Feb 20, 2011 | Computers & Internet
I have a cable modem that doesn't want to accept the RJ-45 cable (I think that's what it is called.) I've tried several different quality cables with no luck. Strange problem. Any tips?
Some RJ 45 jack cable has fault so try with another RJ 45 jack cable .. Purchase new rj 45 jack cable from nearest computer shop. There must be 2 port on modem 1 for ADSL phone line cable and otthr for LAN ethernet port means RJ 45 jack port. Try with another rj 45 jack cable it should be connect.Make sure that LAN port of modem is not faulty means make sure pins on that port are not break. Let me know if you need further assistance. Thanks for using FixYa.
Jul 24, 2010 | Computers & Internet
RJ-45 port fails to securely seat the ethernet jack
These ports are soldered onto the motherboard. They can be changed out by a tech that has the right equipment. I have been able to successfully pull these off at one time using a heat gun set to high for 15 seconds. Then the solder points need to be cleaned thoroughly and the new jack placed into the brass sleeves of the motherboard and each leg soldered into position.
Mar 26, 2010 | HP Compaq Presario R4000 Notebook
T636400000 does it have an ethernet card built in the unit?
You are probably looking at a RJ-11, used for telephone (dial up - modem). You are trying to put a RJ-45 connector in it.
The RJ-45 should have 8 wires while the RJ-11 may have as many as 6 connectors.
Thank you for your voluntary work with this organization.
Note: If you were to plug a RJ-11 into a RJ-45 port and if it happened that you plugged the other end of the phone cord (RJ-11) into a phone jack --- and the phone were to ring ... you would be pumping 60 volts into your computer. Be very careful with these connections. You would then need butter and jelly for your toast, which is what your computer would be.
Ok - recap: Both look very similar ...
Ethernet = 8 conductors - RJ-45
Telephone = up to 6 wires (may be 2 or 4 also) - RJ-11. NOT interchangable.
So how will you connect? If the laptop is not builltin wireless, you can get a PCMIA card for the slot on the side that will allow wireless or ethernet. Get the card at your computer store. ... Or ... use the built in modem for dialup., You would of course need a dialup account somewhere.
Thanks for your question at
Please vote.
Feb 17, 2010 | NEC Versa VXi PC Notebook
Problem to install Intex RJ 45 Lan card in window XP
Hey try to use the cd you got with your motherboard to install netwok/LAN.
Dec 31, 2008 | D-Link DFE-530TX+ Ethernet ED100W Network...
Technical Specifications AAL and ATM Support
VCI 0-65535 address range
VPI 0-255 address range
AAL5 support
IEEE 802.1.d Transparent Learning Bridge (dynamic learning of up to 255 addresses)
Spanning Tree support
FCC Part 15, Class B
CE certification
DSL interface: RJ-11 or RJ-45 (Europe)
Ethernet interface: RJ-45
USB Type B interface (5200, 5500 series)
Diagnostic LEDs
Power, DSL, Activity, Ethernet status; USB status (5200, 5500 series)
Intuitive, Web-based GUI management access
SNMP support
Comprehensive hardware diagnostics
Media Interface
RJ-11 or RJ-45 (European) DSL WAN connection
10/100Base-T RJ-45 Ethernet LAN connection
USB Type B LAN connection (5200, 5500 series)
12V power supply included, 700ma max. 5400/5500 - 12 VDC, 1000ma max.
DHCP server/DHCP client
Network Address Port Translation (NAPT)
Network Address Translation (NAT)
Packet filtering
RFC 2364 Point-to-Point Protocol over ATM PVCs (PPPoA)
RFC 2516 Point-to-Point Protocol over Ethernet (PPPoE)
RFC 2684 (formerly 1483) Bridged Ethernet and routed encapsulation Routing
Standards Compliance
IEEE 802.3
USB 1.1 T1.413 issue 2 G.992.1 (G.DMT) G.992.2 (G.Lite)
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
dear ashprabha,
you are saying that your motherboard doesn't have a on board Ethernet slot. now, if u want to connect to internet means
then you have to purchase and fix a PCI Ethernet card. so that you can connect to internet.
Sep 26, 2008 | Intel Motherboard
How to replace ethernet port in gateway gt5404
If your motherboard's ethernet (RJ-45) port is the only problem, you have two options. For a workaround, use a spare PCI or PCI-Express slot and add a network card. Assuming their is nothing wrong further down the line than the port itself, that should get you back on the web / home network.
If however, you do not have a (spare) slot to add a network card, the only alternative is repair. Most manufacturers are good about helping customers with repairs, though of course, at a cost. Even worse with RMAs is the shipping cost, which is often completely billed to you, both ways. For this reason, motherboards are usually cheaper to replace than repair.
Desoldering the RJ-45/USB module from your motherboard may seem like a simple task, but the average joe with a soldering kit simply doesn't have the ability to do this sort of repair without further causing further damage to the board. Leave the repairs to the professionals. If you are trained to do this sort of work, you shouldn't need any advice about how its done.
Sep 17, 2008 | Computers & Internet
How to connect Remote to computer
Hello Nairy, Install infrared module onto IrDA connector, and enable function from the BIOS setup. Make sure you have the correct orientation when you plug into the motherboard. Location: Towards rear of motherboard, next to first PCI slot, on AGP side. The number one pin is closest to rear of board. Pin Configuration: 1. +5V 2. NC 3. IRRX 4. GND 5. IRTX 6. NC Please let us know how this works for you, and if we can help you in any other way. Best regards, nightdiver
Sep 20, 2006 | Acer AOpen AX 59 Pro II (91.87810.402)...
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
