Question about Siemens Gigaset S79H 8-Line Cordless Expansion Handset
Handset won't switch on letter icon flashes red
Flashing green light
hello,are you sure that you have not left your camera flash on,and virtually killed off the battery?as the zig zag icon usually refers to mostly flash related aspects of most modern cameras,all cameras need a certain base level battery power,before they will switch on for use,but may well display all manner of icon's and oddity's when the power is all consumed.hope that helps, cheers.
Jun 02, 2013 | Nikon COOLPIX P510 16.1 MP CMOS Digital...
That little icon with the letter A that shows how many copies you've selected, has a funny lookin red squiggly thingy that flashes as soon as it's turned on, also, it doesn't make copies.
the A and the funny looking red squiggly thingy that flashes is a paper miss feed or jammed paper. locate the A which is instructed on the machine. most probably from the paper tray and before reaching the conveyor unit. clean the feed rubber on located on the paper tray. this will help you remove that flashing red squiggly thimg.
Mar 09, 2010 | Office Equipment & Supplies
How do i set the flash on my vivitar cam. model 8025
Touch the lightning bolt icon in the function area until the flash icon and the letter A appears on the left side of the display. This activates the automatic flash.
Touch the lightning bolt icon again until the letter A disappears. This forces the manual flash mode.
Touch the lightning bolt icon again until the eyeball appears on the left side of the display. This activates the red-eye reduction feature.
To turn off the flash function touch the lightning bolt icon repeatedly until the no-flash symbol (lighting bolt in a circle with a line through it) appears on the left.
This is all described in the manual.
Jan 23, 2010 | Vivitar ViviCam 8025 Digital Camera
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Jan 26, 2009 | Palm Treo 755p Smartphone
How do I turn off the flashing light on the handset?
Just go thru the call log and look at each call, then the message indication icon in the lcd disappears and the red lights stop flashing on all the phones, but only after you have looked at each one and the message icon in the lcd goes away above each call.
Happy New Year
Jan 01, 2009 | Philips CD4451B/37 Phone
Envelope icon flashing on screen (not voicemail icon)
Try deleting some text messages in the in box this may solve the problem.
Jul 02, 2008 | Samsung Cell Phones
"DV IF" Flashing
To get rid of the DV IF flashing go to >menu>systems>DV control ...OFF. (page 63 in the instruction manual)
Mar 06, 2008 | Canon XL1S Mini DV Digital Camcorder
K800i Sony Ericsson Handset.
All of you need to hold down the power button and look at the Infa-Red port. Is it Flashing?
Yes: Flash the software on your phone.
NO
Seek professional advise from your service provider.
Nov 18, 2007 | Sony Ericsson K800i Cellular Phone
Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Oct 02, 2007 | Epson Stylus C86 InkJet Printer
Sony Ericsson phone
does it work when memory stick is not inserted?if not try software update available on se site
Aug 31, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Siemens Gigaset S79H 8-Line Cordless Expansion Handset Logo
109 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
