Question about HP OfficeJet V40 All-In-One InkJet Printer
I can't print a invitation on my hp printer 4630
Im trying to pring a invitation from wilton print wizard website and my printer hp 4630 can not take the paper
SOURCE: paper mismatch
Hi kingwa55,
I have an hp photosmart c4480 and was having the same problem printing wedding invitations. Same size 5.5"x8.5'. Im not sure if this will work on your printer, but this is what I had to do.
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print, properties,features, click the drop down box under sizing options.
Click more and scroll to the bottom and it should be there.
If your options are different then mine, I'm sorry for wasting your time.
Posted on May 13, 2009
  • 6 Answers
SOURCE: Paper mismatch error
I got around this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Posted on Jun 27, 2009
  • 6 Answers
SOURCE: Can't Print Invitations
There is a workaround for this problem by tricking the printer.
Deny
vanherringto
  • 1738 Answers
SOURCE: HP PSC 1310 reads paper jam in control panel. There is no paper i
Click this link to solve your paper jam problems with your HP printer:
http://bit.ly/9ShIi2
Posted on Feb 09, 2010
SOURCE: How to print 5 X 8 invitations on an HP Photosmart C309a printer
I think it's more or less the same on Mac or PC. Hit Print in your software, then when the dialogue box comes up you should see several options settings. There will be a pull-down menu that lets you choose paper size. (This menu is sometimes buried in another sub menu called "printer options" or something similar. It can be tricky to find this in some apps like Photoshop). Just select your 5x8 size and then at the top of the dialogue box you should be able to save it all as a preset. Pull down the "preset" tab and select "Save As..." then you can name it and pull it up each time later.
Hope this works.
Posted on Mar 28, 2010
How do I make the text larger on my office jet 4630 printer
This is the font setting in the application.
Make sure the font is at least 12.
(I am assuming the default settings in the printer setup.)
Oct 25, 2015 | HP Officejet 4630 Inkjet Multifunction...
How do I copy 2 sided copy from 2 sided original on hp Officejet 4630 e- All-in-One Series
copy one side, then take copy and put back into blank paper try and then copy other side. trial and error will tell you how to put paper in paper tray but usually printed side up, top in
Sep 18, 2015 | HP Office Equipment & Supplies
HP Office Jet 4630 E-All in One. Installing to print from 2 computers via wireless network. Wont print from 2nd computer.
It's some kind of communication error. I would suggest uninstalling the printer from the second computer. Also, make sure you go to the website for that printer and download the latest driver that was designed for Vista 32bit. If you are using the included software disc it may not have the latest driver updated that fixes this problem.
May 07, 2015 | HP Office Equipment & Supplies
Where do ink cartridiges go in an HP 4630 printer?
Download user guide from below link, you can understand how to load.
http://h10032.www1.hp.com/ctg/Manual/c03909822.pdf
Aug 25, 2014 | HP Officejet 4630 Inkjet Multifunction...
Does not pring
I assume you have new or near new ink cartridges?
Make sure you use genuine HP replacement cartridges.
Maybe try cleaning the print heads, which you can usually do direct from the printer.
Oct 20, 2012 | HP Photosmart Premium C309g multifunction...
Printer sends error message HP p2015
As mentioned above, install the universal PCL 5 drivers from HP website. This will fix the error.
Feb 23, 2009 | HP LaserJet P2015 Printer
Paper mismatch
Hi kingwa55,
Click on custom
Then Click
Apr 23, 2008 | HP Officejet 6310 All-In-One InkJet...
Print Size
you have to choose the paper type in the printer driver option wheather envelope or A4 paper see the preview before printing
Mar 22, 2008 | HP Deskjet 3915 InkJet Printer
HP OfficeJet V40 All-In-One InkJet Printer Logo
377 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
