Question about Dell Computers & Internet
Broken dc port - Dell Computers & Internet
    Problem Solver:
  • 83 Answers
Hi
you have two options
1. Replace the main board or cable that connects the motherboard that depending on the model of your laptop.
2. Use the dork station or port replication
Posted on Jul 23, 2014
How to replace charging port
Gateway Nv57h73u notebook jack issue check:
1) more common issue is changer ( ac adapter) DC core broken inside, please change a adapter to fix. also you can repair adapter DC core wire. if still no charging that could be DC jack issue inside notebook.
2) disassembly keyboard and top cover of your laptop looking for a wire it connect to the DC jack, check is the wire broken close to the jack soldering pot. you can soldering it to fix, or other issue is jack damaged, you can order and change the DC jack with wire easily, the parts see picture
Oct 20, 2014 | Gateway Nv57h73u With Autodesk Maya...
Msi wind broken dc power connector port
1) http://www.bit-tech.net/hardware/laptops/2008/07/05/breaking-wind/1
2) http://www.radioshack.com/product/index.jsp?productId=2103245
3) http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
[You don't need a Soldering Station though. Use a 25 Watt soldering iron, or so. Rosin core solder, Rosin flux paste, etc ]
4) http://laptopjacks.com/product/MSI-Laptop-DC-Power-Jacks.html
So, who is going to do the job?
Post back in a Comment.
Regards,
joecoolvette
Mar 14, 2013 | MSI Wind U100 Netbook
My laptop charging port is not working problem. I have to wiggle it about and selotape it into place for the computer to charge. What do you think is the most likely cause the port its self or the charger?
I think it is because of the loose dc jack. So
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place....
http://www.chargerbuy.com/laptop-ac-adapter/samsung-compatibility.html
Oct 29, 2012 | Samsung Rv511
Where can i buy a gateway m 7818u charging port?
The proper name is DC Power Jack. May be marked as DC_IN on the laptop.
Just from a quick search,
http://www.aliexpress.com/product-fm/406129021-Free-shipping-DC-Power-Supply-Jack-For-Gateway-MD7818U-MD7822-MD7818-Acer-Aspire-5532-5535-ONE-wholesalers.html
(First one I saw was $59)
Need guidance in replacing? Post back in a Comment.
Regards,
joecoolvette
Jul 21, 2012 | Gateway M-7818u 15.4" Notebook PC - Avalon...
Gateway solo 1450 laptop will not power up.
1. remove main battery and test with just ac charger.
2. test ac charger with multimeter or test notebook with good charger.
3. remove any memory, then test each stick once at a time in each slot.
4. if only 1 stick, get and test with a known good stick, in each slot.
5. plug into external monitor and then power on to test if its a screen issue.
6. clear bios - usually by removing main AND BIOS battery, wait 5 mins.
7. remove all hardware - hdd, odd, wlan, modem, etc and test.
8. remove mainboard, reseat cpu, benchtest
9. test power is getting past DC port - ie, DC port is not broken...
if fails on bench after clearing bios, reseating cpu, with different sticks of memory tested in each slot, with a known good AC charger, and dc port is undamaged, the board is faulty.
hope this helps.
May 19, 2012 | Gateway Computers & Internet
My notebook 2133 is completely dead charger is working ok I think its the battery
Im very sorry to hear that,For you to be able to isolate the exact problem, try to do these steps. Removed the battery then connect the laptop directly to the power outlet then power on the laptop, if the laptop turn on, that means that the AC adapter is working fine if not, theres a possibility that the problem is with the AC adapter or the DC port on the laptop itself.If the problem is with the DC port on the computer itself,it maybe loose or totally broken, If its the DC port itself, you will need to replaced the Motherboard or lets just hope that its just the Base Cover that needs to be replaced...
Hope this will help...Your response is very much appreciated...
Jan 24, 2011 | HEWLETT-PACKARD HEWLETT PACKARD PCDO...
The stinger from my car charger has broken off
this is very common problem with this and many model of magellans.
disregard the test for charging if you know your power port is broken and go to the bottom for further help
try the car charger2_bing.gif.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repair it here
or buy the power port here
if you need further help, just let me know.
Dec 13, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 5310. when pluging in th power
yes it can be fixed
you can go here for help
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
Oct 15, 2009 | GPS
DC input jack broken
you need to buy a new jack for replacement. then solder the broken one out of the mainboard and clean the place and solder the new one. or some acer have a separet jack then that one is easy only to change.
Dec 25, 2008 | Acer Aspire 5500 5570-2609 Laptop
DC input port broken.
Radio Shack can get it... Call 304 925 3992 and ask for John
Dec 10, 2008 | Amphion Mediaworks AMW M510
Computers & Internet Logo
56 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
