Open sony remote control rm aau035 - Audio Players & Recorders
  • 579 Answers
SOURCE: Opening the case of a JVC Remote Control
Not having seen that particular one, remote cases usually have a couple screws under the battery to lock the case together and then a number of plastic tabs around the perimiter that hold the joint closed. find the screws (sometimes they hide them under labels) - I don't know what it is about screws that manufacturers don't like to show. Either think they are not cosmetic or don't want us take-it-apart maniacs to get in. Anyway, get the screws loose then (this is the hard part) carefully pry open the case joint, feeling where and how the tabs snap out and then be careful not to have everything inside go flying when the last one lets loose. Almost impossible to not leave little gouge marks in the joint.
Hope Ya Fis It!
Posted on Jan 08, 2008
SOURCE: Insignia TV code for Sony remote RM-V302
press tv, hold setup til tv blnks twice and release setup, type 10463 then power. 5 digit code not 4 like most.
Posted on Jun 19, 2008
  • 3 Answers
SOURCE: remote control
Go to
http://www.1800customersupport.com/products.aspx?type=pa&view=325&p=21&sc=26
Posted on Aug 21, 2008
  • 17 Answers
SOURCE: sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Posted on Oct 30, 2008
SOURCE: How to open remote control Sony RM-Y181
I had open a Sony RM-GA010 because the transmitting bulb was stucked inside after a fall. The two screws inside the battery compartment was not really holding the case together. I used two flat screwdrivers working on the side of the remote control; one levered open a bit and the other slipped in further and levered more to split it open. I think a blunt knife may also do the job; but never a sharp one because it will be too dangerous. You need to accept some permanent depression at the edge of the control (better than a useless remote). Once you open some part, it become much more easy. After opening the outer case, you can access the buttons, but not he transmitting bulb in my case. I need to loosen two additional screws (i.e. totally four, including the two inside the battery compartment) to loosen the electronic board a bit and I could correct the bended transmitting bulb. Then put everything back, clicked up the case and the remote worked again!
Ben
Posted on Aug 29, 2009
How to open Sony remote control device RM-887
and why does it need opened . not made for self service .
Dec 23, 2014 | Sony Televison & Video
Sony rm ss251
As all other buttons works properly except Volum Dn, the problem is with the remote control itself. Clean the remote control and check. To clean it, you have to open the remote control. If it too doesn't help you, buy one original remote control from the authorized service center for Sony. No universal remote control will go properly with Sony TVs. If you wish to get some details, check the site linked here. Pull up older posts.
Dec 07, 2013 | Sony Televison & Video
Need instruction manual for sony rm 841 remote control
How can i tune chanells. How can i open the menu for tuning with RM-841
Nov 07, 2012 | Sony Original Tv Vcr Remote Control Rm-841...
Sony Remote RM-YD035 does not change channels or turn off TV
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
Open remote control sony RM-GA011 for cleaning
how can i open remote control RM-GA011 SONY REMOTE
Oct 01, 2012 | Sony Televison & Video
Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
Apr 01, 2012 | Sony Rm-yd035 Remote Control
TV remote RM-ED002 for main TV works fine except volume control which has no effect. Another Sony remote, RM-ED007 for second TV works fine on main TV including volume control.
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
Aug 24, 2009 | Televison & Video
Have sony RM-AV3000 need code for direct tv Hr20-100s
how to program the remote control sony model RM-AV3000
Nov 19, 2008 | Sony RM-AAP001 Remote Control
65 people viewed this question
 Grubhead
Grubhead
