Question about Sharp UX-B800SE Plain Paper Inkjet Fax
Server error (-14) (Sharp UX-B800SE)
When i try to use my fax to email i keep getting the (server error (-14)How do I fix this?
checkitright
  • 1362 Answers
SOURCE: Sharp UX-B700 Fax Machine
here is the manual in case you guys don't have it
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=196b4c87ed0acc8b59064e5655b55ba1&q=sharp+ux+b+700+manual
Posted on Dec 11, 2007
SOURCE: Manual for a Sharp UX-105 Fax Machine
tracidale...
Please send the manual for me too..via lannaapple@yahoo.com
Thank you in advance
Supawadee
Posted on Aug 17, 2008
leroyal
  • 2120 Answers
SOURCE: Error on Sharp fax UX-B700
Do you have a DSL or any kind of digital phone line?
Posted on Oct 26, 2008
  • 408 Answers
SOURCE: Sharp UX 108 manual
http://www.usersmanualguide.com/sharp/faxes/ux-108_178_188
That will have what you are looking for.  Please dont forget to rate!
Posted on Mar 06, 2009
SOURCE: Com error
Two simple Solutions to the annoying COM.E-2 error problem on a Sharp FAX machine:
Get rid of your DIGITAL FAX line and go back to an old ANALOG phone line.
OR
Buy yourself a Canon, Rico, or Brother FAX machine.
(SHARP doesn't even have a list of their own error codes: Just like the place Dilbert works at, in the comic strip.)
This fix is Guaranteed to work.
Posted on Apr 02, 2009
Tip
SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)Posted by...
<a href="http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/">SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)</a> <span>Posted by <a href="http://www.smtp2go.com/blog/author/admin/">mi6</a> on </span>August 19, 2009 - 4:06 am <span>Filed under <a href="http://www.smtp2go.com/blog/category/uncategorized/">Uncategorized</a></span> Some Sharp fax machines require a certain type of SMTP server in order to be able to send emails. SMTP2Go provides an SMTP server that authenticates senders based on their 'from' email address, meaning that it works with fax machines that are unable to send an SMTP username or password.<br /> Two examples of SMTP setup procedures for popular Sharp fax machines are below:<br /> Sharp UX-B800SE and UX-D1200SE Broadband Fax SMTP setup In the 'Network Settings' area, enter smtp2go.com as the SMTP server, and <b>UNCHECK</b> the box 'POP before SMTP'. Try entering either port 2525, 25, or 587 as the outgoing SMTP port. Then, make sure you are sending 'from' an email address that is registered with SMTP2Go.<br /> See a sample screenshot from the UX-B800SE fax below (click on it to enlarge):<br /> <br /> <p><a href="http://www.smtp2go.com/blog/wp-content/uploads/2009/08/sharp_fax_ux-b800se_smtp_setup.gif"><img src="sharp_fax_ux-b800se_smtp_setup_small.jpg" /></a><br /> Please note that Gmail's SMTP server doesn't work, as it not only requires a username/password, but it also requires that SSL/TLS is used.<br /> Please note: some fax machines may still have a problem sending - if this is the case, use the IP address of 207.58.142.213 instead of smtp2go.com as the SMTP server.<br /> SHARETHIS.addEntry({ title: "SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)", url: "http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/" }); <span><a><span>ShareThis</span></a></span><br />
on Feb 15, 2011 | Office Equipment & Supplies
We are getting a Server error (-14) when we try and run a email
Hi there you need check your phone line to see if it is properly connected,you can also try another cable if none solve the problem you should call your phone service provider to fix your phone line.
Aug 03, 2010 | Sharp UX-B800SE Plain Paper Inkjet Fax
Com error
OR
Apr 01, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
NEED ERROR CODE TRANSLATION
I do not know what the error code means but try this http://www.sharpusa.com/global/ContactUsProdSupp/1,1878,,00.html
They should be able to fix your problem
Jan 09, 2009 | Sharp UX-B750 Inkjet Fax
Sharp UX- B700 getting a Line Error message
Verify that you have a dial-tone by plugging a regular phone into the wall jack
Make sure the phone cord is plugged into the LINE jack..
Dial the number from a regular phone and listen for fax tones.
Sep 04, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
UX-B800SE Fax
I had the same "Full Memory" problem & called Sharp. You need to unplug the fax, then hold (press down) on both the "Start/Memory" & the "Stop" buttons at the same time. While holding them down, plug the fax back in. After it's plugged in, you may need to press the start button again. That should clear it.
Aug 02, 2008 | Sharp UX-B800H Fax
Sharp UX-B800SE Plain Paper Inkjet Fax Logo
932 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
