Question about Sony PlayStation 2 (PS2) Console
Controller interface problems with playstation2
I have a logitech controller and a phoenix controller for playstation2 set.  I can use the logitech without problem.  Can't use the phoenix with it.  Any help would be appreciated.
  • 80 Answers
Phoenix controllers have never reallly worked with playstation console which is why the majority of retailers have pulled them off the shelves. Your best bet would be to return the controller and get another logitech controller, or a Mad Catz controller.
Posted on Jun 21, 2009
HU8643773
Here is what I have for that model of PS2.
The 128-Bit Emotion Engine is the first chip of its kind. No other mass-market computer technology on the market comes close to its power. In the PlayStation2, this chip is used as the workhorse of the console. It processes all physics and math calculations.
The PlayStation2 has a 128-Bit Emotion Engine. The 128-Bit part of the title means that this chipset both processes information and sends it over a 128-Bit bus (A Bus is the pathway between chips on a circuit board. A wide bus carries more bits of information and is thus faster than a narrower bus).
You may think that your PC has a faster processor, but remember that the Emotion Engine has inherently faster 128-Bit processing and it is just a part of the overall PlayStation2 power.
A small note for the really detail oriented: The reason that the speed is 294.912 MHz, is that it must be a multiple of a required processor speed that supports the DVD ROM operations.
* Dimensions: 301mm (W) x 178mm (H) x 78mm (D), (12" x 7" x 3").
* Weight: 2.1 kg (4 lbs. 10 oz.).
* Media: PlayStation2 CD-ROM, DVD-ROM, and PlayStation CD-ROM, CD Audio
This means your PlayStation 2 will basically play all your old PlayStation games (but not make them look any better), all music CDs and all North American DVDs.
* Interfaces: Controller Port (2)
These are the same as the controller ports on the current PlayStation.
* Interfaces: Memory Card Slot (2)
These slots are very similar to the ones on the original PlayStation, except they support the new, faster transfer rate.
* Interfaces: AV Multi Cable Output (1)
This is where you plug the cord that goes to the back of your television.
* Interfaces: Optical Digital Output (1)
This port will let you send data directly to a digital receiver. This is perfect if you plan to plug your PlayStation into a DTS or Dolby receiver and get perfect sound.
If you don't use digital output, your data will be converted to an analog signal and then be converted back to digital at the receiver.
* Interfaces: USB Port (2)
USB enables you to connect any number of devices to your system with a high-speed data link.
* Interfaces: I.Link (IEEE1394) (1)
The IEEE139 port is known by two names: I.Link and for Mac owners, FireWire - there are some minor differences between the two. This high-data transfer port has the advantage of supplying (some) power to devices that are connected. You can expect that an enormous number of hardware devices will use this port including speakers, printers, and other like devices.
* Interfaces: Type III PCMCIA Card Slot.
This slot is a lot like a laptop's add-in slot. Here you will be able to plug in a modem and eventually the connection for Sony's planned broadband network and hard drive.
Jul 28, 2014 | Sony PlayStation 2 (PS2) Console
Offline status
The most likely cause for this OFFLINE status on the PC is which interface is selected on the printer.
I think the printer defaults to Serial interface, so if you are using USB ensure you select the USB interface via the control panel on the printer, similarly if the connection is parallel ensure the parallel interface is selected.
If the connection is serial, ensure the cable is of the correct pin configuration and ensure the serial interface is set up correctly.
May 25, 2012 | TallyGenicom Tally 5040 Passbook Matrix...
