Question about HP PhotoSmart C5150 All-In-One InkJet Printer
Error message: ink device failure oxc18a0506
I've tried HP's suggestion of powering the machine down; removing the ink cartridges; waiting for 2 minutes; replacing the cartridges; powering on machine.
This did not work. When I turn on the printer, the display screen does a short boot up and then the warning exclamation mark is lighted and the message appears on the screen.
  • 159 Answers
Perform the following on your printer http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Posted on Mar 15, 2010
HP Photosmart C6288 Ink System Failure
Turn off the machine, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, replace ink cartridges. If this doesn't clear the error you may need to re-prime the ink lines to fix it. Instructions for doing this are at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Mar 14, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hp3210 ink system failure
Turn off the machine, unplug the power cord from the back of the machine, remove ink cartridges, wait 2 min, plug power cord back in, press on button, wait until the printer prompts you to replace the missing ink cartridges, then replace the ink cartridges. If this doesn't clear the error you may need to re-prime ink through the lines. There are instructions for doing this at www.ccl-la.com/blog/. Search for HP Photosmart and run through the "ink system failure" #1 instructions.
Mar 07, 2010 | HP Photosmart 3210 Printer
Ink Failure on HP photosmart premium C309g printer
Turn off the machine, unplug the power cord from the back of the machine, remove the ink cartridges (lift the lid up at the base of the control panel), wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime the ink lines to clear the error. You can find instructions for this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Mar 03, 2010 | HP Photosmart Premium C309A All-In-One...
Have a hp 3310 it says ink system failure error 0xc18a0106 it wont print,scan,copy and it does have enough ink. thank 4 ur help
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error then you may need to re-prime ink through the system to clear the error. There are good instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Feb 20, 2010 | HP Photosmart 3310 All-In-One InkJet...
HP Photosmart C6280 printer won't print and displays Ink System Failure message and Error #0xc18a0001.
Hi there
0xc18a0001.
Try the following steps to remove HP Printer Error Code 0xc18a0001.
I have put 3 ways for you to try.
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Or try 2
Turn the printer and wait until you receive the error message.
* Simultaneously press the keys "9" and "#" printer.
* While holding the button down, unplug the power cord from the unit.
* Wait a few seconds.
* Still holding the button down, reconnect the cable and turn on the printer.
* Release the buttons.
Or try 3
* Turn the printer and wait until you receive the error message.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP c6150 all in one error message Oxc19acff Ink System Failure. Replaced Yellow ink cartridge an still receive error.
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the power button to turn on the machine, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime ink through the system. There are instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jan 30, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, turn the machine on using the power button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error you may need to re-prime ink through the system. There are instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jan 16, 2010 | HP Photosmart 3210 All-In-One InkJet...
Ink system failure. How do I reset a hp 8250 printer?
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the power button to turn on the printer, wait for the printer to prompt that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error you may need to re-prime the ink cartridges. There is a good explanation of how to do this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Nov 15, 2009 | HP - HP Photosmart 8250 printer
I have a 13 month old HP Photosmart C5180 which is now displaying the following error message, "Ink System has failed. Unable to print.." Error: Oxc18a0506. The help message suggests "turn power off then...
your second set of catridges mush help you,, and also,, it seems that your operating system is corrupted,, its better you reinstall the printdrivers first,, if problem persists,, then try reinstall of windows..
Sep 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
Ink sys failure error message
Try the following steps and check if it resolves the above error.
1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Print a Self Test to verify product is functional.
9. Reconnect the USB cable, and try to print from the computer.
Wish
Aug 01, 2009 | HP Photosmart D7160 InkJet Printer
HP PhotoSmart C5150 All-In-One InkJet Printer Logo
388 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
