Question about Toro LX427 42" 20-HP Kohler Lawn Tractor
Where is fuse located on lx427 riding mower - Toro LX427 42" 20-HP Kohler Lawn Tractor
Fuse for igntion were its located
    Riding Lawn Mower Fuse Replacement - Craftsman Lawn ...
    ? 1:51
    https://www.youtube.com/watch?v=rjFz8l8hoGk
    Aug 22, 2014 - Uploaded by RepairClinic.com
    ... instructions for replacing the fuse on a Craftsman riding lawn mower. ... Mower Starter Solenoid Replacement - Craftsman Riding Lawn ...
    14 HP Murray Mower 42813x92B Blowing the Fuse - YouTube
    ? 4:37
    https://www.youtube.com/watch?v=J8l1Ew40G7g
    Feb 14, 2013 - Uploaded by RogerASkiVideo
    Photographic guide to troubleshooting a Murray riding mower that keeps blowing the 15 amp fuse. images for Lawn Mowers ignition fuse
Dec 19, 2015 | Garden
John deere riding mower model D120 electrical diagram does it have a fusable link, if so where is it located
Yes, it has a 20 amp fusible link. It looks just like a 20 amp auto fuse. It's in a holder in the wiring harness. Typically it's found attached to the frame right in front of the battery holder.
Mar 05, 2015 | John Deere Garden
How to change the fuse on a cub cadet riding mower
Most of the times the fuses on cub cadets are located under the engine cowling close to where the steering shaft runs through the frame near the battery. Follow the wiring harness from behind the ignition switch and it should lead you to the fuses. There are no very many fuses to check on your mower. Good luck and I hope this helps.
Sep 07, 2014 | Cub Cadet Garden
Where is the fuse box on gt 5000 craftsman lawn mower?
If you think your riding lawn mower has blown a fuse, trying to locate that fuse may be the most challenging step in replacing it. While different lawn mower manufacturers have located the fuse holder in different areas of the lawn mower, the best place to start looking is near the mower's battery, according to Sears.
Some manufacturers have made it easy to find the fuse holder. Simply lift the hood. The fuse holder is molded into the metal right inside the hood, near the battery. (See photo at Ref. 3, p. 53) If the battery is located beneath the seat, you may find the fuse holder located beneath the rear fender. Other manufacturers make it more challenging, placing the fuse inside an electrical box, located behind the mower's upper air baffle. (Ref. 4, p. 28) Fuses can also be located on or close to the edge of the mower's electrical panel, above the solenoid.
If you check these locations and still cannot find the fuse holder, check your operator's manual for a diagram of the electrical system, which should display the fuse's location. If you no longer have your manual, it may be available online through the manufacturer's website. Should you be unable to find a manual, call a local lawn mower dealership or lawn mower repair shop and ask for assistance in locating the fuse in your exact model.
Jun 27, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Where is the fuse on a Husqvarna model YTH1542XP riding mower
Did you ever find the fuse? I have looked at the diagram & tried to locate w/no success
Apr 20, 2013 | Garden
Fuse location
Most of thenew ones are back by the battrey at the back of the mower
Apr 13, 2013 | Mtd Garden
How to fix LX427 toe-in back to factory alignment.
Your owner's manual tells you how. If you don't have one go to and get free manual www.managemylife.com
Feb 25, 2012 | Toro Garden
Toro LX427 42" 20-HP Kohler Lawn Tractor Logo
91 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
