Question about Garden
My Homelite 26 HT Hedge Trimmer is stubborn to start and then only runs on Full Choke at full throttle, but not smoothly. Whats up with this?
    Problem Solver:
  • 7 Answers
The problem with the homelite trimmer is that the instructions show the incorrect starting procedure.
The manual refers to priming 10x , when the unit actually needs to be primced 20 times.
Surely it can be a clogged carbie, but... in my cash it was a brand new unit, and after getting tennis elbow and tearing some ligaments..... learnt my lesson!
So remember - prime twenty times, then pull pull pull!!!
Posted on Dec 21, 2010
    President:
  • 512 Answers
Jets in carb are dirty. Take carb off and clean, blow out all jets, you may have to use thin wire to get all gunk out. Also fuel line might be dry rotted. Put carb back on and adjust settings on carb.
Posted on Jun 18, 2009
Mitox 28lhr long hedge trimmer does not start properly. It takes at least 50 pulls of the start cord before it starts. I've changed the spark plug but to no avail. Any advice on how to help it start
  1. Switch machine to On position.
  2. Switch choke to full.
  3. Pump the primer bulb 5 or 6 times to prime the carb.
  4. Lock the throttle on with the throttle switch.
  5. Pull over until engine fires. (it may only be a quick pop)
  6. Switch to half choke.
  7. Pull over until engine starts and runs.
    Also check the air filter is clean and the fuel filter is good.
    I've added a link to the manual incase you didn't have it. Page 30.
    http://www.mowerspareparts.co.uk/v/Mitox%20manuals/271MT281MT.pdf
Apr 09, 2016 | Garden
I have a craftsman 358.796354 hedge trimmer that will start on full choke, throttle in the start position. But, as I move the choke from full it will rev up then stall. The only way I can get it to "r
It sounds like more of a carburetor issue but out of curiosity did they say why they thought it was a compression issue? Although craftsman is a little high on their parts a lot of the aftermarket parts such as a carburetor a lot of times are not all that expensive. I can't imagine you'd have all that many hours on it unless you use it commercially to warrant a compression issue. Might be worth a try.
Apr 14, 2013 | Craftsman 22" Gas Hedge Trimmer
My 26HT reconditioned trimmer will start and run on full choke but, if I take it off to middle choke, it dies. It doesn't run right on full choke but does rev up enough to engage the blades. Has...
sounds like a carb problem You will have to take the carb off and strip it down to parts clean out all the ports with a good cleaner I use brake clean reassemble and reset the High speed and low speed jets at 1.5 turns out then adjust from there
Jun 14, 2011 | Homelite Factory Reconditioned 26cc...
Hi Experts, I have a McCullough lawn edger/trimmer Mac-Pro I. I am having problems staring the engine. I can't remember whether I have to hold the throttle in whilst pulling the cord? Also,...
Yes, the throttle should be in the full in position. When starting, the choke should also be in the full on position.
If you can't tell if it is in the closed or open position, remove the cover that is over the carb where the air filter is and you should be able to see which way you move the lever for the closed or open position and mark it where you can see it. When starting put the throttle full on and the choke also in the full on position. It should usually start and stop right away. Now move the choke to the full off position keep the throttle in the full on position and it should start in 2 or 3 pulls. If it doesn't do the procedure again. While you have the cover off the carb check the air filter and if it is very dirty replace it or clean it off because a really dirty air filter could make it run rough or not start at all. I will gladly answer any questions. Best regards and good luck.
Dec 28, 2010 | McCulloch Lawn Care: Trimmer Plus...
How do i start my homelite ht -17 hedge trimmer
it sounds like your throttle cable is to long i have the same problem with mine... when starting up pull the throttle full on with your finger whilst you have it set on choke. best to do this on a very flat surface.
Nov 03, 2010 | Homelite Expand-It Hedge Trimmer...
My homelite string trimmmer will not run when choke is run position. it will run, but not at full throtle, when choke is set between full choke and half-choke.
you've got a fuel system issue , most likely carb problem, if this a newer trimmer it will likely need the carburetor replaced or adjusted, also check for cracking fuel lines or signs of old fuel varnish in the tank
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
540 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
