Question about Dryers
Our dryer is not heating up. It is working but
Our dryer is not heating up. It is working but only with cold air.
    President:
  • 512 Answers
Check the heating element. Also check thermal switches behind back cover. Check with a tester and make sure they work. If not replace and you should have heat again.
Posted on Jun 18, 2009
My dryer doesn't seem to function properly, it's just blowing cold air. I had it on for over one hour, my clothes are still wet and the air is still cold. The dryer model is LG Tromm DLG 3788W. The...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 24, 2010 | LG Dryers
The dryer blows cold air instead of hot air.
heatman101
Dec 11, 2010 | Roper RGX4634KQ Gas Dryer
Problem: the dryer is working, all the functions are good but there is no hot air, just cold air coming out. After few minutes of running "on cold air", it zeros out and stops like it has...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 28, 2010 | Siemens Dryers
Cold air
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 14, 2010 | Dryers
Dryer spins and drum turns, but only cold air c...
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
Dryer not releasing hot air
if its an all electric dryer then you may have an open heating coil or a bad contact on the timer that supplies power to the heating element .. a few dryers have a fuse that could be blown ..
if you have a gas dryer then you may have a bad solonoid that operates the gas valve .. or more likely a bad igniter .. thats a module that heats up or sparks to ignite the gas .. the igniter is a replacable item mounted near the gas flame. . the heated type fail frequently on some dryers ..
Aug 18, 2009 | Dryers
The tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Jun 07, 2009 | Zanussi TC7102W Electric Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Blows only cold air
Check connection to heating elements. My have bad heating elements
Jan 19, 2009 | Maytag Neptune MDE6800 Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
