Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
How to remove the icemaker from Kenmore refrigerator 795 58813 900
5 Suggested Answers
Greg20
  • 149 Answers
SOURCE: How to install Kenmore icemaker
2 screws on top of icemaker into wall (loosen almost all way) 1 screw bottom remove. pull IM up and off of 2 screws and disconnect wiring plug from IM (depress tab). reinstall in reverse.
Posted on Jun 12, 2009
milten1
  • 1304 Answers
SOURCE: Refrigerator icemaker won't work and refrigerator fills with wate
check your fill tube you might have an ice build up on the end
the fill tube is where the water dumps into the ice machine
Posted on Oct 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: I want to remove the icemaker from a kenmore elite
Remove the outer trim.
It is snap-fit in place.
Start in one corner and work around.
Then the rest is simply un-screwing the fountain and unplugging the wire harnesses.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
woodchuck789
  • 4059 Answers
SOURCE: How do you remove the
The ice maker hangs on the wall with three screws. two at the top and one at the bottom. Just loosen these screws and the ice maker will lift off the bracket and you can then reach the wiring harness to unplug it. You may need to melt some ice with a hairdryer first.
Your water inlet valve on the back is probably stuck open and need to be replaced.
Posted on Sep 04, 2011
Why did it stop working?
How to Fix an Icemaker-EASY ICEMAKER REPAIR - YouTube
? 3:52
www.youtube.com/watch?v=4Lmpy--Rz2I
Aug 18, 2012 - Uploaded by n4ktz If you have a Kitchenaid, Whirlpool, Maytag, Estate, Roper orKenmore Refrigerator/Freezer and the Icemaker ...
Jul 31, 2015 | Kenmore Refrigerators
Removing ice dispenser motor cover from kenmore elite 1065779701?
I am having trouble getting the icemaker out of the refrigerator. Am I supposed to just be able to push up the little clips and it will release. I can get the left one loose but not the right one as I face the icemaker in the refrigerator.
Buy Custom Car parts.
Jun 02, 2012 | Kenmore Side by Side Refrigerator
How to take out old ice actuator on Kenmore fridge
The easiest thing to do is remove the icemaker first. Ujnplug your fridge first, though. Take a 1/4" nut driver and remove the screw at the botton of the icemaker. Then loosen the 2 screws on the topside of the ice maker. You'll be able to see the back screw, but the front one is kinda hidden....you'll have to use your fingers for eyes on that one! Lift up on the icemaker and it should come free from the screws. Disconnect the electrical plug, being sure to release the little latch on the side of the molex plug.
Now you can work on the icemaker....there is a white plastic cover over the end of the icemaker, pull that off and you can start to see the guts of the icemaker. There are 3 phillips head screws holding the motor module on, and the rest of it can be torn down from there. Good luck!
Aug 13, 2010 | Kenmore 57029 Side by Side Refrigerator
Replace icmaker on kenmore
Unplug refrigerator. Take a moment to examine how the icemaker is positioned in the freezer compartment prior to proceeding (e.g.: water inlet tubing coming into the icemaker, etc.). Remove or loosen (where applicalble) screws holding icemaker. Unplug icemaker's wire harness connection. install new icemaker by reversing the screws harness, etc. Make certain that the new icemaker is in the "on" position. Plug the refrigerator in. Allow approximately 6 to 8 hours (some models take fewer or longer timeframe) for ice production.
Feb 10, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Kenmore side by side refrigerator model 106.5686*601 is leaking water from the ice maker inside the freezer.
Icemaker leaks are common and cannot always be solved. May need a new Icemaker. Ofter you can obtain a kit from Lowes (use a Whirlpool kit.)
Aug 23, 2009 | Kenmore Refrigerators
Ice maker stopped making ice
Pour about 1/2 cup of water into icemaker . If it dumps , replace the water valve . If doesn't dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
Icemaker not working after installing new filter
I have a Kenmore 106.56542400 icemaker stoped working ,water line is cleared not getting water to icemaker
Jul 02, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Jun 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water and Icemaker do not work
Sounds like you need a knew water valve. It is located on the back lower left corner of the fridge.
Jan 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
24 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
