Question about Hipstreet Flare 2 9 inch Tablet with 8GB Memory 2nd Generation
Shows the icon that indicates the tablet is charging but will not turn on - shows @9 only. Can turn it off with the power of/on button but won't advance past the @9 screen
How can I change the battery in m9100 kocaso
Try the follow to see if it will fix it:
There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
After performing the power reset on the device the device will behave in one of the following ways:
1. The tablet will turn on like normal.
2. The tablet will show the battery icon only.
3. The tablet will show nothing on the screen at all.
All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
Then most likely the battery will need replacing.
Here is a link to where you might be able to get a new battery:
Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
Jan 23, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
How long does it take for the proscan plt 1066 to charge.Why can't I see it charging when the screen goes black?
When you turn off a tablet, it's turned off. Thus, will not automatically illuminate even if it's charging in the background. If you really care to see the battery icon you can press the power button and in some tablets the battery icon will show without necessarily turning on the tablet.
Sep 26, 2014 | Tablets & eReaders
Sm-T210R tablet will not turn on or charge
Plug in your tablet, hold the power button while also hold downing the home button (white, black or silver button on front of tablet beside the return key) until the battery icon shows on the tablet. If this doesn't work and you are still under warranty send it back to Samsung. If no longer under warranty you will need to remove the entire back of the Tab and disconnect the battery from the motherboard. I do not give advice on doing this and you will have to look elsewhere for that procedure. I hope the simple fix works.
Aug 28, 2014 | Samsung Tab Tablets & eReaders
My tablet won't power, only shows battey then shuts off, won't charge
When you see the battery icon, hold the power button in a few seconds longer and see if it then powers on. Good Luck.
May 10, 2014 | Noria 7 Android 4.2 Tablet - White
Wont start up
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Mar 23, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Trio stealth G2-9 battery life will not charge
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
Mar 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Hipstreet flare 2 won't turn on
I have an Hipstreet Flare 2 that locks up at boot up. I even tried to hook it up to my computer and that failed to work. What to do now
Dec 28, 2013 | Techno Source Kurio Kids Tablet With...
Hipstreet Flare 2 9 inch Tablet with 8GB Memory 2nd Generation Logo
19 people viewed this question
Top Hipstreet Tablets & eReaders Experts
Lawrence Oravetz
ray gallant
Are you a Hipstreet Tablet and eReader Expert? Answer questions, earn points and help others
