Question about Frigidaire FGFBZ90GC Stainless Steel Kitchen Range
Frigidaire fefbz90gc stove--the left front burner which has the bridge element turns itself on spontaneously. The stove beeps and the numbers above the knob for that burner change up and down. I had a service call while it was still under warranty but the service person told me it was impossible for that to happen and he could not recreate it. I have to turn the circuit breaker off when I am not using the stove, as this is a safety issue.
4 Suggested Answers
  • 23 Answers
SOURCE: Frigidaire FGF378AC Gas Stove
There are 2 possibilities:
1) Are there 2 knobs to control the oven? If so, they may be switched.
2) Depending on the thermostat used, it may be possible to put the knob on upside down.
Posted on Jan 23, 2008
tony2155
  • 64 Answers
SOURCE: Front left dual element on a Frigidaire ceramic
open the door and look under the top remove the screws and the top will lift
Posted on Jun 23, 2009
  • 105 Answers
SOURCE: The right front element will not heat properly on
Without a proper model number I would say you need to replace the element or the infinite switch for the element. Best off to call a reliable repair company such as Sears.
Posted on Jan 31, 2010
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
The left rear stove element went on High and would not turn off by controls, why? There was an F550 code that came earlier with the oven?
My range was doing the same thing. I finally called the Consumer Protection Agency and reported it. It launched a national recall. With their help, Frigidaire replaced my range. On Easter 2014, the new one did the same thing. Burner turned on by itself, to 8.5 with knob in the off position. We had to unplug it. Frigidaire once again did not care. I contacted the CPSA again - they are investigating. I will NEVER have another Frigidaire Range. Check your model number against the recall information. Don't trust it! It is a fire hazard.
Feb 06, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Could this be a User Interface,Board 316239500 part problem? or a Electronic Control Board part problem?
Normally, the E.O.C. (electronic oven control) only controls power the ehe bake/broil side for the oven. Doesn't control power to the element. If you have already replaced the infinite switch to that eye, the element itself could be faulty. There is a sensor inside the element that is supposed to communicate with the infinite switch to determine the proper cycling temp for what you selected.
Jan 31, 2013 | Frigidaire GLEF396 Electric Kitchen Range
Frigidaire model FEC30S6ABF front burner wont turn off
Hi - From what you have described the range could possibly be experiencing a faulty element/sensor or the communication to the element from the control board is now compromised. If you are referring to the left front element, the part number is 318178110/MSRP: $65.86. Right front element, part number 316224201/MSRP: $89.60. I would suggest contacting a professional to move forward accurately and properly diagnose the range.
Oct 18, 2012 | Frigidaire FEF336BC Electric Kitchen Range
Heating element stays on when turned off
The thermostat (that is the dial that you turn to energize the heating elements) is the only thing that connects power to and disconnects power from the heating element. It is bad.
You can unplug the unit and remove the thermostat. Take it to a parts supplier and get a new one and install it. Your problem will go away.
If you would like to see a wiring diagram...click on this link:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255301.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 15, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
Jul 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
My right front burner will not turn off on my electric stove top.
Its probably the switch for that element, the contacts are fused. If this is a smooth top ceramic stove then the control relay board relay for that element is stuck.
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore electric stove model c880.6383880 left front burner does not work....it is not the element itself as it heats up on another burner.
hi,
sounds like you have the old-style coil elements on you stove.
your problem is the switch under the element, called the infinite switch. i would suggest to have a technician replace it. they usually charge for the labour but if you have never done it before, it's money well spent.
Aug 19, 2008 | Stoves Kitchen Ranges
Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove.  Must be a constant 220.  Let me know what you find.
Oct 15, 2007 | Frigidaire FED300AS Electric Kitchen Range
Frigidaire FGFBZ90GC Stainless Steel Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
