Question about Tascam 2488 Portastudio Multitrack Recorder System
Tascam 488 MKII
I am a TV rpair hobbyist who has a 'musician' friend that presented me with this Tascam 488 MKII (not the 2488) that he thinks is not working. Personally not knowing exactly what the machine is supposed to do or how to do it would help if I could procure a copy operating/owners' manual. Maybe its not malfunctioning at all. But if it is I I also wonder if anyone would have copies of schematics for the same. I did write to TEAC but had no response. Any ideas?
Thanks
Rob
ettmart1@shaw.ca
  • ettmart Dec 18, 2007
    It is not the 2488 that I was looking for, but thanks.
    Rob
  • jrkunz Mar 31, 2008
    I have a tascam 488, quit using it for about 2 years, then turned it on and the VU meters all went up have way and stayed there... then when i hit play or record the tape slows down and then finaly stops. just a motor? any help out there: ? thanks, jim kunz
I have a Tascam 488 mk II that will rewind and fast forward, but will not Play or record. Does anyone know a solution to fix this problem?
Check too make sure that the tabs on the cassette itself are there if they are gone place a piece of tape over them, then try recording again. It may be a belt issue open the unit and see if all the belts are present cassettes usually have 2 or 3 separate belts one controlling the fast forward and rewind and another for record and play more than likely this is the issue, If so belts for these units are obsolete try searching science and surplus magazine catalog they carry a variety of large rubber band / belts you may get lucky and find one there good luck I hope this helps you
Mar 31, 2015 | Tascam 488 MKII Portastudio
I have a tascam 488 mk II when its turned on the play record and pause lights all are blinking and dont know why?
check to see if any of the buttons on the play/record panel are pushed down or stuck if not go to the tascam website and submit a trouble iinquiry
Oct 08, 2014 | Tascam 488 MKII Portastudio
How do i load a song from a cd onto tascam 2488 mkII?
Although I was a factory authorized service center for Teac and Tascam, this is a much later product than I'm familiar with; no problem however.
If you have your owner's manual, the procedure will be listed there. If you no longer have the manual, just Google Teac, in Montebello, CA. I'm quite sure it will be our their website.
Jun 12, 2014 | Tascam 2488 Portastudio Multitrack...
Control midi program sampletude
The Tascam has no midi In,Out or Thru so the answer is No.
Apr 21, 2009 | Tascam 2488mkii 24 Track Recording...
Tascam 2488 locked up/frozen
This will reinitialize it to the factory settings. All data (music) will be lost.
With the 2488 turned OFF
Simultaneouly, hold down the Quick Routing, Shift, Send and Shut Down buttons.
With all buttons pressed .... turn the 2488 ON.
It shoulld go through the normal boot up screens, including a screen that states ' partitioning drive', etc. When finished it will show ' Factory Settings Reinitialized - Reboot (or something like that) and you are done.
I have the original 2488 as well, and tried everything recommended to address the HDD lockups.
I think I know why Tascam eliminated the Tone Generator (Drums) on the MKII and Neo versions.
Too much for the processor to handle?? Hope this helps.
Bill H
Mar 24, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio screen.
You could add an HGR monitor interface module to display the 2488 on a PC monitor.
www.hgr2488.co.uk
That way you don't need to look at a damaged display and the 2488 (MK1, MKII and NEO) work just like before.
Aug 31, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
In the monitor section on the 2488 console (upper right) make sure your monitoring source is set to 'stereo'. Then make sure your 'monitor level' control is turned up. The 'stereo' fader (sub mix fader on the MKI, stereo fader on the MKII).
Dec 26, 2007 | Tascam 2488 Portastudio Multitrack...
Don't know how to Pre-Master or Burn to CD, please help me!
Don Q -
This answer assumes you have the 2488 mkI and not the newer mkII because the process may differ slightly on the mkII.
To premaster you first have to set an out point for the end of your pre-master (the start point is always zero). Go to the 'Audio CD' menu item and choose 'pre-master' under that. You'll see the word 'mastering' appear in the top left of the screen to let you know you've entered mastering mode. Make sure you have the tracks unmuted that you want to mix into the pre-master and have all of your eq, panning, etc set the way you want. Then hit record and play. The pre-master records to a stereo pair of dedicated internal tracks. You can redo the premaster as many times as you like which will overwrite those internal premaster tracks. You can clone the premastered tracks to a stereo pair of tracks, export them as waves or burn them to a CDR.
fnawesomewes - You have to press record and play to record your premaster.
Dec 07, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
1,211 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
