Question about PNY HP K2500 WIRELESS KEYBOARD
Hp k2500 letters keep typing
Typing along and all of a sudden it starts repeating a letter continuously
Letter j keeps repeating in console in windows 7
It means the key with letter 'J' was malfunctioned in the keyboard. When you open a console or notepad it goes continuously by printing the letter 'J' on the screen or sometimes you will get continuous beep.
This problem can be rectified by replacing the keyboard.
Hope this will be helpful.
Regards
Nandu
Sep 30, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Keyboard typing multiple letters/ numbers when pressing certain keys.
Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard's repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
Feb 03, 2013 | Computers & Internet
When I type a letter on keyboard it keeps repeating the letter
The key might be sticking down, which is probably a defect in the product. I tested an ihome keyboard (Bluetooth) and everything except the spacebar was prone to sticking itself down, no pop spill or nothing. So, I recommend to return the keyboard if you still have the receipt and get a Bluetooth Apple keyboard instead, as ihome is good for their docks, but their keyboards suck!
Feb 02, 2013 | iHome Bluetooth Keyboard for iPad 1 & 2,...
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
My keyboard will not type a double letter or backspace more than once without stopping first? Do you know why?
Disable Filter Keys in Windows 7 and Work.If Filter Keys has turned on in Windows 7 and your keyboard is no longer responding as you would like, follow these directions:
  1. Click Start
  2. Click Control Panel
  3. Click the Ease of Access heading.
  4. Click Change how your keyboard works.
  5. Remove all the check mark in the box next to "Turn on Filter Keys".
Enjoy :)
~ Vikrant (India)
Dec 09, 2010 | HP Computers & Internet
The striker appears not to strike the Daisy wheel letters firm enough to produce a dark and clear letter. Many times the result is a letter not fully printed and it appears to be lighter along the left...
Please check the ink ribbon. There are two types of ribbons. The plastic one can be used once and if you try it the second time then there is no guarantee that all letters will appear fine and legible. (as may be happening in your case). The other is the cloth ribbon. This can be reused and it keeps fading as you keep repeating it. But in this case all letters are faded and nor selective.
Nov 22, 2010 | Lexmark Wheelwriter 1000 Typewriter
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
Repeating letter on viewed webpages and while typing
install powerful antivirus, if not work change the keyboard
Nov 26, 2009 | HP Pavillion ZV6000 Notebook
Brother EM530 Typing Wrong Letters
Hi there. Take out the printwheel and see if any of the spokes are bent. That would cause wrong letters. . Also if the print solenoid(piston) does not go in and out freely. Lawrence
Aug 06, 2008 | Brother ML-500 Typewriter
PNY HP K2500 WIRELESS KEYBOARD Logo
21 people viewed this question
Top PNY Computers & Internet Experts
David
David
marley mcelhinney
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
