Question about Refrigerators
I have a White Westinghouse side by side refrigerator model WRS22WRBW
It does not defrost at all any more and basically after a time It keeps going nearly all the time. What could be causing that and what is the fix. Thank you. My email is alpha395@vianet.ca
  • 1073 Answers
SOURCE: trouble shooting defrost system
you can not manually start a defrost cycle
go to the freezer and check the heater and bimetal they are in the evaperator coil if these parts check good then replace the adaptive defrost control
Posted on Apr 25, 2008
  • 1073 Answers
SOURCE: Refrigerator Defrost Troubleshooting
you cannot do this
just check the defrost heater and the bi metal, if they check good then the adaptive defrost control is bad
  • 9 Answers
SOURCE: REFRIGERATOR IS NOT GETTING COLD,FREEZER ICING UP
What you need to do is get a amp meter check the amp draw of the defrost timer. also check the defrost thermostat and ohm the defrost heater out.
Posted on Apr 02, 2009
SolutionGuy
  • 331 Answers
SOURCE: I have a Kenmore Coldspot Model 106.59502992 that
Hi Danda,
About 98% of the time on a Whirlpool built Kenmore such as yours the problem with automatic defrosting is the "defrost timer". It's super easy to repair. You can get one from Sears, a local appliance parts retailer or just about anywhere online (just plug this part number---> 482493 <--- into a search engine and price shop)
Here's a diagram I made. It details the repair. Number 4 says "ADC", don't worry. There are two types of defrost timers one is an ADC and another is yours. They both follow the same repair procedure, OK?
Here's a full size diagram of your machine. You'll see that there is no difference other than the type of defrost timer.
NOTE---> UNPLUG YOUR FRIDGE BEFORE DOING THIS REPAIR!!! Otherwise, you'll look like this permanently...
There ya go, Danda! Remember to rate this solution as "FixYa" WillYa?
SG
Posted on Apr 22, 2009
Sea Breeze
  • 4654 Answers
SOURCE: our freezer keeps freezing up and it causes it to
If you tell me the model number found in locations in photo below I can help you.
Posted on Jul 14, 2009
Westinghouse RJ452T-R freezer wont defrost
how about the defrost heaters thermal fuse ? its on the back of unit with a port into the defrost heater inside with black and red wires going to it of course if it went then its pretty much a sure thing that the defrost thermostat is bad as thermal fuses don't usually go like that for no reason
May 11, 2016 | Westinghouse Refrigerators
Westinghouse fridge freezer model RS6437*4 FRIDGE SIDE KEEPS FREEZING UP
Could you please check that model number again? The number you posted came up as a range. The model number should be listed in the refrigerator section.
Oct 17, 2012 | White-Westinghouse White Westinghouse...
My westinghouse refrigerator has stoped working but my freezer is working fine help. Model Bj513V Serial Number 72656346
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 18, 2010 | Westinghouse Microwave Ovens
Timer problem
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 18, 2010 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
The auto defrost on my Whirlpool refrigerator model 310/350 isn't working and the refrigerator is very iced up.
cant find your model # but you know what its doing / so to correct this problem its one of two things . the defrost timer ( some times called (A D D C ) aditive defrost control . or the heater /thermo in the back of freezer . most comon it adc. mm hope this helped . feed back pls ..
Feb 04, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer & fridge warms up on average every 6-8 weeks. Remedy turn off and leave 24 plus hours with doors open. On turning on the fridge and freezer cool down again to operating temperature....
Good day,
That's too long a period, for a normal. defrost system failure.
You'll have to wait until it quits, then remove the rear panel and look for ice (not frost) building up somewhere in the freezer compartment.
I have solved similar problems on this model, by replacing the defrost thermostat with a GE 60 degree thermostat, and a WR9X330 GE 6 hour defrost timer to get this model to defrost completely.
It's also possible that the refrigerant charge is slightly low, causing the defrost thermostat not to reach a cold enough temperature to perform a good defrost cycle. (building ice over a long period of time).
Make sure Freon 12 was used when replacing the compressor.
Some substitutes caused the evaporator coil to act as if it was
slightly low on charge.
Nov 08, 2009 | Westinghouse Refrigerators
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
Ice maker freezing up
its a confirm defrost timer problem.the defrost timer is a device which after every interval of 8 hours defrosts the freezer part if the timer is faulty it wont defrost and go on over freezing.you can buy the defrost timer for aprox 30 dollars from link below:http://www.repairclinic.com/thanks and plse do not forget to rate the solution.
Jun 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer not working
Your refrigerator has a Control-defrost,adaptive timer ,PC board part number 241508001
This is providing your model is the one listed above your post WRS3R3EW. The model you listed in post does not come up. Until we can determine that the freezer is not defrosting you need to unplug and remove the back panel of freezer compartment to see if the evaporator coils are frozen or clear. If frozen this alone will cause a chain reaction that keeps vents to fresh food compartment open and cause freezing in that area. Go to link below and enter model number WRS3R3EW0 Then you will see a list of diagrams on left side, chose #11 this will show the control parts. Click link below Thanks, Sea Breeze
We offer free help and assistance also.
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
How do you adjust a Westinghouse 2 dooe refrigerator door
Loosen the top hinge screws.
Pull up on the door to where you want it.
While holding the door in place, re-tighten the screws.
Mar 11, 2009 | Frigidaire Freezer Refrigeration White...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
