Question about GetYourGiftHere Baby Gear
Ring A rhodium plated single stone "garnet" setting sz 5 ring w/CZstones on top of band I bought from you in early Feb 2013
SOURCE: lengthen my ring time
hello you need to go into your settings then click on divert, it will say your settings are on divert:if unavailable thats why your phone call cuts off if you havent answerd it in a certain amount of time. So just turn divert off completely and your fone will ring longer
Posted on Jan 23, 2008
  • 43 Answers
SOURCE: Microwave plate doesn't fit on cog?!
I know this is probably DUMB of me to say, But some with this type of turntable arrangement, The ring would only set one way. The ring did not turn, but rather the wheels faced up and rolled with, and supported the turntable.
Posted on Jan 26, 2008
Bajanguru
  • 7752 Answers
SOURCE: Pantech C120
change the speaker on the phones and also have the ringer check on the main-board.
Posted on Jun 24, 2008
  • 14 Answers
SOURCE: night ring
The manual day/night switch can be made from the operator ext (usually 101). This will over-ride the preset schedule.
Press:
[SHFT], [FEAT], scroll jog dial until you see Night Mode, [SEL], then press [0] for night or [1] for day.
To change the automatic start and stop time is, indeed, a phone guy (or gal) function.
Page 4-33 in the System programming manual.
Posted on Jun 27, 2008
sodeep
  • 3267 Answers
SOURCE: cant get the phone to ring. it is set to vibrate & ring but only vibrates
Set the ******** off and see if it rings otherwise try any ringtone as your default callertune and observe if the speakers ring. If not then best to take it to a technician...........sodeep
Posted on May 04, 2009
My calls go to voice mail
How to stop iPhone calls going straight to voicemail - iOS 7 tip
www.macworld.co.uk/.../how-stop-iphone-calls-going-straight-voicemail...
May 28, 2014 - Do your iPhone calls go directly to voicemail? ... I don't remember setting my iPhone to Do Not Disturb, and it appears nor do most people ...
iPhone 5 calls go straight to voice mail ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Dec 25, 2013 - Madman, your advice solved the problem on my wife's phone. It wouldgo to voice mail very often, seemingly for no reason. When I'd call again, ... iphone 6 going calls going directly to voice mail
Jul 20, 2015
My iPhone doesn't always ring, why?
Oct 28, 2013
calls going straight to voice mail
Feb 24, 2013
Calls going Straight To Voicemail
Jul 3, 2010
More results from discussions.apple.com
Troubleshooting Calls going straight to
Dec 30, 2015 | Cell Phones
Not getting an answer to why I havent received my item
Is this the place? you might try the phone number.
Classic Jewelry.
One Galleria Parkway 1C-7B, Atlanta, Georgia 30339,
phone (770) 690-8629.
Email : info@classicjewelry.biz
Feb 27, 2015 | Clothing Accessories
Complaint
so why are you complaining here?? this is a repair help site.
Jul 11, 2017 | Microwave Ovens
What do jewelers use to resize a 14kw ring
It depends on many factors. First do you want to make the ring a larger or smaller size? To upsize, a special tapered mandrel in a press is used to expanded the ring from the inside. Metal can stretch only so far, then you must cut the ring at some point and braze more gold into the gap. To down size the ring, a special ring press can be used to squeeze the ring from the outside, forcing it into a steel die.
If there is a stone on the ring, this does not work because the stone is in the way. In that case a jeweler will have to cut the ring and remove material, then braze it with gold to reconnect the pieces after the ends are pressed together. With either process of enlarging or reducing, the jeweler will have to use additional tools to bring the ring into roundness and will have to do final polishing and cleaning.
Jan 29, 2014 | Bella Findigns House 14kw 7 5mm ring size...
What is the difference between wedding rings engagement rings?
You can go for non field mesh rings, which - similar I said- are exploit increasingly famous when it comes to work and wedding rings. First choices are emeralds, rubies, sapphires, quartz and amethysts but Swarovski crystals are healthful options too because it is popular and can be molded in any designs you require. Stones specified as garnet and opal are both of the gems which are now also situated at the place of meshing bands because of its fascinating look.
Non Diamond Engagement Rings
Dec 20, 2012 | Clothing Accessories
I have Kohler single handle shower, but the handle does not have a screw to remove it. How do I remove the handle. The handle was installed in the house in 1999. Thank you.
Ok I am take a stab at this. If it is a L shaped handle it is not steel but an aloy and at the end of the long part of the handle is a end cap that either screws off or pops out when pry on. The set screw should be in the handle under that.
If that is not true then the set screw has to be somewhere around the base of the handle near the shower cover plate maybe headen under a little cover that would look like a small push-in cap.
Feb 05, 2011 | Plumbing
I purchased a wedding ring and band and it is discolored supposed to be gold but it fading and I am trying to get a form of some sort I have a smart protection plan what do I do now it was purchased like...
Thanks for contacting FIxYa.
Is it a white gold wedding band?? You dont mention what color it is. If it is yellow gold turning white, then its not solid gold. If its white gold turning yellowish, then it needs to be re-rhodium plated which most jewelry protection plans will cover. You need to go back to store where purchased to find out.
Best regards. Jewel
Sep 08, 2010 | Watches
Rolling Stones Rock Tumbler - no rubber ''O'' ring
Nothing high tech here. Try it without the o-ring. If the water does not start to leak out in the first 3 to 5 minutes of tumbling you will be ok. Stop it every day to check the water level.
Set the whole thing on a cookie sheet in case it does leak when you are not watching - you don't want a bunch of rock dust and polishing grit on your table or floor in the morning.
You will not damage anything by trying it without the o-ring.
Mar 18, 2010 | Rotary Thumlers Tumbler Polisher...
Baby Gear Logo
66 people viewed this question
Top GetYourGiftHere Baby Gear Experts
Dorel UK
Dorel UK
Are you a GetYourGiftHere Baby Gear Expert? Answer questions, earn points and help others
