This CD player is part of a Mitsubishi E-63P Audio System. I realise that it is old,but it is a wonderfull unit. The Laser needs replacing in the DP-47P CD player. I have been told another new laser is not available. Surely ther must be a compatable laser that could be used. I trust you can help me, i.e. part numbers and where to purchase Regards, Norm. Sydney Australia Norman.L@Bigpond.com
  • 1 more comment
  • norman_l Jun 18, 2009
    If you have a manual,then why not get the part number and see if Mitsubishi in the states or Japan can offer a laser that would be compatible.
    I am a long way away in Australia,and believe that the inquiries that I have made here have been put in the too hard basket.
    In these Hi Tech times there must be an equivalent laser.
    How about helping an old chap.
    The product is CLASS 1 Laser & complies with DHHS 21 CFR sub chapter J part 1040:10.This information is from the manual that I have.
    The manual is not the issue.
    Issue is what is a comparable Laser and what is the part number,and where is it available.
    Regards
  • norman_l Jun 21, 2009
    Yes very good
  • 790 Answers
Hi
This is the site for all you need to buy your pick up lens Clickhere; www.alibaba.com/showroom/Laser_Pickup.html many supplier are available for your needs.. just tell the brand and model to the supplier..
Thanks!
Posted on Jun 18, 2009
Hello
I've had a hard look to find any part numbers or replacements for this model but unfortunately could find anyone providing this information. I'm not sure if this will assist, but I have found a manual which may have the part number listed.
The manual can be purchased here, and they will send you the manual by e-mail as an electronic copy which you can see on your computer. I hope it will be of some help.
Best of luck.
With regards
nLinked
  • Anonymous Jun 18, 2009
    Thank you for your reply, Norm.
    I understand you concerns and have just tried again very hard to find the manual for free. I don't have this one with me. I can only suggest purchasing the one found online. There seems to be no-one giving out the manual for free for this model.
    With regards
    nLinked
I have an old SHARP mini component systen and everything works except the CD player. It says ER CD-10
Laser assembly is probably ng and that part of unit needs replacement if it is not a proprietary design. If so, forget it since it will not be cost effective.
Aug 28, 2017 | Sharp Audio Players & Recorders
Cd inserted in cd player no disc
The problem is in the laser pickup assembly, overtime the laser becomes weak until it will no longer read the disc, it is far cheaper to replace the stereo than have the old unit repaired.
May 01, 2012 | JVC MX-GT80 Shelf System
I have a philips hts6510 home theatre system and when i put a dvd in to play it says no disc
hi,
Normally a dvd player shows the message NO DISC when,
1. The disc inserted is bad.
2 The lase pickup unit inside the dvd lost its reading intensity, dirty lens or the spindle motor damaged .
In your case the second one happened. the intensity of the laser pickup unit has lost or the spindle motor faulty or there is some dust on its lens. just insert a cleaning cd in it for two or three times. then check again is the DVD is reading or not
if the problem remains then you have to check the motor and the laser pickup unit. the lase pickup unit have two laser emitter and receiver in its inside . one for reading and playing DVDs and the other for CD and MP3. also the spindle motor runs in different speed when u insert dvd and cd.
Open the cover of your dvd player and power it on insert an audio cd and watch is it reading or not also notice the speed of the spindling of the cd. if the audio cd reads and play. then the possible problem is the spindle motor
To conform it remove the audio cd and insert a dvd. watch the rotation of the dvd. if it feel very hard to rotate it then, the spindle motor is damaged. if so replace the spindle motor if it runs more the the speed of than audio cd then the laser pickup unit is faulty. Then u have to replace the laser pickup unit.
if you need any further assistance from me , feel free to contact me through fixya.
ok
Jan 16, 2011 | Philips HTS-6500/37 System
Cd scraping when played
hi,
did u mean skipping in audio. then ur cd players laser pickup unit have some problem. just try to clean the lance of laser pickup. for that u can use an ear bud. do not use any solutions only ear bud.do no give pressure on the lance. clean gently. after cleaning try again. if problem remains u should replace the laser pickup unit.
ok
Dec 22, 2010 | JVC FS-2000 Shelf System
My bose wave multi cd player will not play discs, error code comes up. Only 1 year old.
hi,
may be some mechanical problem or laser pick up unit have some problem. is better u should replace the same, for maintaining the audio quality.
ok
Dec 17, 2010 | Bose Wave music system Multi-CD Changer...
My one-year old Marantz CD5001 CD player
these models use the 12.1 philips laser mechanism and it is a very common problem for failing to read discs.
various technics / marantz / philips / cyrus cd players etc also use it and are plagued with the same fault.
it's a 90% chance the laser is dead!
philips realised the unreliability of this laser and uprated it to the identical looking VAM-12.
do not dismiss the spindle motor as these also fail quite alot on this mechanism.
hope this helps.
Dec 20, 2008 | Marantz CD5001 CD Player
RS 2653
I had a rca system similar to this little different. It's a problem you'll find in any cd player after awhile. You'll need to replace the laser. It's quite easy google for some instructions to replace a cd laser. Look around for a laser that can read cd's and cd r and cd rw and you'll be ok. The disassembling might be a bit tuff but it's worth it. I had to replace my hifi laser and after i did sound was incredible again no skipping. Make sure when opening your system you power it on and unplug it to make sure all charge is gone wait 30 minutes or so before you go and operate.
Feb 10, 2008 | RCA 100-Watt Stereo System With 5-CD...
Kenwood Car Audio system model no. KDC-X8529
Mnay things can stop a CD player from reading.... Try cleaning the LASER LENS in the unit(you may have to remove it from the car) with a cotton wool bud soaked in Windex glass cleaner. Then use a second (fresh, dry, and clean) cotton bud to remove any residue film(left from your cleaning procedure). If this does not work, then the unit may need some detailed diagnostic work done to determine what is wrong, or if a laser replacement is needed. REMEMBER Repairs are worthwhile, only if yo have a good tech!!
Dec 27, 2007 | Kenwood eXcelon KDC-X759 CD Player
CD player
It may be power problem/Lens cleaning
Dec 09, 2007 | Audio Players & Recorders
70 people viewed this question
 Grubhead
Grubhead
