Question about Sharp LC24LE510K 24" LED TV 1920x1080, 50 Hz, Freeview, HDTV, LED Backlight
Won't turn on and constant red flashing light on front of TV
Hi, I have a Sharp LC25LE510K TV. I tried to turn it on last night, but couldn't, either with the remote or buttons on the TV, there is the red power light on the front is constantly flashing at a rate of approximately 1 per second. The user manual is of no assistance. Would appreciate any advice as to what the problem may be, and if there's some kind of re-set that we can do? Thank you
  • 33 Answers
SOURCE: LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
Posted on Dec 12, 2008
dsacco86
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
SOURCE: Flashing OPC/DL light
Here's what I did to fix issues with my 37D5U - do at your own risk:
***Follow the instructions below to fix the same issue in your LC-37D5U tv***
Do this test first to confirm the failure:
(1) Connect the cable line to the tv.
(2) With the tv unplugged, hold down the Input and Volume-Down buttons simultaneously, then plug in the tv.
Expected result:
(a) You should hear the tv come on in the service mode; the OPC/DL and power lights on the front of the tv should turn green and blue, respectively.
(b) The broadcast sound should come through the speakers, but you will probably still have no picture or back light.
If your test yields the expected results, proceed to the fix.
Fix
Parts Needed
(1) Part type: Fuse
Location on circuit board: F705
Official Part No: QFS-A1154SNEZ
Replacement Part No: BK/PCB-1-R (Mfg: Cooper Bussmann - about $2) or the original QFS-A1154SNEZ (Distributor: Sears Parts Direct - about $14)
(2) Part type: Mosfet (4 of them)
Location on circuit board: Q723, Q721, Q719, Q717
Official Part No: k3469
Replacement Part No: FQPF13N50C or FQPF13N50CF (Mfg: Fairchild Semiconductor - about $2 each)
Fuse F705 is part of the circuit on the power supply that powers the inverter circuit, and the inverter switches on the back light for the tv. The mosfet at location Q723 was suspect when I tested it, so I went ahead and replaced it and the other three mosfets "chained" to it as preventative maintenance. Parts can be bought from digikey.com - digikey is usually a same-day shipper with the best prices, so I use them. USPS Priority shipping is the best bang for your buck.
Tools Needed
Philips screwdriver
Soldering iron
Desoldering braid or some other solder remover
Light bulb socket that has two wires running from it and a clear 100-watt light bulb - Home Depot sells the sockets. Alternatively, you can use a 2K ohm/10W resistor
Multimeter - not necessary, but helpful
Procedure
(1) **Important: Make sure the tv is unplugged**
(2) Remove the back cover and stand - there are a bunch of screws holding the back cover on. You can either mark the screw locations and bag the screws or do what I did: Unscrew the screws, leaving them in their holes, then slowly lift the back cover off and carefully set it down with the screws intact.
(3) Set the tv on a flat surface with LCD panel facedown and remove the AC power cable.
(4) The board you want to work on is the power supply board (see pic below), which is the board where the AC power cable connects. Carefully detach the connectors that connect to the other boards in the tv from the power supply, then remove the screws that hold the power supply to the back of the tv and lift it off the tv by holding it by its edges.
(5) Locate the four large 450V capacitors at locations C734, C709, C710, and C852 without touching them (they look like soda cans). Flip over the power supply board. Touch each wire of the socketed light bulb or resistor for about 3 seconds to the negative and positive leads of each large capacitor, respectively; polarity is irrelevant. This discharges the high voltage from the capacitors so you don't get shocked while working on the power supply. The voltage usually slowly dissipates on its own, but it's better to be safe than sorry when you're talking about a potentially lethal 450V. Check the voltage with your multimeter in the appropriate DC mode to verify that the capacitor voltage has been drained; if you don't have a multimeter, just continue on.
(6) At this point, you can verify that the fuse at location F705 (looks like a small black box) has indeed failed by holding the multimeter's red and black probes on the fuse's leads with the multimeter in continuity mode. If you have no continuity, the fuse has internally failed; proceed to the next step.
(7) Desolder the fuse from location F705 and desolder the mosfets from locations Q723, Q721, Q719, and Q717 then replace with new components.
(8) Put the power supply board back in the tv, using just a couple screws to hold it in for now. Reattach the connectors to the power supply.
(9) Attach the broadcast cable line.
(10) Reconnect the AC power cable to the power supply (don't plug it into the wall socket). Hold down "Input" and "Volume-Down" simultaneously, then plug in the tv. The tv picture and sound should come on.
(11) With a small screwdriver or other probing device, depress the Reset button, not the System Reset button; it's the last recessed button below the cable jack on the back of the tv. The tv will reset, then you should get sound and a picture from channel 2.
(12) Reinstall the remaining power supply screws, back cover, and stand.
Posted on Dec 30, 2010
jotvguy
  • 146 Answers
SOURCE: screen black, power light constantly flashes, no
I recently found on a 42" Sharp. The inverter module had three fuses on it, inline little fuses markings all begin with an F 1001 etc. a tiny little fuse
f3 I believe had opened and caused exactly what you describe. The inverter module is usually furthest left and attached physically to your lcd panel. Has a metal cover over it. Be careful HIGH VOLTAGES on this pc board. If the fuse has opened. www.shopjimmy.com wonderful recycler of previously used or repaired parts. you can shop them by model #
Posted on Jul 11, 2011
  • 96 Answers
SOURCE: My tv has no power,
John, sounds like if the main isn't the culprit that the Power Supply may have faulted on you. Try ShopJimmy.com, I have used them in the past with great success. I included a link to the PSU from their site. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/new-sharp-rdenca272wjqz-power-supply-unit.htm
Posted on Aug 19, 2011
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
Hi i have an isis tv and have lost the manual to it. I can not get the tv to switch on, every time i turn the power on and try and use the remote to turn it on nothing happens and the led red light on the...
Hi can anyone please help me a have a isis tv only a year old was working fine last night aye want to put it on tonight and the red light flashes for a bit than comes on but no sound or picture what could it be the scream is just dark
Sep 13, 2011 | Televison & Video
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
Go to turn on tv and all I get is flashing red light and tv won't turn on. Was working the other day.what do I check?Sharp LC-26GA5U
Try unplugging the TV from the power point and leave unplugged for 5 min.
Or the batteries in the remote may be flat, try replacing the batteries.
If this doesn't work the TV may have a fault.
I hope this helps
MobileJB
Jul 13, 2011 | Sharp LC-26GA5U 26 in. HD-Ready LCD...
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jun 13, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp LC24LE510K 24" LED TV 1920x1080, 50 Hz, Freeview, HDTV, LED Backlight Logo
15 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
