Question about Texas Instruments Office Equipment & Supplies
How to use sin function
How to access sin function
  • kakima Apr 15, 2014
    What model TI calculator?
  • Texas Instru... Master
  • 7,993 Answers
Depending on calculator, enter angle then press sin key or press sin key then enter angle and press equal sign. Make sure angle units are the ones you want (degrees, radians or gradians.
Posted on Jan 30, 2016
Find inverse sin
The inverse of a function usually shares the same physical key as the direct function.
Feb 03, 2014 | HP 30s Calculator
Im pressing the buttom that everyone is saying is the inverse key but it is saying error. i really need help with this.
It is much more enlightning to tell us what you want to do rather than talk about something that does not exist. And one thing that does not mean anything is that ellusive INVERSE key that everyone and his dog is looking for.
The additive inverse of a number a is its opposite (-a). The key to use is the change key (-).
The multiplicative inverse of non-zero number a is its reciprocal 1/a
The inverse of the natural log (LN) function is the EXPONENTIAL function e^(x). On most calculators if one function is accessed diectly (the marking is on the key), its inverse is accessed by pressing [SHIF] (Casio, or [2nd] (TI) or [2ndF] (Sharp).
The inverse of the function raise 10 to a power [10^x] is [LOG]
Similarly, the inverse of the sine function SIN is the arcsine [sin^-1]. To access the latter, it you press [2nd][SIN]. The same is true for arcosine [2nd][COS], and arctangent [2nd][TAN]
The inverse of the square functions [x^2] is the square root function [2nd][x^2]
Inverse of x^3 is cubic root
This is just a quick overview.
Feb 16, 2012 | Texas Instruments TI-84 Plus Silver...
Cant find the arc or inverse button
The trigonometric function [SIN],[COS] and [TAN] have inverse functions arc-sine, arc-cosine, and arc-tangent which are also implemented on scientific calculators. To access the inverse trigonometric functions you use the sequences [SHIFT][SIN], [SHIFT][COS] and [SHIFT][TAN]. The functions are marked on the body of the calculator as [SIN^-1], [COS^-1] and [TAN^-1].
When you use these functions, make sure that the angle unit is correctly set (as required by the problem you are solving) because the angle values returned are in the same unit as the one set.
Jan 15, 2011 | Casio FX-115ES Scientific Calculator
How do i do sin-1
Press SHIFT then sin to access the arcsine function.
Aug 31, 2010 | Casio FX-115ES Scientific Calculator
How to do inverse of tan cos sin
The inverse trigonometric function share each the same physical key with its direct function. The inverse trigonometric functions are accessed with the [SHIFT] key
[SHIFT] [SIN] accesses the arcsine
[SHIFT][COS] accesses the arccosine
and [SHIFT][TAN] the arctangent.
Apr 14, 2010 | Casio FX-9750GPlus Calculator
How do you use the sin-1
You would press on the SIN key, "sin(" should come on the display, then enter the value, for example 3.5 or -1 so that the display shows
sin(3,5) or sin(-1) for example.
remember to close the sin with the ) on the end.
sin(-1) = -0.841470985
Feb 16, 2010 | Texas Instruments TI-30XA Calculator
How do you find arc sin on this calculator
Before using the inverse trigonometric functions, make sure your calculator has the right unit as angle unit. The unit of the values returned by the inverse trigonometric functions is the same as the default angle unit. This being said, you access the arcsine function by pressing 2nd sin^-1
The syntax is as follows number 2nd sin^-1 =
Hope it helps.
Thank you for rating the solution.
Dec 09, 2009 | Texas Instruments TI-30XA Calculator
How to use the cosine,tangent etc functions of calculator fx-82ES plus
1.Set the correct angle unit required by your problem: degrees, radians, or grads. [SHIFT][MODE] [3:deg] or [4:Rad]
2. Press the key for the function COS, SIN, or TAN
[COS] displays Cos(
3.Enter the angle 12 deg Screen shows cos(12
Close the right parenthesis ) Screen shows cos(12)
4.Press [=] Screen displays 0.9781
If you want the inverse trigonometric functions you access them with arccos [SHIFT] [COS] (cos^-1)
arcsin [SHIFT][SIN] (sin^-1)
actan [SHIFT][TAN] (tan^-1)
You have to know the principal domain for the inverse trigonometric functions (see any book on trigonometry) to understand the results.
Hope it helps.
Nov 05, 2009 | Casio Office Equipment & Supplies
How to use trig function keys on my casio fx-300ES
You have 3 keys for the main trigonometric functions: [SIN], [COS] and [TAN]
To use them correctly you must set the angle unit to the one your problem calls for.
Press [SIFT][MODE] [3:Deg] for degree, [4:Rad] for radian, [5:Grad] for grad. Dependig on angle unit chosen a small D, R, or G appears on the top of the screen.
If you need the inverse trigonometric functions arcsine, arccosine, arctangent, you access them by first pressing the [SHIFT] key
Thus
arcsine [SHIFT][SIN] (sin^-1)
arcosine [SHIFT][COS] (cos^-1)
arctangent [SHIFT][TAN] (tan^-1)
The syntax for the function is
[SIN] # [ ) ] [=]; [SIN] 30 [ ) ] [=] gives 0.5
[COS] # [ ) ] [=] [COS] 19 [ ) ] [=] gives 0.945518576
Note: if the argument of the functions are numbers, the right parenthesis is not necessary. But if the argument is an expression (with various operations) better put the parenthesis to make sure the calculator is performing as one wants it to.
By the way, there are no keys, or key combinations to calculate cotangent, cosecant, and secant, but you can use the definitions:
cotangent (x) = 1/tan(x) Do not confuse it with tan^-1
cosecant(x) = 1/sin(x) Do not confuse it with sin^-1
secant(x) = 1/cos(x) Do not confuse it with cos^-1
Hope it helps.
Oct 30, 2009 | Casio fx-300ES Calculator
Cosecant
The cosecant function is defined by
cosec(x) = 1/sin(x)
1[/] [sin] x.
Do not confuse this function with the arcsine function which is accessed by [2nd][sin to the -1]. When you use trigonometric functions make sure that the angle unit (Rad, dgree, grad) is the one you want.
Hope it helps.
Sep 18, 2009 | Texas Instruments TI-30XA Calculator
51 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