Speaker Logitech S-0264B not working with windows xp
if your computer came with a motherboard disc the sound drivers could be on it
if you dont have a motherboard disk you will need to download the sound drivers
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
Mar 13, 2012 | Logitech X-240 Computer Speakers
How to set Clock for S00067
The manual can be downloaded from the Logitech Website. The link at the bottom of this post is where the manual can be found for your unit or click on this link (you need Adobe Reader to view it which can be downloaded for free)
http://logitech-en-emea.custhelp.com/ci/fattach/get/502116//session/L2F2LzEvc2lkL21ReUpSR0Fr
Logitech Pure-Fi express Plus page:
http://logitech-en-emea.custhelp.com/app/answers/detail/a_id/10300/section/troubleshoot/crid/439/lt_product_id/4781/tabs/1,3,2,5/cl/gb,en/kw/
To set the clock as per above manual:
1. Press and hold the clock set button (the hour will blink)
2. Use control knob to adjust time hours (PM will indicate if not then AM is default)
3. Press clock set button once which will confirm hours and advance to minutes setting (the minutes will blink)
4. Use control knob to adjust minutes
5. Press clock set button once to confirm time set
6. Clock settings now complete
Aug 04, 2011 | Logitech Pure-Fi Express Portable Speaker...
Just bought this from an individual who knew nothing about it. Scooter is in excellent condition however it has been sitting for a bit. The problem is the scooter only goes forward when in the High speed...
Jade
This model Drive Phoenix 3 wheel is found for sale at pharmacies and is subject to floor model abuse.
Most common abuse is not recharging batterys and letting them sulfate thus
reducing life of of charge.
I have found that the foward and back-up levers have been bent
by people sitting and squeezing both levers at the same time. the resulting misshaping of the levers results in a very slow speed comand to the controller because of limitted movment of speed control. The result is that main control (turtle/hare) must be advanced to fast (hare) position to get scooter to move.
I have had success straightening levers by carefully bending them in opposite direction on my Phoenix 3W ( which was a clearence item with no warranty.)
The real (legal)solution is ordering a new lever having a technician
replace it so as not to void warranty.
Hope this helps....jth1939
Apr 02, 2011 | Drive Medical Phoenix 3 Wheel Compact...
We have a Logitech Harmony 890 remote; we are snowbirds and unplug our system when we leave our vacation home from April to Nov. Upon returning this past week and plugging everything back in, we have...
Your best option is to contact Logitech for a replacement battery. If you click on the link below, you will find
a troubleshooting guide for charging problems with the 890 remote:
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/9169/kw/charging
This page also contains all of the information you need to contact Logitech support. Sorry, there is too much information to paste it all here.
Hope this helps.
Please rate this solution if you find it helpful. Thanks
Nov 03, 2010 | Logitech Harmony 890 LCD Remote Control
Software set-up
I had that problem a few years ago and it turned out to be a bad remote in the usb section. I called Logitech and they replaced it. I think they have a lifetime warranty, right? Check it out.
May 27, 2009 | Logitech Harmony 880 LCD Remote Control
Promblem
Normally there is no reason to re-calibrate the Logitech Cordless Action Controller for PlayStation2. In rare cases where the mini-joysticks may need to be re-calibrated, you can use the process below. Please note that this process only works for the Logitech Cordless Action Controller for PlayStation2.
  1. Remove one battery.
  2. Hold the L1 and L2 buttons while re-inserting the battery. (NOTE: Do not touch or move the mini-joysticks at all during this time. It is very important that the mini joysticks are allowed to center themselves during this step or the calibration procedure will not be successful.)
The mini-joysticks should now be re-calibrated. Please note that in some cases you may need to resynchronize the gamepad and receiver after this procedure.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=1414
Aug 13, 2007 | Logitech Cordless Action (9633200403) Game...
Keyboard crescent key
the crescent key is called a sleep key. The Sleep key is used to put the computer into ACPI state G1 Sleeping from ACPI state G0 Working. The Advanced Configuration and Power Interface (ACPI) specification is an open industry standard first released in December 1996 developed by HP, Intel, Microsoft, Phoenix and Toshiba that defines common interfaces for hardware recognition, motherboard and device configuration and power management. According to its specification[1], "ACPI is the key element in Operating System-directed configuration and Power Management (OSPM)". try wikipedia.org to find out about g1 nd g0 hope this helped
Jul 30, 2007 | Logitech Cordless Desktop MX 3000...
Sony PlayStation 2 (PS2) Console Logo
93 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
