Question about Panasonic Workio DP-1820E Copier
Remove misfeed paper j33
How to fix problem
3 Suggested Answers
  • 100 Answers
SOURCE: panasonic workio dp-1810p
pls check out the sensor lever below the drum if it is freely moving.
because that is the sensor concerned for j33
Posted on Aug 21, 2008
  • 6 Answers
SOURCE: Panasonic Workio DP-2000 j33 problem
The sensor arm just below the registration roller has dropped the spring to return it to it's home position.
Posted on Apr 14, 2009
How removed misfeed indicated problem?
a miss feed mean the roller could not get the paper, so clean the roller (s) or have them replaced, try a different paper draw
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 25, 2014 | Konica Minolta Di2010 Di2510 Di3010 Di3510...
MISFEED INDICATOR BLINKING
DEAR SIR WHERE YOU REMOVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEASE CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Sharp AL 800 Copier
I have a Sharp Al-2040cs when I turn it on the misfeed indicator is blinking. I checked it there no misfeed paper or piece of paper inside. How can I fix this problem?
The MISFEED Indicator blinks when a MISFEED has occurred. Remove the misfed paper referring to the the description of MISFEED REMOVAL beginning on page 65 of the pdf Manual at:
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/cop_man_AL2030_AL2040CS.pdf
When the MISFEED Indicator is blinking you should look closer at the paper feed area (see page 66 of the PDF). You may need to remove the paper tray to find any remnants of paper. If after closing the side cover the light does not stop blinking you will need to follow through as per the illustrated instructions.
Remember after removing jammed paper, you need to press the clear key to clear the MISFEED error.
If after doing all this the error signal has not cleared, power down the printer; unplug from the power supply; let rest 5 - 10 minutes; plug back i to power supply; turn printer on and see if this resolves issue.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Sharp AL2040CS Digital Laser Copier,...
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    Ricoh Aficio CL3500N printer phantom misfeed
    It seems that the sensor is having dust or toner settled upon it. Kindly remove the toner and clean the residual toner. Take a hard stock paper and give one copy command and push it while it tries to pull the paper. Paper misfeed is not the same as paper jam. Paper misfeed refers to the blank paper tray and paper jam refers to paper which has been taken from the tray and now inside the unit.
    May 19, 2010 | Ricoh Aficio CL3500N Laser Printer
    Paper jam
    I would like to inform you that this might cause due to dirty paper rollers hence Please click here and follow the instructions to resolve this isse.
    May 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
    I JUST CHANGED THE TONER AND THE COPIES ARE PRINTING OUT WITH A HEAVY THICK LINE ON THE SIDES
    Indication Cause and remedy Page
    Drum replacement
    required indicator
    Steadily
    lit
    Replacement of drum cartridge will be needed
    soon. Prepare a new cartridge. 70
    Blinking Drum cartridge must be replaced. Replace it with
    a new one. 58
    TD cartridge
    replacement
    required indicator
    Steadily
    lit
    Replacement of TD cartridge will be needed
    Blinking TD cartridge must be replaced. Replace it with a
    new one. 57
    Misfeed indicator Blinking
    A misfeed has occurred. Remove the misfed
    paper referring to the description of "MISFEED
    REMOVAL".
    63
    SPF misfeed
    indicator Blinking
    An original misfeed has occurred in the SPF.
    Remove the misfed originals referring to the
    description of "D: Misfeed in the SPF".
    67
    Power save indicator is
    steadily lit.
    The unit is in the preheat mode. Press any key to
    cancel the preheat mode. 54
    The unit is in the auto power shut-off mode.
    Press the start ( ) key to cancel the auto power
    shut-off mode.
    54
    The paper tray indicator is
    blinking.
    The paper tray is not installed properly. Push the
    tray into the unit securely. –
    "CH" is blinking in the
    display.
    The TD cartridge is not installed. Check if the
    cartridge is installed. 57
    "CH" is steadily lit in the
    display.
    Side cover is open. Close the side cover
    securely by pressing the round projections near
    the side cover open button.
    "P" is blinking in the display.
    The paper tray or multi-bypass tray is empty.
    Load paper. 15, 17
    A misfeed has occurred in the paper tray or
    multi-bypass tray. Remove the misfed paper. 63
    A letter and a number appear
    alternately.
    The scan head locking switch is locked. Unlock
    the scan head locking switch. 9
    alternately.
    The unit will not function. Turn the power switch
    off, remove the power cord from the outlet, and
    contact our Technical Assistance Department at
    1-(630)378-3590 in the USA or 905-568-7140 in
    Canada.
    May 13, 2009 | Sharp Office Equipment & Supplies
    Mar 27, 2009 | Panasonic Workio DP-2000P Copier
    Misfeeds
    DEAR SIR WHERE YOU REMPVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEAZ CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
    Sep 16, 2007 | Sharp AR-M455N Copier
    Panasonic workio dp-1810p
    Sep 01, 2007 | Panasonic DP-1810P Laser Printer
    Panasonic Workio DP-1820E Copier Logo
    22 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
