Question about Seiko S149 Stopwatch/Printer
S149 will not start
My watch is on and shows ready to measure but I can't start it. The lock switch is off.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
You may need to reset it. Unfortunately, this can not be done without taking the unit apart. I fixed ours yesterday when the screen was blank, by replacing the internal battery. Part of that process is resetting the clock.
This might solve your problem and so, I have included my full instructions for replacing the battery.
You will need a small phillips screw driver, a paperclip and a new battery. ( a CR2032 works fine and can be bought anywhere)
Keep in mind, you will be handling some electronics, so keeping static discharges to a minimum is a good idea.
*Place the unit face down on a table.
*Remove the battery cover and batteries.
*Using tape, cover the two switch sliders located on the sides of the unit so they stay in place when you remove the back.
*Remove the three screws inside the battery bay and the four longer screws on the main body.
*Before you gently seperate the back from the front, take note of the two battery connections that are on the outer edge of the battery box and are opposite of the strap brackets. These will need to be coaxed through the plastic as you pull the back off. You will also need to manipulate/open the paper roll cover.
*Remove the back cover.
*The top circuit board and printer are connected to the lower circuit board and front cover by a white ribbon cable and wires to a switch. Gently lay the top circuit board and printer to the side, being careful not to unlpug the cables.
*Locate the battery, it is standing on edge. Note the orientation.
*Straighten the paperclip and make a hook so you can remove the battery.
*Install the new battery, taking care to not bend the connectors.
*A label on the inside of the back cover details the reset procedure. Locate the AC and + on the lower circuit board.
*Use the paperclip to make an electrical connection between those two points.
*Reassemble the unit in reverse fashion.
*Pay attention to the switches on the top circuit board and the slots they fit into. These are the black switch sliders that were taped to the side.
*The printer assembly should set into place.
*Reinstall the back cover, coaxing the battery connections through their respective holes.
I hope this solves your problem.
Posted on Oct 19, 2016
I cannot measure heart rate during or after the exercise as it shows locked.
A bit more information is needed like make and model. I just measure mine for 10 seconds and multiply by 6. That way I only need the second hand or equivlant.
Nov 27, 2014 | Watches
Replace printer ribbon
Print is very faint on thermal paper Seiko System Stop Watch S149
Aug 13, 2013 | Seiko S149 Stopwatch with Built In Printer
How do you open the Seiko S149 to replace the battery
there are four screws on the back and three in the AA battery tray. then you remove three screws holding the battery down.
Jan 25, 2013 | Seiko S149 Stopwatch/Printer
How to change the internal battery on an s149 stopwatch printer
Go to this link for your instructions. The title page is in Kanji, but the instructions are in english...
http://www.cei-ultrak.com/seiko/s149.pdf
Good luck and don't forget to vote.
Oct 12, 2010 | Seiko S149 Stopwatch/Printer
I am having trouble finding 6V SB-T74 battery for Seiko s149 stopwatch. Any suggestions?
See:
http://www.battery-house.co.uk/reference.html
for a list of battery equivalents. Looks like the SB-T74 is a CR2340, available online for a couple of UK pounds.
Sep 23, 2010 | Seiko S149 Stopwatch/Printer
Seiko Stop Watch S149 Stop watch has new batteries in and they are put in correctly but nothing shows up on the screen. The paper feeder works so it is getting power.
If you go to "www.sportscounters.com/seiko-s149-stopwatch-printer-all-in-one" you will see a telephone number, try calling them for advice.
(This problem is fairly common after replacing batteries, so I suspect that there is a procedure for resetting the timer.)
Feb 25, 2010 | Seiko S149 Stopwatch with Built In Printer
Seiko Stopwatch with printer S149 - came with no manual for setup
Get it here:
http://www.everythingtrackandfield.com/catalog/matriarch/documents/SeikoS149StopwatchPrinter4220.pdf
Rate, please.
Feb 04, 2009 | Seiko S149 Stopwatch with Built In Printer
My seiko s149 with built in printer went blank the other day.
The S149 has 2 sets of batteries
1) 4 X AA for the printer
2) a round "button battery inside the unit for the clock.
Open up the unit, you will see that it takes either a 2450 or a 2032 depending on the model.
Nov 15, 2008 | Seiko S149 Stopwatch with Built In Printer
Seiko S149 Stopwatch/Printer Logo
85 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
