Whatb is the volume of a water pipe 1650meter long and 300mm inn di9ametr
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
About 116.6 cubic meters.
Posted on Sep 03, 2014
When Faucet is turned on I get a loud noise. If I use the Sprayer the noise goes away.
Sounds like water hammer. Air in the pipes. Lower volume of water out of the sprayer isn't enough to initiate the hammer. Try shutting the water off to the house and draining the pipes.
Open the offending faucet and turn the water back on this should eliminate the air in the pipes.
Dec 08, 2014 | Plumbing
Tip
How to Clean a 2-Stroke EXHAUST.
Cleaning (de-coke, de-carbon) an exhaust header, expansion chamber and pipe is a periodical must to reap full advantage of the engines capabilities, that is often overlooked. A simple, quick and cheap method is to remove pipe from bike (and muffler) and place a length of cable wire (old clutch or speedo) or the metal shroud that surrounds it (stripped of rubber sleeve) long enough to exit both ends by 300mm (12"). Attach one end to drill chuck, Spray WD40 liberally into pipe and roll around till inner surface is covered, and spin drill with a slight in and out motion. A few minutes of this and then rinse out with water into a rag covered basket with a garden hose spray nozzle. For your health and safety, it may be wise to wear gloves and goggles. See results below. Note: Two old expansion chambers have been here cut for illustrative purposes!4d89371.jpg3d3a03d.jpgf841648.jpg
on May 04, 2010 | Motorcycles
Hi - just fitted my beko washing machine after moving .Disaster!! When the water began to fill it come straight out of the bottom through a disconnected 10mm black hose about 300mm long .One end was...
a 10mm pipe is not the main drain pipe. The 10mm black pipe is for manual emptying and should have a blue stopper to plug the end, pull off the front bottom panel, and there should be a small opening, inside this opening is the manual drain pipe. Check to see that the blue stopper is still connected. If not, then you can buy these for less than a fiver online.
Oct 06, 2012 | Beko WME7247W Washing Machine
VOLUME OF WATER IN 4"
I don't know if this is what you are looking for and it's not exact but close. The volumn of a one foot section of 4 inch pipe is about.662 gals. Hope this helps you. Thanks
Nov 26, 2010 | Plumbing
Furst thing to leard basics I do not know whatb
I would start at Borders (or another local book store) and find a beginners book on computers. "Computers for Dummies" (I'm not calling you a name, that is the title) or the "Getting StartED with..." series. Some computer stores will also offer you a class with the basics for a fee.
Jan 24, 2010 | AOpen Computers & Internet
Volume of water in pipe work
3.14 x Diameter x Diameter / 4 x length= Volume in Cubic inches Diameter and Length are in inches.
Multiply the above volume by 0.004 to get gallons.
Jun 11, 2009 | Plumbing
Dropped sigma 70-300mm lense in water, can I get rid of water spo
Hi The front lens will screw off after you remove the front cover ring and you can clean it
Feb 26, 2009 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Water sound change in home plumbing
the Pipes heat and expand and become tighter in their mountings. less pipe movement.
and the expanded pipe has a different reverberation
Sep 22, 2008 | Brewmatic High Volume - Single Coffee...
Tokina 35-300mm af zoom lens
Unless you have extensive experience, this is best left to professionals. If you didn't spend much, then you could "learn" on it, but if it is something you really value...don't do it.
Oct 29, 2007 | Tokina 35-300MM F4.5-6.7P KAF Lens
29 people viewed this question
jasbo
jasbo
